Home » Eclipse Projects » Plugin Development Environment (PDE) » Project Explorer vs. Navigator problems
Project Explorer vs. Navigator problems [message #487114] Mon, 21 September 2009 19:38 Go to next message
I have a problem with both views:
1) Navigator does not show problem marker decorations created on IFiles, however Project Explorer does.
2) Project Explorer does not show my custom 'New Custom Project' and 'New Custom File' extension points when i right click on the project in the Project Explorer, however the Navigator does.
Also which view should i be using if i am creating a custom IDE for a proprietary language?
If more information is needed, let me know what information you need and i will provide the details.
-Rob
Re: Project Explorer vs. Navigator problems [message #487257 is a reply to message #487114] Tue, 22 September 2009 11:32 Go to previous messageGo to next message
Problem 2 is likely because you have not attached the "New..." actions
to the right kind of object or context. Can you post the extension XML
that you're using to register your New Custom... wizard?
Eric
Re: Project Explorer vs. Navigator problems [message #487281 is a reply to message #487257] Tue, 22 September 2009 12:24 Go to previous messageGo to next message
Attached is a small snippet of the plugin.xml. This shows up in navigator but not in project explorer as stated in my previous post above.
Edit: It did not seem to upload my file, here is the pasted xml:
<?eclipse version="3.0"?>
<plugin>
	<extension point="org.eclipse.ui.newWizards">
		<wizard category="com.xxx.med.cad.kmt.application.KMTCategory"
			class="com.xxx.med.cad.kmt.application.wizards.KMTProjectWizard"
			hasPages="true" icon="icons/kmt_diagram_file.gif"
			id="com.xxx.med.cad.kmt.application.wizards.KMTProjectWizard"
			name="KMT Project" project="true">
		</wizard>
		<category id="com.xxx.med.cad.kmt.application.KMTCategory"
			name="KMT">
		</category>
	</extension>
   <extension point="org.eclipse.ui.newWizards" id="creation-wizard">
      <?gmfgen generated="true"?>
  	  <wizard
  	     name="%newWizardName"
  	     icon="icons/obj16/TemplateDiagramFile.gif"
  	     class="com.xxx.med.cad.kmt.template.diagram.part.TemplateCreationWizard"
  	     id="com.xxx.med.cad.kmt.template.diagram.part.TemplateCreationWizardID">
  	  	 <description>%newWizardDesc</description>
      </wizard>
   </extension>
</plugin>
[Updated on: Tue, 22 September 2009 12:26] by Moderator
Re: Project Explorer vs. Navigator problems [message #493064 is a reply to message #487114] Thu, 22 October 2009 18:32 Go to previous messageGo to next message
Hi Robert,
I am facing a similar situation with problem markers not appearing in the navigator. They show up in the problems view but not on the IFile in the navigator. When I refresh the file manually, then they appear. Please let me know if you had any luck in solving this issue.
Sushma
Re: Project Explorer vs. Navigator problems [message #494265 is a reply to message #493064] Thu, 29 October 2009 16:10 Go to previous message
I have not solved this problem yet ...
Re: Project Explorer vs. Navigator problems [message #601810 is a reply to message #487257] Tue, 22 September 2009 12:24 Go to previous message
Previous Topic:Headless build contribute root files twice when p2.gathering=true
Next Topic:Project Explorer vs. Navigator problems
Current Time: Wed Jul 23 19:58:48 EDT 2025
Powered by FUDForum. Page generated in 0.06046 seconds
