Home » Archived » B3 » Re: b3 - resolver model
Re: b3 - resolver model [message #486588] Fri, 18 September 2009 06:54 Go to next message
Copied from an email:
>> On Sep 17, 2009, at 10:12 PM, Thomas Hallgren wrote:
>> On 09/17/2009 01:57 AM, Henrik Lindberg wrote:
>> - In Buckminster, there are flags for mutable, source on readers, and
>> regexp pattern matching on component names to control the routing. In
>> b3, this is instead moved to a regular OSGi type filter. The OSGi
>> filter does not have the pattern matching capabilities of a regexp, but
>> wildcard at the end, or middle seems to be what everyone is using, so
>> this should be fine.
> I've been thinking some more about this. Perhaps the OSGi filter is too
> limited in it's pattern matching capabilities after all. Or, if not
> limited, then at least somewhat obscure. I think people are used to two
> types of pattern matching. The regular shell type matching (similar to
> what Ant uses) and the regexp.
Agree.
>> Experience shows that even very experienced developers tend to make
>> mistakes with regexp. Forgetting to escape the dot for instance, is very
>> common. The most pragmatic approach to pattern matching is probably to
>> do use the same approach as Ant. Developers, especially in the build
>> domain, are very familiar with that.
> I can see us do this in two ways.
> 1. We change the model so that the pattern matching is separate from
> other types of filters.
> 2. Since we have our own OSGi implementation, we can add pattern
> matching operator.
> I would opt for #1 since OSGi is a standard. It doesn't feel kosher to
> add our own operators to it.
Agree, here as well. I will reintroduce my earlier design that allows a
composition of different types of filters. (For newcomers who do not
know what I am talking about - there will be models posted soon).
>> - I modeled that the IResolver takes more that one Filter. I don't know
>> if that is a good idea, but it would allow easy composition of shared
>> filters for common namespaces; i.e. just add a filter for (or
>> (b3.namspace=osgi.bundle)(b3.namespace=eclipse.feature)) instead of
>> having to first compose a string with all constraints. Idea being to
>> reduce number of instances. For convenience sake, this can just as
>> easily be done in a filter factory (a useful implementation is in
>> Buckminster).
> My preference would be one single filter. Ease of composition is
> something that needs to be addressed by tooling one way or another.
Yes, agree - especially since the earlier design allowed composition of
filters - no need to have an additional way to compose them.
- henrik
Re: b3 - resolver model [message #486617 is a reply to message #486588] Fri, 18 September 2009 08:34 Go to previous messageGo to next message
--------------060308080003000300090903
Hi, the revised Filter model part is attached... (wonder if attachments
can be used in a newsgroup???)
- henrik
>> matching operator.
Content-Type: application/pdf;
name="Filter.pdf"
Content-Disposition: inline;
filename="Filter.pdf"
JVBERi0xLjQKJaqrrK0KNCAwIG9iago8PCAvVHlwZSAvSW5mbwovUHJvZHVj ZXIgPEZFRkYw
MDQxMDA3MDAwNjEwMDYzMDA2ODAwNjUwMDIwMDA0NjAwNEYwMDUwMDAzQTAw MjAwMDUzMDA1
NjAwNDcwMDIwMDA3NDAwNkYwMDIwMDA1MDAwNDQwMDQ2MDAyMDAwNTQwMDcy MDA2MTAwNkUw
MDczMDA2MzAwNkYwMDY0MDA2NTAwNzI+Ci9DcmVhdGlvbkRhdGUgPEZFRkYw MDQ0MDAzQTAw
MzIwMDMwMDAzMDAwMzkwMDMwMDAzOTAwMzEwMDM4MDAzMTAwMzQwMDMyMDAz ODAwMzAwMDM1
MDAyQjAwMzAwMDMyMDAyNzAwMzAwMDMwMDAyNz4KPj4KZW5kb2JqCjYgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMQovTGVuZ3Ro IDcgMCBSCi9X
aWR0aCAyNDgKL0hlaWdodCA0NwovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xv clNwYWNlIC9E
ZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0K eJztwTEBAAAA
wqBs61/KDP5AAQAAAAAAAAAAAADwGPZokC4KZW5kc3RyZWFtCmVuZG9iago3 IDAgb2JqCjM1
CmVuZG9iago4IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTIKL0xlbmd0aCA5IDAgUgovV2lkdGggMjQ4Ci9IZWlnaHQgNDcKL0Jp dHNQZXJDb21w
b25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1 IDI1NSAyNTUg
MjU1IDI1NV0KL1NNYXNrIDYgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJztwjERAAAMAyHpHd92bWSAoytVVVVVVVVVVVVVVVVVVVVVVVVVVVVV VVVVVVVVVVVV
VVV14wNhrqADCmVuZHN0cmVhbQplbmRvYmoKOSAwIG9iago2MAplbmRvYmoK MTAgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMwov TGVuZ3RoIDEx
IDAgUgovV2lkdGggMjQ4Ci9IZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQg OAovQ29sb3JT
cGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4K c3RyZWFtCnic
7cExAQAAAMKgbOtfygz+QAEAAAAAAAAAAAAA8Bj2aJAuCmVuZHN0cmVhbQpl bmRvYmoKMTEg
MCBvYmoKMzUKZW5kb2JqCjEyIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1 YnR5cGUgL0lt
YWdlCi9OYW1lIC9JbTQKL0xlbmd0aCAxMyAwIFIKL1dpZHRoIDI0OAovSGVp Z2h0IDQ3Ci9C
aXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFz ayBbMjU1IDI1
NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAxMCAwIFIKL0ZpbHRlciBbIC9G bGF0ZURlY29k
ZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZtZICjK1VVVVVVVVVVVVVV VVVVVVVVVVVV
VVVVVVVVVVVVVVVVVXXjA2GuoAMKZW5kc3RyZWFtCmVuZG9iagoxMyAwIG9i ago2MAplbmRv
