Home » Archived » Buckminster » Buckminster headless installation
Buckminster headless installation [message #487095] Mon, 21 September 2009 16:39 Go to next message
Hi!
I'm trying to install buckminster headless on linux and get the error
messages below. Can someone please help?
fhackenberger@hacki-mobile:/tmp/director$ ./director -r
http://download.eclipse.org/tools/buckminster/headless-3.5/ -d /tmp/buckminster/ -p
Buckminster -i org.eclipse.buckminster.cmdline.product
Installing org.eclipse.buckminster.cmdline.product 1.1.350.r10646.
An error occurred while collecting items to be installed
session context was:(profile=Buckminster, phase=, operand=, action=).
No repository found containing:
osgi.bundle,org.eclipse.equinox.frameworkadmin.equinox,1.0.1 00.v20090520-1905
Error closing the output stream for
osgi.bundle,org.eclipse.equinox.launcher.gtk.linux.x86,1.0.2 00.v20090520 on
repository file:/tmp/buckminster/.
Caused by: java.io.IOException: Error
unzipping /tmp/org.eclipse.equinox.launcher.gtk.linux.x86_1.0.200.v200 905208209252915533000918.jar:
Invalid zip file format
osgi.bundle,org.eclipse.equinox.registry,3.4.100.v20090520-1 800
Application failed, log file
location: /tmp/director/configuration/1253565376750.log
cat /tmp/director/configuration/1253565376750.log
!SESSION 2009-09-21
22:36:16.211 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_GB
Framework arguments: -r
Command-line arguments: -r
!ENTRY org.eclipse.equinox.p2.engine 4 4 2009-09-21 22:36:55.132
!MESSAGE An error occurred while collecting items to be installed
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2009-09-21 22:36:55.132
!MESSAGE session context was:(profile=Buckminster, phase=, operand=,
action=).
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0 2009-09-21
22:36:55.132
!MESSAGE No repository found containing:
22:36:55.132
!MESSAGE Error closing the output stream for
!STACK 0
at
org.eclipse.equinox.internal.p2.core.helpers.FileUtils.unzip File(FileUtils.java:75)
at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository$ZippedFolderOutputStream.close(Simpl eArtifactRepository.java:155)
at java.io.FilterOutputStream.close(FilterOutputStream.java:143 )
at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository$ArtifactOutputStream.close(SimpleArt ifactRepository.java:83)
at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:184)
at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:159)
at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:95)
at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:511)
at
org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
22:36:55.133
DI Florian Hackenberger
florian@hackenberger.at
www.hackenberger.at
Re: Buckminster headless installation [message #487105 is a reply to message #487095] Mon, 21 September 2009 18:05 Go to previous messageGo to next message
Hi Florian,
I think you hit a bad mirror. I just tried and I can run your command without problems. Please retry the install. If the
problem persists, try passing -Declipse.p2.mirrors=false to the director. This is not something that you should do every
time since it puts a heavy load on the servers at eclipse.org but it's sometimes good to use when analyzing problems.
Thomas Hallgren
On 09/21/2009 10:39 PM, DI Florian Hackenberger wrote:
> Hi!
> !SESSION 2009-09-21
> action=).
> 22:36:55.132
> 22:36:55.132
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> 22:36:55.133
Re: Buckminster headless installation [message #487108 is a reply to message #487105] Mon, 21 September 2009 18:13 Go to previous message
Hi Thomas!
Good to see you are still working on buckminster :-)
A bad mirror was indeed the issue,
passing "-vmargs -Declipse.p2.mirrors=false" solved it for me. Sorry for
not coming up with that conclusion myself! Thanks for your support and keep
up the good work!
Florian
www.hackenberger.at
Previous Topic:Different materializing in headless mode with target definition
Next Topic:headless 1.1.350.r10655 installation problem
Current Time: Sun Jul 20 22:15:38 EDT 2025
Powered by FUDForum. Page generated in 0.36852 seconds
