Home » Language IDEs » ServerTools (WTP) » Problem deploying plugin I wrote myself.(Problem deploying plugin I wrote myself.)
Problem deploying plugin I wrote myself. [message #486945] Mon, 21 September 2009 05:29 Go to next message
I am using Eclipse Ganymede to write a simple plug-in.
My plug-in project uses the template: 'plug-in with sample help content'.
I test it using the "Launch an Eclipse application" in the testing section of the overview tab of the project. All Ok. It works as expected. I can see the new items in the help menu.
I then export the plug-in using the links in the export section, on the overview tab in the plug-in development perspective. This results in a jar file created for plug-in with all the files in the jar file.
However, when I try to use this plug in any other eclipse instances, I run into problems. I selecte help / software updates / available software / Add site / Archive / Select the jar and I get:
No repository found at jar:files:D:\plugins\my.plugin.help_1.0.0.jar!/
and then:
See details for more information.
I click on details an dI just get the same error message.
This makes no sense to me. Would really appreciate some help. I have tried using the -clean option makes no difference. The jar file looks ok, it's not corrupted I can open it with winzip and all ok.
Any help, greatly appreciated.
Thanks.
Re: Problem deploying plugin I wrote myself. [message #487306 is a reply to message #486945] Tue, 22 September 2009 13:44 Go to previous message
If you want to install via update-manager/p2 you need to create/export a
feature that contains your plug-in, and then an update site, that
contains that feature.
Easier to just drop the plugin in the 'dropins' folder.
Felix
Previous Topic:Struts 2.1 Minimum Jars
Next Topic:Extend the XML of SSE or Write a new one?
Current Time: Fri Jul 25 20:40:10 EDT 2025
Powered by FUDForum. Page generated in 0.03016 seconds