YmoKMTQgMCBvYmoKPDwgCi9GdW5jdGlvblR5cGUgMiAKL0RvbWFpbiBbIDAg MSBdIAovQzAg
WyAxIDEgMC44MTk2MCBdIAovQzEgWyAxIDEgMSBdIAovTiAxIAo+PiAKZW5k b2JqCjE1IDAg
b2JqCjw8IAovRnVuY3Rpb25UeXBlIDMgCi9Eb21haW4gWyAwIDEgXSAKL0Z1 bmN0aW9ucyBb
IDE0IDAgUiBdIAovRW5jb2RlIFsgMCAxIF0gCi9Cb3VuZHMgWyBdIAo+PiAK ZW5kb2JqCjE2
IDAgb2JqCjw8IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0Rldmlj ZVJHQiAKL0Nv
b3JkcyBbIDEwMCAxMCAxMDAgNTcgXSAKL0RvbWFpbiBbIDAgMSBdIAovRXh0 ZW5kIFsgdHJ1
ZSB0cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoKMTcgMCBv YmoKPDwgCi9U
eXBlIC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTYgMCBS IAo+PiAKCmVu
ZG9iagoxOCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFn ZQovTmFtZSAv
SW01Ci9MZW5ndGggMTkgMCBSCi9XaWR0aCAxNgovSGVpZ2h0IDE2Ci9CaXRz UGVyQ29tcG9u
ZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0 ZURlY29kZSBd
Cj4+CnN0cmVhbQp4nGNgIAz+QwAaFybw/z+KADL9H0H/pyYf2Xx0+zHch+F+ FAAAxnd+ggpl
bmRzdHJlYW0KZW5kb2JqCjE5IDAgb2JqCjQxCmVuZG9iagoyMCAwIG9iago8 PC9UeXBlIC9Y
T2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW02Ci9MZW5ndGggMjEg MCBSCi9XaWR0
aCAxNgovSGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3Bh Y2UgL0Rldmlj
ZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayAx OCAwIFIKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgoB84c+zJ9I5j RQkbC+I2FMZv
ALKBIrgUL5x6BqisNmdHf8MhCAKygSJAcayKU0NW9jUcXDrz/LqlVyAIyAaK AMXRtNy5/ibR
f3ln1f4Vcy4gi1+/+BIo0l27HygLVAMXB7qzNmd7c8keIJo38TRE8OieBxAR IGoq2jmn/yRc
fXHixszINfmx6yAIIrhzwy0INzt6DRAB1cDVJwUsj/FcEOu1MNJ9HhBBBNct uQjhAsWj3Ocn
+i9DNj/Bf1ms98Ioj/lABFW/9BKQDVEf47UA2Xyg21KDVyQFLE3wXxTntxAi uHH5FSAbKAJE
KUHLF01DBNGjex9Cnebnx61rq9iNHD5H994DihQmbATKIocPEMyfdDrWa0lF 2paumn3IKCdm
TUrQCqAsZpQBBeO8l5SmbCpN2QhDm4AiWBVDADC1TG0/mhO9Fuh9IDmj6zie 9EMkAAC4IdZP
CmVuZHN0cmVhbQplbmRvYmoKMjEgMCBvYmoKMzQ2CmVuZG9iagoyMiAwIG9i ago8PC9UeXBl
IC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW03Ci9MZW5ndGgg MjMgMCBSCi9X
aWR0aCAxNgovSGVpZ2h0IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9y U3BhY2UgL0Rl
dmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4 nGNgIAv8//8f
lfcfWQSN//8/qgAhPiHzMOynAAAASng8xAplbmRzdHJlYW0KZW5kb2JqCjIz IDAgb2JqCjM1
CmVuZG9iagoyNCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9J bWFnZQovTmFt
ZSAvSW04Ci9MZW5ndGggMjUgMCBSCi9XaWR0aCAxNgovSGVpZ2h0IDE2Ci9C aXRzUGVyQ29t
cG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1 NSAyNTUgMjU1
IDI1NSAyNTVdCi9TTWFzayAyMiAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29k ZSBdCj4+CnN0
cmVhbQp4nGNgGALAPr6egaEBTBIEDfb28UBq2akPII0gdgM+k4GGzt8PVAxE EAZEO25ngEwG
6gEygCRQC1wcq2MgJgNZ/3+DSKB6sBbsToKYA1RAtPkg90NcDkFALXjcD3ES RAHUZELhg+Qw
IsN/iAEAtI5FqwplbmRzdHJlYW0KZW5kb2JqCjI1IDAgb2JqCjExMwplbmRv YmoKMjYgMCBv
YmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0lt OQovTGVuZ3Ro
IDI3IDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25l bnQgOAovQ29s
b3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0K Pj4Kc3RyZWFt
Cnic7cExAQAAAMKgbOtfyhg+QAEAAABvA26O984KZW5kc3RyZWFtCmVuZG9i agoyNyAwIG9i
agoyOAplbmRvYmoKMjggMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlw ZSAvSW1hZ2UK
L05hbWUgL0ltMTAKL0xlbmd0aCAyOSAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0 IDQwCi9CaXRz
UGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBb MjU1IDI1NSAy
NTUgMjU1IDI1NSAyNTVdCi9TTWFzayAyNiAwIFIKL0ZpbHRlciBbIC9GbGF0 ZURlY29kZSBd
Cj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZlZIGjK1VVVVVVVVVVVVVVXX9T yTyJCmVuZHN0
cmVhbQplbmRvYmoKMjkgMCBvYmoKMzcKZW5kb2JqCjMwIDAgb2JqCjw8L1R5 cGUgL1hPYmpl
Y3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9JbTExCi9MZW5ndGggMzEgMCBS Ci9XaWR0aCAx
MDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNl IC9EZXZpY2VH
cmF5Ci9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEB AAAAwqBs61/K
GD5AAQAAAG8Dbo73zgplbmRzdHJlYW0KZW5kb2JqCjMxIDAgb2JqCjI4CmVu ZG9iagozMiAw
IG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAv SW0xMgovTGVu
Z3RoIDMzIDAgUgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21w b25lbnQgOAov
Q29sb3JTcGFjZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUg MjU1IDI1NV0K
L1NNYXNrIDMwIDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3Ry ZWFtCnic7cIx
EQAADAMh6R3fdmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVu ZG9iagozMyAw
IG9iagozNwplbmRvYmoKMzQgMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAov Q29sb3JTcGFj
ZSAvRGV2aWNlUkdCIAovQ29vcmRzIFsgMTAgMTE4IDEwIDE1OCBdIAovRG9t YWluIFsgMCAx
IF0gCi9FeHRlbmQgWyB0cnVlIHRydWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAK Pj4gCmVuZG9i
agozNSAwIG9iago8PCAKL1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAy IAovU2hhZGlu
ZyAzNCAwIFIgCj4+IAoKZW5kb2JqCjM2IDAgb2JqCjw8L1R5cGUgL1hPYmpl Y3QKL1N1YnR5
cGUgL0ltYWdlCi9OYW1lIC9JbTEzCi9MZW5ndGggMzcgMCBSCi9XaWR0aCAx NgovSGVpZ2h0
IDE2Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdy YXkKL0ZpbHRl
ciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nGNgIAz+w8Aw4SMDAKVS dIwKZW5kc3Ry
ZWFtCmVuZG9iagozNyAwIG9iagoxOAplbmRvYmoKMzggMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTQKL0xlbmd0aCAzOSAwIFIK L1dpZHRoIDE2
Ci9IZWlnaHQgMTYKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAv RGV2aWNlUkdC
