Flashing Window Title Text using Display.async [message #486917] |
Sun, 20 September 2009 20:26  |
After looking and figuring out that getting a window to request attention of the user without bringing the window to the front (aka. flash in the taskbar in windows, jump up and down on a mac, etc) I decided to explore other routes and ideas.
I was messing around and thought it would be cool to try and make a rotating window title or a flashing window title, just something of that nature because if I cant make the item flash, I can at least be as annoying as can be. I tried the following just for a generic text changing tool:
Display.getCurrent().asyncExec(new Runnable (){
public void run ()
String text = tempWindow.getText();
//flash 10 times and thats it
for (int x=0;x<10;x++)
if (tempWindow.getDisplay().getActiveShell() == tempWindow.getShell())
break;
tempWindow.setText("SEE ME!!!");
try
Thread.sleep(1000);
catch (InterruptedException e)
e.printStackTrace();
break;
tempWindow.setText(text);
try
Thread.sleep(1000);
Overall what it is supposed to do is in every second, switch between the current window text to the text "SEE ME!" and then in another second switch back.
The issue is, this code freezes up the UI thread so that all the threads in the Display cannot refresh. This means that Windows will give a lovely "Not responding" on the title bar since the UI isn't responding.
And I'm assuming once we get this to run truly in another thread, that adding a ShellListener will allow knowledge that the user has clicked on a window and we can kill the async method which will be the next step for this project.
Anyone have any ideas or suggestions on how to make this work? Or how to make a window request attention?
Re: Flashing Window Title Text using Display.async [message #486920 is a reply to message #486919] |
Sun, 20 September 2009 22:17   |
On Sun, 20 Sep 2009 21:37:00 -0400, Ricky Patel wrote:
> Seems to work quite well, thanks!
Okilydokily.
> For anyone who is interested, here is a generic version of it that uses
> a shell and a string
Note that you're going to want to do some kind of checks within your
runnables since the code only considers the _current_ active shell at any
one moment in time and doesn't concern itself over how focus is being
shofted around.
Consider the scenario where you have window A and window B with the focus
on B, A starts blinking, you click on it, it stops blinking, then you go
back to B all within the ten seconds, A will start blinking again. I'm
not sure if this is the behaviour you want or not but thought I would
mention it.
Remy
Re: Flashing Window Title Text using Display.async [message #490694 is a reply to message #486917] |
Fri, 09 October 2009 13:51  |
Noting that my solution really doesnt handle the situation that Remy brought up I thought I would remake the solution for anyone who would like to use it:
* makes a window request a users attention
* @param tempWindow a shell of some sort
* @param tempMessage a message for the user to know why attention is needed
protected void requestUserAttention (Shell tempWindow, String tempMessage)
//rate at which the title will change in milliseconds
int rateOfChange = 1000;
final Shell window = tempWindow;
final String orgText = window.getText();
final String message = tempMessage;
window.setData("requestUserAttention", true);
window.addShellListener(new ShellAdapter (){
public void shellActivated (ShellEvent e)
window.setData("requestUserAttention", false);
window.getDisplay().timerExec(2*rateOfChange*x-rateOfChange, new Runnable (){
public void run ()
if (((Boolean)window.getData("requestUserAttention")))
window.setText(message);
window.getDisplay().timerExec(2*rateOfChange*x, new Runnable (){
public void run ()
if (((Boolean)window.getData("requestUserAttention")) || window.getText().equals(message))
window.setText(orgText);
FUDForum. Page generated in 0.08973 seconds