Ci9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDM2IDAg UgovRmlsdGVy
IFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnicY2CgH5hbo48L4VL/4+dF TIRL/exqA6zq
geJY1U+vMPj+4xoQ/fgJRj+gJFAcq/rJ5UYLZ+QswEBAcazq+0pNsLoHKI5V fWeRGVb1QHGs
6pvzzbG6HyiOVX1djkVTW2NTKzoCimNVX5llhdU9QHGs6ksybLCqB4pjVV+Q aovV/UBxrOpz
U+yzkrAgoDhW9cQAANYX80cKZW5kc3RyZWFtCmVuZG9iagozOSAwIG9iagox NTEKZW5kb2Jq
CjQwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9O YW1lIC9JbTE1
Ci9MZW5ndGggNDEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1Bl ckNvbXBvbmVu
dCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgplbmRzdHJl YW0KZW5kb2Jq
CjQxIDAgb2JqCjI4CmVuZG9iago0MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0 Ci9TdWJ0eXBl
IC9JbWFnZQovTmFtZSAvSW0xNgovTGVuZ3RoIDQzIDAgUgovV2lkdGggMTAw Ci9IZWlnaHQg
NDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlUkdC Ci9NYXNrIFsy
NTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDQwIDAgUgovRmlsdGVy IFsgL0ZsYXRl
RGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMrVVVVVVVV VVVVVVVdf1PJ
PIkKZW5kc3RyZWFtCmVuZG9iago0MyAwIG9iagozNwplbmRvYmoKNDQgMCBv YmoKPDwvVHlw
ZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTcKL0xlbmd0 aCA0NSAwIFIK
L1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0Nv bG9yU3BhY2Ug
L0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVh bQp4nO3BMQEA
AADCoGzrX8oYPkABAAAAbwNujvfOCmVuZHN0cmVhbQplbmRvYmoKNDUgMCBv YmoKMjgKZW5k
b2JqCjQ2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTE4Ci9MZW5ndGggNDcgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0 c1BlckNvbXBv
bmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUg MjU1IDI1NSAy
NTUgMjU1XQovU01hc2sgNDQgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUg XQo+PgpzdHJl
YW0KeJztwjERAAAMAyHpHd92ZWSBoytVVVVVVVVVVVVVVV1/U8k8iQplbmRz dHJlYW0KZW5k
b2JqCjQ3IDAgb2JqCjM3CmVuZG9iago0OCAwIG9iago8PCAKL1NoYWRpbmdU eXBlIDIgCi9D
b2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29yZHMgWyAxMCAyMzUgMTAgMjc1 IF0gCi9Eb21h
aW4gWyAwIDEgXSAKL0V4dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24g MTUgMCBSIAo+
PiAKZW5kb2JqCjQ5IDAgb2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRl cm5UeXBlIDIg
Ci9TaGFkaW5nIDQ4IDAgUiAKPj4gCgplbmRvYmoKNTAgMCBvYmoKPDwvVHlw ZSAvWE9iamVj
dAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMTkKL0xlbmd0aCA1MSAwIFIK L1dpZHRoIDEw
MAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2Ug L0RldmljZUdy
YXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BMQEA AADCoGzrX8oY
PkABAAAAbwNujvfOCmVuZHN0cmVhbQplbmRvYmoKNTEgMCBvYmoKMjgKZW5k b2JqCjUyIDAg
b2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdlCi9OYW1lIC9J bTIwCi9MZW5n
dGggNTMgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAovQml0c1BlckNvbXBv bmVudCA4Ci9D
b2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1NSAyNTUgMjU1IDI1NSAy NTUgMjU1XQov
U01hc2sgNTAgMCBSCi9GaWx0ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJl YW0KeJztwjER
AAAMAyHpHd92ZWSBoytVVVVVVVVVVVVVVV1/U8k8iQplbmRzdHJlYW0KZW5k b2JqCjUzIDAg
b2JqCjM3CmVuZG9iago1NCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0 eXBlIC9JbWFn
ZQovTmFtZSAvSW0yMQovTGVuZ3RoIDU1IDAgUgovV2lkdGggMTAwCi9IZWln aHQgNDAKL0Jp
dHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmls dGVyIFsgL0Zs
YXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cExAQAAAMKgbOtfyhg+QAEAAABv A26O984KZW5k
c3RyZWFtCmVuZG9iago1NSAwIG9iagoyOAplbmRvYmoKNTYgMCBvYmoKPDwv VHlwZSAvWE9i
amVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjIKL0xlbmd0aCA1NyAw IFIKL1dpZHRo
IDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3Bh Y2UgL0Rldmlj
ZVJHQgovTWFzayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayA1 NCAwIFIKL0Zp
bHRlciBbIC9GbGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd 33ZlZIGjK1VV
VVVVVVVVVVVVXX9TyTyJCmVuZHN0cmVhbQplbmRvYmoKNTcgMCBvYmoKMzcK ZW5kb2JqCjU4
b3JkcyBbIDE3MiAyMzUgMTcyIDI3NSBdIAovRG9tYWluIFsgMCAxIF0gCi9F eHRlbmQgWyB0
cnVlIHRydWUgXSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iago1OSAw IG9iago8PCAK
L1R5cGUgL1BhdHRlcm4gCi9QYXR0ZXJuVHlwZSAyIAovU2hhZGluZyA1OCAw IFIgCj4+IAoK
ZW5kb2JqCjYwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0lt YWdlCi9OYW1l
IC9JbTIzCi9MZW5ndGggNjEgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0MAov Qml0c1BlckNv
bXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAv RmxhdGVEZWNv
ZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KGD5AAQAAAG8Dbo73zgpl bmRzdHJlYW0K
ZW5kb2JqCjYxIDAgb2JqCjI4CmVuZG9iago2MiAwIG9iago8PC9UeXBlIC9Y T2JqZWN0Ci9T
dWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0yNAovTGVuZ3RoIDYzIDAgUgovV2lk dGggMTAwCi9I
ZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFjZSAvRGV2 aWNlUkdCCi9N
YXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDYwIDAgUgov RmlsdGVyIFsg
L0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdmVkgaMr VVVVVVVVVVVV
VVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iago2MyAwIG9iagozNwplbmRvYmoK NjQgMCBvYmoK
PDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UKL05hbWUgL0ltMjUK L0xlbmd0aCA2
NSAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRzUGVyQ29tcG9uZW50 IDgKL0NvbG9y
U3BhY2UgL0RldmljZUdyYXkKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBdCj4+ CnN0cmVhbQp4
nO3BMQEAAADCoGzrX8oYPkABAAAAbwNujvfOCmVuZHN0cmVhbQplbmRvYmoK NjUgMCBvYmoK
MjgKZW5kb2JqCjY2IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUg L0ltYWdlCi9O
YW1lIC9JbTI2Ci9MZW5ndGggNjcgMCBSCi9XaWR0aCAxMDAKL0hlaWdodCA0 MAovQml0c1Bl
ckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VSR0IKL01hc2sgWzI1 NSAyNTUgMjU1
IDI1NSAyNTUgMjU1XQovU01hc2sgNjQgMCBSCi9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJztwjERAAAMAyHpHd92ZWSBoytVVVVVVVVVVVVVVV1/U8k8 iQplbmRzdHJl
YW0KZW5kb2JqCjY3IDAgb2JqCjM3CmVuZG9iago2OCAwIG9iago8PCAKL1No YWRpbmdUeXBl
IDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0IgCi9Db29yZHMgWyAxNzIgMTE4 IDE3MiAxNTgg
XSAKL0RvbWFpbiBbIDAgMSBdIAovRXh0ZW5kIFsgdHJ1ZSB0cnVlIF0gCi9G dW5jdGlvbiAx
NSAwIFIgCj4+IAplbmRvYmoKNjkgMCBvYmoKPDwgCi9UeXBlIC9QYXR0ZXJu IAovUGF0dGVy
blR5cGUgMiAKL1NoYWRpbmcgNjggMCBSIAo+PiAKCmVuZG9iago3MCAwIG9i ago8PC9UeXBl
IC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0yNwovTGVuZ3Ro IDcxIDAgUgov
V2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29s b3JTcGFjZSAv
RGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFt Cnic7cExAQAA
AMKgbOtfyhg+QAEAAABvA26O984KZW5kc3RyZWFtCmVuZG9iago3MSAwIG9i agoyOAplbmRv
YmoKNzIgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3VidHlwZSAvSW1hZ2UK L05hbWUgL0lt
MjgKL0xlbmd0aCA3MyAwIFIKL1dpZHRoIDEwMAovSGVpZ2h0IDQwCi9CaXRz UGVyQ29tcG9u
ZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZVJHQgovTWFzayBbMjU1IDI1NSAy NTUgMjU1IDI1
NSAyNTVdCi9TTWFzayA3MCAwIFIKL0ZpbHRlciBbIC9GbGF0ZURlY29kZSBd Cj4+CnN0cmVh
bQp4nO3CMREAAAwDIekd33ZlZIGjK1VVVVVVVVVVVVVVXX9TyTyJCmVuZHN0 cmVhbQplbmRv
YmoKNzMgMCBvYmoKMzcKZW5kb2JqCjc0IDAgb2JqCjw8L1R5cGUgL1hPYmpl Y3QKL1N1YnR5
cGUgL0ltYWdlCi9OYW1lIC9JbTI5Ci9MZW5ndGggNzUgMCBSCi9XaWR0aCAx MDAKL0hlaWdo
dCA0MAovQml0c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VH cmF5Ci9GaWx0
ZXIgWyAvRmxhdGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/K GD5AAQAAAG8D
bo73zgplbmRzdHJlYW0KZW5kb2JqCjc1IDAgb2JqCjI4CmVuZG9iago3NiAw IG9iago8PC9U
eXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0zMAovTGVu Z3RoIDc3IDAg
UgovV2lkdGggMTAwCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAov Q29sb3JTcGFj
ZSAvRGV2aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0K L1NNYXNrIDc0
IDAgUgovRmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIx EQAADAMh6R3f
dmVkgaMrVVVVVVVVVVVVVVVdf1PJPIkKZW5kc3RyZWFtCmVuZG9iago3NyAw IG9iagozNwpl
bmRvYmoKNzggMCBvYmoKPDwgCi9TaGFkaW5nVHlwZSAyIAovQ29sb3JTcGFj ZSAvRGV2aWNl
UkdCIAovQ29vcmRzIFsgMzM0IDIzNSAzMzQgMjc1IF0gCi9Eb21haW4gWyAw IDEgXSAKL0V4
dGVuZCBbIHRydWUgdHJ1ZSBdIAovRnVuY3Rpb24gMTUgMCBSIAo+PiAKZW5k b2JqCjc5IDAg
b2JqCjw8IAovVHlwZSAvUGF0dGVybiAKL1BhdHRlcm5UeXBlIDIgCi9TaGFk aW5nIDc4IDAg
UiAKPj4gCgplbmRvYmoKODAgMCBvYmoKPDwvVHlwZSAvWE9iamVjdAovU3Vi dHlwZSAvSW1h
Z2UKL05hbWUgL0ltMzEKL0xlbmd0aCA4MSAwIFIKL1dpZHRoIDExNAovSGVp Z2h0IDQ3Ci9C
aXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0RldmljZUdyYXkKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3BAQ0AAADCoGzvX8oeDigAAAAA gAcDrsVQugpl
bmRzdHJlYW0KZW5kb2JqCjgxIDAgb2JqCjI5CmVuZG9iago4MiAwIG9iago8 PC9UeXBlIC9Y
T2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0zMgovTGVuZ3RoIDgz IDAgUgovV2lk
dGggMTE0Ci9IZWlnaHQgNDcKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JT cGFjZSAvRGV2
aWNlUkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNr IDgwIDAgUgov
RmlsdGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh 6R3fdk1khKMr
VVVVVVVVVVVVVVVVVVVV3X0OO3b3CmVuZHN0cmVhbQplbmRvYmoKODMgMCBv YmoKNDEKZW5k
b2JqCjg0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5cGUgL0ltYWdl Ci9OYW1lIC9J
bTMzCi9MZW5ndGggODUgMCBSCi9XaWR0aCAxMTQKL0hlaWdodCA0NwovQml0 c1BlckNvbXBv
bmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0ZXIgWyAvRmxh dGVEZWNvZGUg
XQo+PgpzdHJlYW0KeJztwQENAAAAwqBs71/KHg4oAAAAAIAHA67FULoKZW5k c3RyZWFtCmVu
ZG9iago4NSAwIG9iagoyOQplbmRvYmoKODYgMCBvYmoKPDwvVHlwZSAvWE9i amVjdAovU3Vi
dHlwZSAvSW1hZ2UKL05hbWUgL0ltMzQKL0xlbmd0aCA4NyAwIFIKL1dpZHRo IDExNAovSGVp
Z2h0IDQ3Ci9CaXRzUGVyQ29tcG9uZW50IDgKL0NvbG9yU3BhY2UgL0Rldmlj ZVJHQgovTWFz
ayBbMjU1IDI1NSAyNTUgMjU1IDI1NSAyNTVdCi9TTWFzayA4NCAwIFIKL0Zp bHRlciBbIC9G
bGF0ZURlY29kZSBdCj4+CnN0cmVhbQp4nO3CMREAAAwDIekd33ZNZISjK1VV VVVVVVVVVVVV
VVVVVd19Djt29wplbmRzdHJlYW0KZW5kb2JqCjg3IDAgb2JqCjQxCmVuZG9i ago4OCAwIG9i
ago8PCAKL1NoYWRpbmdUeXBlIDIgCi9Db2xvclNwYWNlIC9EZXZpY2VSR0Ig Ci9Db29yZHMg
WyAzMzQgMTE4IDMzNCAxNjUgXSAKL0RvbWFpbiBbIDAgMSBdIAovRXh0ZW5k IFsgdHJ1ZSB0
cnVlIF0gCi9GdW5jdGlvbiAxNSAwIFIgCj4+IAplbmRvYmoKODkgMCBvYmoK PDwgCi9UeXBl
IC9QYXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgODggMCBSIAo+ PiAKCmVuZG9i
ago5MCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQov TmFtZSAvSW0z
NQovTGVuZ3RoIDkxIDAgUgovV2lkdGggMTYKL0hlaWdodCAxNgovQml0c1Bl ckNvbXBvbmVu
PgpzdHJlYW0KeJxjYKA9+A8DVOJTEwAABSMs1AplbmRzdHJlYW0KZW5kb2Jq CjkxIDAgb2Jq
CjE5CmVuZG9iago5MiAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBl IC9JbWFnZQov
TmFtZSAvSW0zNgovTGVuZ3RoIDkzIDAgUgovV2lkdGggMTYKL0hlaWdodCAx NgovQml0c1Bl
IDI1NSAyNTUgMjU1XQovU01hc2sgOTAgMCBSCi9GaWx0ZXIgWyAvRmxhdGVE ZWNvZGUgXQo+
PgpzdHJlYW0KeJxjYBgFxIK5Nfq4EFb1UysMf/y8iImA4ljVdxWZYlUPFMeq vjbH8vuPa0D0
4ycY/YCSQHGs6ovSbLOS7DERUJy8ABkGAACyClYpCmVuZHN0cmVhbQplbmRv YmoKOTMgMCBv
YmoKNzUKZW5kb2JqCjk0IDAgb2JqCjw8L1R5cGUgL1hPYmplY3QKL1N1YnR5 cGUgL0ltYWdl
Ci9OYW1lIC9JbTM3Ci9MZW5ndGggOTUgMCBSCi9XaWR0aCAxMTIKL0hlaWdo dCA0MAovQml0
c1BlckNvbXBvbmVudCA4Ci9Db2xvclNwYWNlIC9EZXZpY2VHcmF5Ci9GaWx0 ZXIgWyAvRmxh
dGVEZWNvZGUgXQo+PgpzdHJlYW0KeJztwTEBAAAAwqBs61/KFH5AAQAAAPA0 satxvQplbmRz
dHJlYW0KZW5kb2JqCjk1IDAgb2JqCjI4CmVuZG9iago5NiAwIG9iago8PC9U eXBlIC9YT2Jq
ZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFtZSAvSW0zOAovTGVuZ3RoIDk3IDAg UgovV2lkdGgg
MTEyCi9IZWlnaHQgNDAKL0JpdHNQZXJDb21wb25lbnQgOAovQ29sb3JTcGFj ZSAvRGV2aWNl
UkdCCi9NYXNrIFsyNTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDk0 IDAgUgovRmls
dGVyIFsgL0ZsYXRlRGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3f dg1EAhxdqaqq
qqqqqqqqqqqqqq4PZ1UlFgplbmRzdHJlYW0KZW5kb2JqCjk3IDAgb2JqCjM5 CmVuZG9iago5
OCAwIG9iago8PC9UeXBlIC9YT2JqZWN0Ci9TdWJ0eXBlIC9JbWFnZQovTmFt ZSAvSW0zOQov
TGVuZ3RoIDk5IDAgUgovV2lkdGggMTEyCi9IZWlnaHQgNDAKL0JpdHNQZXJD b21wb25lbnQg
OAovQ29sb3JTcGFjZSAvRGV2aWNlR3JheQovRmlsdGVyIFsgL0ZsYXRlRGVj b2RlIF0KPj4K
c3RyZWFtCnic7cExAQAAAMKgbOtfyhR+QAEAAADwNLGrcb0KZW5kc3RyZWFt CmVuZG9iago5
OSAwIG9iagoyOAplbmRvYmoKMTAwIDAgb2JqCjw8L1R5cGUgL1hPYmplY3QK L1N1YnR5cGUg
L0ltYWdlCi9OYW1lIC9JbTQwCi9MZW5ndGggMTAxIDAgUgovV2lkdGggMTEy Ci9IZWlnaHQg
NTUgMjU1IDI1NSAyNTUgMjU1IDI1NV0KL1NNYXNrIDk4IDAgUgovRmlsdGVy IFsgL0ZsYXRl
RGVjb2RlIF0KPj4Kc3RyZWFtCnic7cIxEQAADAMh6R3fdg1EAhxdqaqqqqqq qqqqqqqqqq4P
Z1UlFgplbmRzdHJlYW0KZW5kb2JqCjEwMSAwIG9iagozOQplbmRvYmoKMTAy IDAgb2JqCjw8
IAovU2hhZGluZ1R5cGUgMiAKL0NvbG9yU3BhY2UgL0RldmljZVJHQiAKL0Nv b3JkcyBbIDQ5
NiAyMzUgNDk2IDI3NSBdIAovRG9tYWluIFsgMCAxIF0gCi9FeHRlbmQgWyB0 cnVlIHRydWUg
XSAKL0Z1bmN0aW9uIDE1IDAgUiAKPj4gCmVuZG9iagoxMDMgMCBvYmoKPDwg Ci9UeXBlIC9Q
YXR0ZXJuIAovUGF0dGVyblR5cGUgMiAKL1NoYWRpbmcgMTAyIDAgUiAKPj4g CgplbmRvYmoK
MTA0IDAgb2JqCjw8IC9MZW5ndGggMTA1IDAgUgovRmlsdGVyIFsgL0ZsYXRl RGVjb2RlIF0K
Pj4Kc3RyZWFtCnictX3JjiZNltU+nyJegGibhz0SAgkJ1AvWqEV3CUU0gm4J fW+PnTu7h0d2
ZpGlUuXv34nr5jbbnS2/pfO/f5fPPyX3t3/4/JHeZyfwPLSdCz0f/H//yCm/ 5fz2SQ99vX38
qG37w/nTx4+//PhvP/75R2mLy23zTYhPCX/3Hz/L27//Xz/+K5VV3k7Zn/TQ N4royR/On57L
ImIuq2lZe7/tU9LeD5XaVk56+w8//u6//Pd//df/8X/++e0f/uXtPOe3f/mH f347VTgfTKeE
ej51Hj7ooc/zgD/ZA/3pLz/+8Xc++t5T3uN8urz9px/57X/+yO+nqFPY/z2/ /nP89NRPz7c+
9NPj+um/5747H6WX8FBAgqGzB6HF5/M7hpH/j+fzAv7Fz9OHecjg47/nH+7W od1a8uThxkPp
KP20zR7CcKf30tNeb/9EnVzyet9lnncwvqWk9zrr+UB7n7M2vF3ye92rRSjv 991rxjsoFSQr
nz9JGfV8Yc1LGfO97LFuUG71dEB/7y0lgtp7rmldoPo+2jgfn+975E3QeM/z DPMVSqUdqvU+
85ryYts9X6DyvupaXutTqdSy1nq9l/Op07XvY89CL+z3U3S/QOs9j5G8jPXe +kyo8qy9SkGj
7Ut/nYJGzvUGtby2vUil1TPWu+lY1Pw+6qB+LJu7o5b3vte4QGeq9DGsRrW9 915Qxns+w0kF
1fdVUjUIwKnhaXl+n6nktxfR5DE3oLJOWQBqnuelsypqV5rdEg1Gw2z+IKjM UW9QKxhF77VT
p7QwCy/QmXU1tL/UfubNpOEfjWfugVIb17LGe6u136CydrpUor3vVOoNqvlM EkzxvqtAOZ3Z
RVP8DBl9L53tRIEXVSGfyX6haSvzS6cgoTmbkIwBSl1zr9DdtyF5YZxa4pmN tVM2rdx6pknJ
Kbx41mYtI7xY6nyfI81Ac9bRPLME1Wm1EM04swTfO0M30OIDrIYh2e+1tCLl pDMpsD5yXpnK
Wes8nB6r7cwn0JyZvFtFV/fZQbPPfNnbgBc34ywwp2lnPo5Eg0G7AGjye2ur 0IptZ1AAnH22
oD5F5h+gmqmKPcnMPk1dM9+gs+Rp4tZ1dmrUqPQ9DXhRL66RqtOcKp7hoEFN 40w56v5T0p69
0/6AefhJTaEJotAHty4nmkZln6mJwnvChBSAe4n3R6O5Fc3DXXgH5KXdzuLq s8VJ3DA9d71B
uSQakrFrFWjnlqi71+mT0s7Wl8o2AF15NkjagAJNPXsEFZ1aU5rTcSi643UU 3d/XxsKSJQNg
ppoNeNHn504p0JwtoZ9t47S1p8o0sv3LhmQH8FnRdALXLQevPdBa//Uj+CwI PoLpEJVTNvW3
RqfseeCD+Mwre2g/OWXTWfOH4Gen7DJG6MzeRkzVeeid6t/8oX13yuZztNFh 1YmL0l/NxvoM
xjmG63qEbPjzOehGGfQiDW0+Z9g5rpsBr0Nzpt1ukWa/55WGlQMarJGzETRZ tefYPeO4kgGH
BsfPObUCTeHN+AB7zUk05WzGhYo+B3Z9c+BsK9jDA02nRp1S2zi81/XXIS+b 5oNDZx9aOOYr
WFtUTQAUeUYrpe001sRzHLeuTSSIP4TTPdd1+xU+axCKxFZ5epa2eQVe1Puz 1x1odITCZwXq
PPsz9tl6lkI/u1EZNHXObkxHbZctPOP4OJuoAWjhWWjpNNppcF4e1qHjyKaT KeNYBz9zIGau
DDi71hg70rSzc2NzQjl9MFBr5gE65y72x9OKNU69UUEeeQFeVOdzwg6DPi5Q KbQEHDodlMqk
lp0DpBrAXzvnTaRpvG8eYM7cpPUMDd5JP7iSY3ef1ehFHAVh5qOvE78mNGcM a8o8Y1MTmtXP
xLQxNECaEWjQj2XyrFTozE5wvhm7Pk4ZBfDamQU09IGmt84AWBamGWdhANqD RBBAZYXRp2/t
PC7T4Zwt+Sy5SHOZVi+aa9L9p94r1SlzjUfksJs1DxmkMwMqQYf7l86lk0oh 6m1wVJg2pWQZ
k9OnE4Wnw6m/RaDnNG80i4434t8gbJ2ddhNTYUV3YZ8AjIZaGz+FKh6GoASa W8uouWAraJc3
TjcTN7K96wDQtOnG6WbwB+D/unC6Dhina1Az9hEQ8YFPkO/Z9uIDZJwuarXK aV8zTtchfxEs
Q+I9+QvklbAXv0LdOF2HhItF5818GKdunC6gTfK/0ZxeXLXHkTGIq3MKqbuE 7r4NCY/TaSXE
ujhO4IhHHKezT4GD9vkMKDce816hgFAAWxc4pUBzFm8qvUo5+bLh4Fsth/MQ A7HHijvHeWw5
nqvnfWpnw5afuOkKTa77B71Wx+GZ8TXISih69d4MeFHricF2mgaOmap4ln2X Kp4lxcdXwXlm
wGbBItCc7jjMZOZyaCjA3tat32q8S9VG5Zz6rDYN4Kb2VnegmVwg1mhaU5qq EJ0e0tSEhWQj
dhtVHuqzvS0+6z/9VzNp9fClZ8a3/gg5m3OadEa1+HCcipxRmHHI8N29Ik05 3O2ifk15Mk09
j4uKbmcOvDlw2JPNZ41CPKNPIYknZvzVhLuN0GHyc+WqrVVp/Z1Dk4aKz+jN SxL8O/oanafA
i5uIoTYa64bzrSFTRyDlJfrZBTGFTh3mYn2cQZU5ENTwTO9BY3D27gkFC2ZF px33iAVcw7Mm
yqQt76y2MwkUCEe+QaeGsw4vp2F35g1fv9U6n7xWHx3f148I7U4cMqDTP8O2 RCpnN2JjR61a
dFub+rXjpHMgVFEgNIMkFS2nQ2rgtaXfAmNz70Casx0ScK4yZ/VXM1VNHoXl qSfINFW5n8MA
2ponaPIJgBeVqX6AwBqMcnnxK4RTq/IqOZWoepDdIZkxAzMRW/qRN1shjsAg sOWty1tlDYJG
gT73ADQuCpxuHKcEOkCMpp5tsBJwRroLzVydto3dB9MokKHYCDSxMw/XQPLb Vwh70hr7AslM
RyWP5JkNeHFDalgNX9pPAz4Ol5P6hSUf4NRyYLfHYUZbKpEHG9CYXGgGa3AC S36gkvN2ltwA
Z8kVMpb8ALvlC0t+vkVaFWPJT51TbReW/EBl1AtLHiBlyQ1Sdvs09TCCLZ6Q AydaizSnZUf8
iCy5Qc6So5I4bWwHPkW3XS4s+fk8sdlOs8HBlciSz8S1NZbcAGfJFQosuUHK bh9gYh0ElhwQ
xiHSbKhdA0sOaM0aWfKJ0UqBJce3oByO02G/9x3Ovy/TSucadX9gyW1EnCU/ HXdmQIss+YHO
GRFYcvT2QOc6Sz6g+qvLWfIAKEseIGbJBw6ceWHJtWhjt8/HU64Xlny44CI0 t5ZRc2c9897U
HDMzoxYY2Imt5srmTminG23iq1SGzr7eWW4zqsGcUITOGQNxXDe7lc6mL+yq rOt5KnlhUOeZ
onW1OJATk/xCAw0oM026rs/XlTXmdW2Ar2uFbF1PrA8GdF2fz9eZfBmjgrOe oQvr+kCsHPJ1
HSBd1wbpmj1AymER89dKL5HmPIyd47o2yNc1Ktnimp2Qc65KptPXae7kNIs0 dy2u6wOp/orX
tQG+rhUK69ogXbMr80IJ6xrQ5oPFaA4fk+O6BrR4f9B1faDaV/WhxrdGiUws IJZPA81lWvFE
l+4P69pGxNf1gUbdI67r07kk6Ni6nqJICOt6QjI4n7Z1HQBd1wHidT3BuIwS 1/V0HQWv2Qlj
GB9Puq4nhKnSAs2tZdTcBQVB4WUDpdpp7jqrb6xu0JGNTudWYjNzXTxM4DFO 5dCQDVlDgTMD
DsmKNFjYHUYCKudMBQgYpfNMgvJrEVNGhg3UZ9EhJgBosGr3CDRnlqHOVE7l sQ0Cez8nhQNY
l+VCc+qcidHRctCuXlb8lrf91j/WaUvmZGbl9IIeQ84sUuMv6N8T8weZBbTz PTJKnQlBzKoD
GM5SLzRntfWcqZy2F53FhwmmfWSp6qczT+idJgB37ATD5DSNzTBUDut4z3j0 s9Pzt8DVGYBO
473PIOx9sEagHCiq0a4k67GxPOJtv/UPddr2ozf11cluLlCQGfdZ21icT5CL kfscNrmEjWyf
qbVbjxvZbqflOTAxG5ZD5n1ozoFGjyMYdmAPNgA65tkjDZboqTiVs8rkMzSz eH6gknrYWk59
zny7nEaoc5uRRtoVFDUb0nBb1kd0+hldUks0yqqjBaXP+V6q61pWO/tQW4FG gNO2slgbZpCo
mKjeMAw2swzRt9YagUbHQ3TsPLodomMBP76OkE6VdCiJ3HQgMnKBawdHkPdh mUcfBuB7g4WF
SHM+Q0Dqm8fk8D6pU/fOTWNiQPxzYCn2YXzOLvwE9euvdmpLRYIvOdukAjwV VoWgYDS3VnNX
6Ne7j5dCLghZhR6g6DmQTtGr0DCqNTmV04vDZxKAQgvQrckJzgN9BBrYQLto h6SnD6M7B89s
WJMNaGZNdkityQnMuRhtxJp8IDKLqz0JH6fN0G1OqCKdZk5zhncVmmlqTT7Q Ph1Aq5GsyQa4
NZmgQvuRmo7P5/up4w2ag3ckthSfzx/GpxjAJZFWzGm8p92anLDNZZJY1JqM 7oezRHNrskFq
KUYP1LEN4F6ahVVWQnMrmr93Nrk6fdzwPaj1awtDKbpI51sA5cbnMalUDXCV qkOiUqVymigw
mbGkb7XlGyvqQ8yCb6wliTXEaZyLFJWqQ6ZSxWuHG9imLqWiB88AUakCyuVC A+F0laBSBVRq
bqZSdcBUqgapSpXKQX1cpUrfgqZH1aVUn51dx8pN7T3NQHNmYmMbh6hUIyQq VWoqzmMfsduo
0lBnkZjCUOfM3W8vZmK5RrBylCzzSK0cDrg/T/a5pk4y8DbDIn+C3DHBXnyA 3J/n1Ip6060c
DoUXzwI7wsgjFCqhL36F3MrhkPrqnM7ra61w4AFicc9ocGCUGZhih7g6olj2 7r4NCY/TOSRb
I90T6W8/L9CZWrTl5MZqY5xSs2FYFDhn+WEu6OsGyRtcyPWXzFByIjzMbJi0 EfLJZpCoxr7U
lxsxeY8n+d1+tYvnH2ljA1QSOxcpBG9AMgKdcT+fpRV7oL0qT4V+BtkBmJrn vtBM9VbLvJ9j
CU/SW+NbrSSSsQ5jB2811YsJ8CKHRtpwFPpwSDQFTnJWYCe/FHKDhESpkHg5 4jRQiL5OZonJ
bllcoTPhaHfqmTy1FDi7XBvpQjNYMgPQoV6BdSavKjQZQopqjwu5Ru1tQGyY aZj/Qn6Op6+z
jJj+CoupwPeupkfI/YoONDrXkXfrctbxEWPjjl5gTNoj0JwGYd9r7ldkkPsV 4TVwPbp0AZA3
pHOP9Pm9SqDRKrpfkUI6iPDOXMFFgl0vM01yXalw4pisOqiDVxecOCCikMRV y5sB4WAw6JyB
p4eknMZn4GHPiWaxpOW9AXaolNhjNYnJQmnq2agnb2NazoFW5/Odv2UA1EZr RRrUGQcElTNY
iVfBU+m3Wtil7v3zkk6jQ1x3v096kdlVc3AUIFZAIeEBvLHOFJw+otnsNAqE jhXIvnWvD/vm
QQPQaa/aZU1xYSUozGLy55z1EfKJTY6gKw7BmaFrr8swTXNsEpozezcvdJEB 4eWXGyupSQZ0
wGRAg1QGpHJK2UEGxOePeBmmaFUTbfDxbMzZOo20KxxjBkkfqe8vgyYDkkdr ZwcIc1+dtbZL
WZP9DJ1GAJcBHdIVWnU38FWMb626A42OR5AB4R/Y68hRVGnnmB47NLjBqHox LpMXZ1o7dAoU
VXKQq+MrHLZ3N1HFgBYcXxUyx9d9viUuAyKqNPBI1d3jUB9jeNXxtbAuzmkg XPcRRRU0daTu
oooBwfEVdrR+kUvgtJL5lAsQHXwmhpzPp5F7FFUOZGp8pvGedlEFhfe2oqiC puw6o6hikIoh
8Ow4IlUUVeAvCyWe09yK5u8dLqCkKQeU/gqLFqom8hJ4gILjq/remVPr2Upg 0gvrGN182W6b
GlGC46tCwfH1vJbCeQRg5rTj1MbnxUlNaLSKwfFVID2gupz74YCCUhF2PZ/o +4igeUbOHXO1
58C5G+Ccu0KBHSZni/kMhZ7dpu76AjnnDpY61wvnbpC/SHVO5RHyStiLX6HA uRukWxBar6pq
2aagJ4RQH2kGIkEC526QVocFPO3u+5DQDIUKidTkftz0dr6+rZhDPda+NBQs /Q1S/eY5pOFb
AuiL0eqIomeNjHV78azS21be91nMLQWN+9lUDts5XOOOskjqxk46eAc0CEz5 JIn6lETBMapm
BaDGddG7lpHg/5Sc5gBztRGsCWVA/135cIEAFQFyIgk00F1DsYFyds68u9Wt 3xpj0+5GTn4A
Ukm0I5/ZSjSnir2wWayz/R+t7+QzsvhAA1DE8e1MIms97QmTtc8ODHbbjzSd Tewoh6IT4DxV
Sb1OXdax+4ktAcBGdJ3bG1DrBbWK0cDXgHYohH/kJN3BEFhgUtRS64n5FY07 tb6BHzGtPLU+
z+40cP6Yadt6fFF3kNW0wd8YOgcDBnNKkeZsXnlwM9JcbOzbvJN0MHmsNif/ YqpPYv/r0XeW
pvbCS3j3kqkZ8NJOxCET1wlgVVb3kiM5XivslaMGMQPUHBRoMM+gmUY5R36g RX7Kr9rTOcd5
f1sbtIqH8jW+247GTbDlPyqbS4JK7EClcZ1YJaZAUIkZpCoxlNPEsincL77V gmkB9VnYpcL5
NM5j3pFmsuNNUIkZ5Cqx81qbLFOxuusUzc76rhIbeq4aDUnjO6rEDlTLzK4S M8AZdIVMJYZy
Fmt/VSWGbzU2vrK6C/URDwpViQXfGKFxo7qqxAKkWgo0NfqPfhlVGuqZOMIn DjVZT4MiGw4z
6uYokh88X2BQN8lPgdh+hVQao3JGjRIbfWuGYUR9rmalMoU9c5py5GlmabSc WUVDqt8ywAUv
hUzyo3JSiZLfNJ9Fafu9f6zTZncx75NebKmGA1WBWAGFVKqzxoa5f8ij278D oWMF8m/d6sOV
bByMGo5ihcKBOV0R8QVyjnGeubSC10KZ6kEThmlxPJnTbBz1LUp+cNGA771J fga45KeQSX7w
xtjiDCSSH1xPZpyic3LsaBByJnaIFmmkXYENMiiyCwa65DfhS5lX6PHJYWCx LET4RZZKgSD5
GaSsL+otrifKHuNbfQT9jY1HlPzWOWHTalHyg524hViHsip7dIROWTd16/kB b70eJb+VWMlk
kp8CQfIzSCW/Rd4jI0p+51tqE2SpbrlGTSW/5Ro1oTl7f5o7Sn6LmInlkp8B LvkBgs9LEPNO
jSY5E1+gvWuQ6k6NyEc2SH7wj6itBhrvaZf8Frqd93+V/ND9CGcOkp9BKtWd 76VR3CL14jp1
VocJza1o/t6Rh3aJ7soOmbvymcFm8KZdFcAafCyIu3JZ4DJKM07TAHebckjc la0cd1e2b6m7
stXH3ZUjJO7KgNizSyQkKieLHwm7KwPqhUV9UpA7EKookLorWznurmzf6uXt SwdSr8KHoXWV
p+2X8E+ntvBoSOx48AUSyVTfIp918kxxyPdUfesJkhe5NEzWubRG8sstBDVV xEHtR8h02TWp
0uUBMm9pvJg61+ALZN7S/uJXyL2l8eLsHJ/1BeKeqkkPJLTNfsWGjLOplCuE SOrhUIUpdHTi
+SmC5HVohD1BY6FncWAwAxJp4Ay8QAOekFVXpZJhBTRV2G5aeAZA08DBng5l dhxAfWZjvRDp
h0CDvAY87fAZjYF4UR9IEJ920ye1mkW/0HNTdmmBABCbRSIkiYf4SkEop7p6 RkAkAoMgNYBX
p3Imu0cf6X8TzWRyiIeQTmuw9nYWV63WCn3EptC2PIs05fAi3aAPKT4tg6jj G+8tXat5/rZl
C2yNq8mA6ZockhmNb5GziBt1vEbBqFNho1wtRrZVmDZbMBbXDNfFOQODC4hd F4XBNcD5MIeE
6aRyJqtshDGlb/XsxiDUhzX5xjkdpubw/D3SNHjC9ks5SIvAC1O+pYDxlwYp g8vltBQYXP5W
im2/9c9LO20HWy86TaUZgQyIFVBImFdvrDG46BDKDOA0CoSOFci/dasPVxLZ Vsa8jCzSHASH
UwA5i9umjuwQF1gbWQFiBRSy3kY5zIPYiEyW4nzUTn1IjveRJVPkDDQw8Kad YjlFtcH6LQO8
YxWykaVyxogjq2ZPb/utf6zT4B4fRham2BHCFw2IFVDIRk0bG0ZWeHCnUSB0 rPLpNrK3+lAl
S+HFzieF/nIHxVoq+08+QHralM1+2c4gH5bxdFqQCACwn6/1UC0IIAlaTQAl tcgg19JPZ7Rl
DLIBziA7JAwyysmZA5iEQQY0x3KnrYoMBKtFBhlVpPPFaQ7TO9l8KAwyNXX3 bQyyA8YgM8SG
SOGG8fnWRrlBJHso84vPFwn6EAaZenHPFmi8p41BpsJlVguDTC9iJJxBdkiY X+oBiV8RBpnq
lGekuRVN30P6GXVX4YCFCjtnGb6zVWT8KT3K8hXW4BFmAAB1kJeAhYp8Dpvn LPWFAxawYJAG
LKCcw4KnELCAz/NyEC4WFVwU02FsLZqRWsgf8HGBJGDBIV1pyDiUclQk4Gu1 7kgDCY2FEQlY
cMgCFqiSoiLgHYuyEs3LeVVVrDGaBtegGgIWKuyXWZRosD46YAELBnnAgkMS jACg5+WRSfxa
X8yDGc1E8qluAQsEiaO5BCwAIjnJh7qztjhOh3OAzb4DzW1a6Vyj7veABR8R C1hAx01kvPKA
BXTurt0h6u3G7pYSsIAx2X1tC1iIgAQsRIhcPFGOqX6FZ9Oi1aADwM5QtvDQ Ctm7BZpby7i5
mB0c1fvpv1ySqUjS0y6eaA6ZDumcJGyW81mD8LU+4syCaVYYP6Zp7hMkgci1 OQNBgcgOWCCy
QbyCYFylhBOXXx6I7JAEIgPIc8dAZECqy6cgY1R/pN4MeHETSx6BZprjqjiG GdRvKX1oHj0m
1ausl/rVlD51SUqfigIkpQ/yFyJrHx4o12C+PmXP3IcyOO1gehMiztxzTg9L 3fOWOfkAwinJ
z/z6VNJzcUwkxVlKRKTUo9Z/U7ev7f+np6SGRZManlcWtZWfPviJw5biA/3N huC3K/H9IGgF
0tYK4EnSKYYHqcDfW6fya8ijQTbPFR6E9jHtUnmnwn6Wdilb0kgE2tNcwAMH d6B2/hTmwjXz
ElKStMJphMSQih0ELKJBdH4gHAg5gzh0qWbWYiAvEImaDgwNXXKocegSlYMQ JmQt5NAlfAts
5NmZ2UyI+kA5YMChGRIyYTSTo5W5HApdQpIYREDwtyBeGzA0dMmhxf7RXs7W 0CX7lrX93j+0
fTYJKqMshaQgQiYfHEoGIY3MpHWzNHRJU9FlcvOCNsKAoaFLDjW2xXE6Gu5F CV2ib2FUS2UD
qHdaVSMp+BBoopymMt/I5UxmMln0528NMMYKDA1dcmiyzx/YEhwI1K4kJ7NE dFrb7/2DTkMG
O/B8YaaRh8xZdd7bm63/nICLOXODlprscaJMZG7Q4k/RFGsbvgcPKcRtOg3F vvNgy3kKhyBE
iVFKMDoaAiAme4emxCJQ0BAPopjskfQF0xAQmezhDEQpIU4/Lnjrv1BnTnpX hprscfr0wqNP
JnucPhP5BEtXkz1aT6E5pbPJ3oGmJnuHKmuC4PkFhx0AYrKHxxbl5dM1RDkH 6Vu2ztBD6AWn
wZRB8k5kBmWTvUNVTfbkaYW4F51pcAajlHs+G6n1KUxQJCIqjcsRkz28oyjj JaQ+Sv1hQFOT
fYTIZE+eaLTKmprs4QgH0wy6jEz2aCo4KwBiskcqH4pUQzoyNtm3IpkDIYrA ZI+mcjlDTfYH
IlGKkp+RLsGApQo6hzbrl1HwSLwYxGSPnqZcqjrvv6wNLBhiDgfPapJxz4LZ ksjDXlySgtVf
JF+OErawRrw1L5ezt2FaITfOoM1gceIsB7B9j3mhgSTAHhh9Nx7E041VvlVm mEWoDw6bOK3g
KNCbQz3Mxc0GMofOtEKqtw+8luAx7lMGRV83OXCQSJ/lNKf2G+kWfbOEUaKn 7RuqAyAe7UIz
xU4zdHWcTa5wt56Nuc6wx1CM7rxuOgvOqzXQnP/uwTkGSetL3SHQ4HivjzDQ Bp3RL3I4VRwv
9os8wYkfh1sWZsUTVNO1jNM/YvZ0qKhC3gt6gKoH0fXO+YClRvorvDUR9H6F oDevyaEO3Ufm
KomyHy42JVWZV7DcGdBU2e9QZ2U/3JQoHhu6HFb2w+0FRj3KQ4hdwoGlyn6H tgQqbokhL1uV
/XB4qrym8JkzbImeaU0OdnyzAf0E1MoeDlFHUCydQajtEhpR9sNfi3Iyk74E doAAyF7i0GRl
f4egsXgDEmU/agj+hg4WnGt9OCcmyn6v9XBlv4Ndlf14ldIJK0RNodyLBnVy UV9ySGk1yURA
Oy6U/Q40VfY7VFmR35GqE4mdFIjVrK7sR0Ic7XHRAo3CkXu0w0GkH/Dw0P2U xf4B3WPvgSYp
07RVC0R+W4OXK2mBHFiqBXJoMpNzCj78CAOiBRqIzCFosIZnGFc7VAuEdEBw LTPo4wKJFsih
zhqe0zLKImYAfU04G6VJbGoAIFogh5pqgVBJysRN23miTiN1swFUybHlNaZp OJeEQ2Qt0Gg8
NvR5aIEcGKoFcmipFsihzRqeAU2NMo2sBRqdc0tFmgLvJgJYCzTQ6MzTQbRA A22Mo49v0T4U
pgMCXil3p9Lcp9WL55p0/1ItkENTtUBwd+tdUqCyFuj0JWmGDRrGYEzVAsEl cC3hFbDlREC0
QBEiDhoeklW2J+FavejNGh4ktSorO/BCfcj3xWnuLaPmTmF5tFM+AZGLuvfT QP4L/trKtJQd
gsNtoi7R1/A9aJ9QNCUeUeC8tjgZoNMgEXzmTTHPtphm584TZyNdQATIsnOl oZALpAJqq/kS
faE+xGQTk84pAFBrPnjANGRuGQODjTSvQNNZZ3iAVUuXdUQ8ILzyKKDe1sj5 /Jzzso4Wx/Y7
zZY08OBbWXuPdEg8jA0nIm0IBnVOyfhBJc20w2JfKn75hjA5h6fTBICmSqSB gHtOEgzQLLxF
UdwI1ZrPPTC8qUmNSiks/ZV6GoCsTtCvAjg7++aGrCl9vSH1OLBYNx9pUCDT nH7lyTBmkbEn
DsGn3n16Ys4i9dEu/OIqG3N2Nv6M0SFjEkS18OJE7EcPZc0MIYPZdLEBHSiv zvOabEAOTLUB
OTTYBjThnEmiblcbEFwC15YZAvvOqQ/lozDghTof4hloIL/I1BMb0OzKFna2 ATkw1QZEkMzq
til8YMIbX8bDoardTwL3+VrKIkGLDehAI+vyJJrQ02YDQn6qLMyz2IDQ/Twl htqAHOps34Gb
ZhvFAeqlWmekuReN7yFtEqcqxkjbL1SJ9bxIx7Nb2OuRQIh2pzD488YvkKff EOUA3EcPDVyM
Rc1A1ioHJvscRprBWmmUM3eVs5B4ofP5lPL2pU95p2aP2wPq3Heg8XbZonao qDmU3PpEbrpD
wvDHgihL0Sc+toiD1bLJhbNdPoYUX5Tq12gMmJz4NdJslsGnCWgCUMPonhOD vD6L3WRpTDEZ
ctMx1V8uNCBZz9zfQMYaLltCD1DXu0/gL8bi1gM09O4Tf/ErpF272IFfaq2/ XPham30HnqB7
GS6POeRttYIeoCCP7cw+3Vwj++WzY59Nb7X+CEmNkDkm9QsLgEw9swR26gDk 4MicM207G1rW
IpwzZoUDS4OwHOoa2bThqLLKM2S95i8+QNb+3TnhnmmQIuQvTs6E/wh5JezF B2hpEJZDwsDs
wUHtgclB2p0U+R6k3blwa0TDEI0BCqH8rdbd9yGhdDhITtNSiedeTpkVXEaZ 4cRHF8n4uxuq
iBqK22ApRJsvJ99GwH4NJ58DdvI5JCffRuxRv5x8e3N+UTvVUCFKsReOPqp2 jschkFn35fCj
BpOOTE+/gNjxR1jfl/NvG3/o0JZcZXq2ZUpt00c8AFGLOkRzJ1Sh0+0I3IsN teEIpCbteTkD
AyYHHD5KaaHCKYgrrFbfDn0pnUcfKlFmy+lz+tNndU5mA3jCuiX9SkjEtQJv mpNJ/XZCZcr0
UuuV6ox2ewsyfcC6RovSm0mmBZtSEljOnhx5US06H5NGZXUdGjHqWL1cVkaG LbLqtam2PH+q
9beserWpVY922r/XT7T+veGw/c6FLG+ZVLf0iRZuZEFo9WDzbSGzRr4+1fGd +RZEYgEcwXxb
OM9iQQSCGG3DU7A438y3IJLilptvC3XM/qZu7dfMt9XMt6V2Md/iic23cGcn o6k/1H4Z6N+t
xE9GQSqQtlYAT7NpBdq1AjxGZclreOiklW7hofo0uJtvIePzdVm/Yr5tQ+YC Hjqf0+EhzISr
8RYOynQfGnzmIJ59QpdMOe3owqhCt+dZMhilEtUw6VHhsPiJgo7E0olkb3KK h7cSUlpcoVQp
lB9zCcp3hHnIr8PTNqrsNt0vNG5tXaDKKQ35nVOLs8AR2iu1sF/ZNNqdlaOP UNFNDXpLHHuU
h4AS2RzpdK3mACkgSQZymqV1KeqHgjhSfARQ63CyNQBWz1wvNJP126R9vv+C xEe+Gg4VyVoE
l1AKbS/qh0La4cVJC8jHpE9WAxlAulHadZ3GusESFDnEvTsaB0Zy7/ovXIlF lRuVc2sUCghm
RSqxLwaQuokS9TgNXU7G5YjwhKBd5ESjK7EgPDnQVHhySLoSitSZuCNEeBo2 DbPpKCk7SRhH
1LmnSGPtKqYRUYhMo8T4js5pVJ+gL91VVHiClhDLz8oelTXN8WOZNRhOY0BT 4cmhwYIRNaxW
B6hh5PHmNFaf7sIT1E+1JB1T/eVLDEmlkUL5CYK1lCUlKOM6tf0BKiopIQZx jfkMVZWU/MUH
iLsWUZkQTrjW/ssW9awslzxC9zIshs+g0FZ96wHSFz9Yj8RBrlwj/eWzY4ZL /e6Q1GhJVIYt
DZK26+BiTR3BV4Eihll0NkimXzhHBglPDnQVnhwqKpFQRuP1DeS9Zi8+QNb+ uVkjxbcskvDk
kL2IgEBctPQIeSXsxQeoq/Dk0GDBaCWe1AawzgP2v0hD1mACWHhyaHJ1WqF1 Jd39ZUhI4TD4
3lQUI7ITAgChBPEXsdh6jy8i0XKqoayFNDyVB04kJwrso+O2s+TkQFPJyaHK khNSOs8hOx9L
ThRGOeV0whyjwM/aHXhRncFZOw1dMcNni4hNS/Ib04qF1ORAU6GJIHqtqYC0 CrttRgj3vhA0
WBpCFCccGwygGpFvjtOEnjaBCYU3ybcjAhOawudzVXnJocKS0JJLUQ14oSQO MTaae9H0PVgo
e5Ol7b98EouT+SNkTMWSCAc7aHbS88IOow15u+4LzWySEUmkJIeKCkkoacsE oCVzgMr9X1RE
wuf5LBTIqyjMxSvUel7Z5p6YbR5NmWV/6u7H+Stsc8/KNhPfq/JRGeV7znyU 3/rEqPoJYk5F
PkK7WEDCE+dquT59JyEJlVzS7R6udPxzLvomolG5Pn0nJAmVlOj3fs8sIgo9 PdbxFyWlJpIS
OEsWOeTpg59YQro+XYSlv64u3w5LqEe2emQVlKge7VYPvc+7qay1VVgqMpHk 6SdyE3Jp/4bg
VHKRSUJPNLXxofD0rfBU8mDXTtrfJYcQwu3oDmzFKA9okXNKnF+R/5RcLLDr n+NmvAWkqvtr
wBAviIB6KovY2aQOsPRF2mZwdS4lykG9iMVShHNbSso4o9rsyMNlVc2kSR6u /EVU2pGqbrAB
6+wHG8oa6gjrX/SeuPcXp0QdbKkmcYB9YQtdPd6XY5SbE96w+KZ4w+KrfDMz MgLRonUEKadK
uVJl9t+issbifhUnL/5iYh6HcwJZLyrCfU1OsYGq86nIZU2uV2MnGf4itmlH qvrFBqyxYyzK
Esmwq2cssMm536wn7v3FeScz31PLZ1b4aScUrmenPBPPmB1bdL38qOHcKuQ/ GcUqzhZ6Dvp0
paJrBMLRFTA7u+hN2uX1YAJCyXXC6YVaVO5qo7K62vkVMMnTARcW6kzpB/3p 3DxSYrJi4glz
cQZJSilO9RkzgYZSbDap6VfMRJrw7hOmGSYze7VJ/f2nj1ktnAXzGftSTkhV qVhouL34hEV5
h+6Yp4zKUjP96eIN7bpwgXvErGaLEy8FoYfuRmcOd2ryySnT3cUeSiOaapB7 AmKCT8BMnEBS
UIp7e8ZCN9q7T5j1Bt1AzvuTiT8BC+9uXzhfsVAXe/cJMxkoYEMziS6+aDpI QfiC6BiMarOH
T5CDAkYzEQWtKKx8HShON4ltK88oC2FCDzoH7F0shTou0hD6YI42IlVG5ryL PEQ5LhdxuyIQ
BcQkooCJSATkiH4XmYi3JtnoRfAuqgXLnmgU+q/RIlWDk+VFLgJGmS5MMApI 82SjjbPPBTmo
UHDBGHessSAyPJcoeXAH6Yg3ijkjVej9kHIUkW2k0jIBicYEefWDhBSwohlF C9+gHGQkqlud
F6p7+fzVwT5JsiH4T5/rCM+tq3yD+ZGDZCO4v9MPE2iP91UBi0Sa5K0dqDYn fo9HjmN+5FDS
vBnkJSCTB8WPHEp5Unuksrr6keNYlJlo6EhqoieSlgrnidOn35GbwAWQ4EQ8 cxCcuPTyMy79
d4SnWUR6ou/cpCeJDsQTma7K9em78EChElmnRelJAgTpmrwkMlN4+i5CUKik xBGlJ47Po6fH
Ov5imGB36Ynj7Yo8sfQk4YHXp0uk4F9Xl5+Ni9YjWz2yRglSPeatHjJuq2vE IJ74QIeXtD/9
LGhw9d+JGiSHepok9MRrue/49G3cYEGun2reJ/7TnVZwgYdE/Txh5rWDG1Q2 m6SfMPPboStT
1qzfYOa5E959wMSUjAs52I+T628/3XyO6zIkAugB+1KO+/QEzBvuhT1hwa0H cuP5/7Ka6U/3
4oHwkZHG9xGzmiFOe5To2wPpY48a/HuBdORyDd49wEj5aO49AVl+PYph5jUD eafN/R0WutHe
fcKq35EiVz4FL5+AhXeXOis+YaEu9u4TZq4+Adt6DcpiPjI4+wATh45A1cYM jtciSRNWk1Qr
lei183WgXnJzxay5RY8fyEtzRFd3IAk3S4V37UKNQJWg7u7R5weCdWMnEnH6 CYh5/QRM3H5Q
1vniiH4/wOh2G3PpIQm2tRwdf6j2aaRIdeZ2FV8s5dSKpBgzx5+AmOMPY+ni 5Wr3j9ww4vLM
qQe1sBhT5dRK8YBVoQq975wavtDJIch8f6hVyE8UfH8CJm496I/BjsPm+0P3 nEyJrRGqe/kv
EYop+7RsCPYzzHUK2J37G6y7cmCwmd78enBPB4UpBu8furuDHQcDFaW/C94/ AeuuHFgcpmDr
C1da7DSCb92La7FrjlRWV/P+cUw3NL2rIgRE4uILDkrUaEeIv+zI7CGRdD/H biFMEhL+no0d
9SQoEljirVCiIgNiYZEBk7hIKovjfywwEl+ki5Qt6pHqlWp35EW1nxphK1SN GecQHBkwi47E
m43WuIY+cvkrxOG+SGUgLv1GhehY2YxVeYZOaRrlQCo2RyxGMmASJMm3nnR2 9JcoSXyxlx1C
IFGvOSPC7S67pEgFV4QZAuuYSjCLiwxzIMRKQhkwK+94NCn0Z1gNVTfZR8xX CGUJiP7aLPGP
dlkhUMOmsq9Ug92qfYU45iuk7ps3HN+40cKaeVEtKnJ6Byqrq6+Q6gcH9wOE W4r8Dkc+ye01
nhmQ28lLFLudJH9utncuNYyH3VSzFDsmMTNclsY/SOJm+uKKXdgkSU7swiML 51QuVMilXee1
rK6RVfbF7rFWmoXZsSV5oKmsLPu+JIImvcC89MS9v17ai1midjUXdGsaEaxH vSOhHoaJI31o
uXnbs4SeR6QyJPS1YfbFe71eco1GWRaW6z89RgIyNSXMDw2X2wcj24AkUlA6 B6qpUbcbpxdT
SQJWWqhIRBmQxdmdL1Qtag7WvPrMB0xCdG8YnaKobWrCjaWWSLNO4eAS4kZ3 qtN1HpxTQBDW
Jsg6VSrvn/PFypPMMa8ZMoO18Q2m661XjlzLyN6kd2MoFl/EtcFX59yA+eaj d2T4muiHCUo7
v8WV0wcnOAtUULcqdyF5uRErzGtCosACAgPObFcqGTwgtUmgh+bm7kOiJW1q dMnPFScQao+s
GYHK2uhMs2HaZ9yTRrlMjII/4FyB5cZXey+38uRi20BlyLQs3Y7phkotWMEF metGblmByuo1
PFN30BmQJzI9sR4Woqg//Y4v8izijEyaguCMzKX3n+kmfschGd9h3onKdY/k SrYFzgDURSPV
rk/fWNyVXjQ85kVcYYaSZGpD7Ozt+vSNxV3pucSavMQqVm56eqzjL1rcB+uM EF/M9upW1aeX
nqak5YtPF4v7X1eX78Yl1qNaParY2bke7VYPGbemb1ZzT64jxaefWNxr+y2L ex1qcacnUoqC
KwxP31rcK6Kwq7kB+k83XtUxOKj3gk1OvmwYkJkb2/YK4qORuQmM22Kz1wAX HpDDlI5+o6qc
lRBfpEw2pF6HqAgqsGRpiJIYnxPrMv/sHEyONyg5MbDGmRmeMZ7kFyIyan9S YWWlgPH3SOVj
WEDEl+AVqcTAibJYilDkFb+ZQgbl2fiirWAGqrNy4JEZeOrEHW5XM1CFM2mL PsN1Jg4FDmYg
dCBlOTAzUEDMDBQwMQOhrJ6vZiB8ka6XMgMP6pXVW1STqp7a5xbNQECOsHQx A1G7dzQDBcTM
QIzlFk0+qNlqVzMQapbYxCYGHtRssA+AmYGoX9UHQKhC73t6Vbo5JF385Ojd cjUDBUwMPNQf
UNcGMxDVDTxfoLqXz1/tuGdETSqFVvbsHJRHV7/xZn2YanUuX6zcrLgvpJLJ cem184fT5nis
QGUIco/QxfMB66zPQvlL7jfAjITYj/IpttmQF9WCUrwHqs7hCXy9XOPyO4u9 JBdsJFFzpHEW
yQsVMq2eLRKlkzKNZx/nZEfQbxa7MOevRCRszRfbFmpP2UwClbXRPMUDZva0 uhJncHrGwO9w
/ziGq/Y2UkHC15VdYTnrEX+Bsp7TyMHFEIiYNJfldINT8qIWgJ/ui8eSHIYU kZYX8iMwqvtc
4RkURjPzdQmX1ouqnvtIHDo5fS35L8997SPb1YwKSRjE2rlq03lAd6ywp9DM bwFB/ug71WAl
F7VzifcNIdwbdJlaoLq3iNq5OmdJjXsmDC48R3U3XI0nftwz4d3bOcxFqWCi zOOyZ64sN67Z
numI75mO6Z65kP+jzsueSZ6yPeyQqANd0Rb3zNXUOd2ooKtf6bJnLsSLiC86 75mO+J65bB36
/nhqIbPqgi32kNfdcDVWaMQ9k3ydW4tUofd9z1y23/qeucxlxfdMx3Q3XMaL +J6JurEfi1Hd
y+evTnVzpiN87XP0SLRLGYm2S5CsffHgqmtp7EbANqux6AOwSx9sZ74qItLt wuLuBUP6RAk0
oVRkTFe5vKlFVfMQxtfOdOZDjDKVca1IK2JcykY6R9rxkGx+0YngWPj8Eff6 /A4z74C6+82R
ulLMc7qE9ZwNjA15gQqaabHxi1BbOehY5iKE2oA0FWoD1lmoRel7aLQBC7XA aksheAD1oqwk
ce2i9qtcqKyN5rMTMOkz7klDuwq1KI+Wgr2Nr+ZZb+VNvgg3UBnSVKgNmHg8 UAtqCp4S3ALK
IhaorF7VhdrDG56FldR3zX86J94SNGhrPGPOYLaUOaz5GbMjoSWw3Bqu8AUz P7vw7hPG87ZR
ZHPOVn/7adOzUShyTd9gX8ox3zvHYsP1xScs+t6dScbshNZMf7qfXcMlNBRs 8oRpzXK5+dl9
EpZ2PIEaridZcraIRRdYmZn3U7LoBsR87wJmfmwtg7uf32Hejf7uE2a9gfqS fj/43gUsvFud
o/qKhbrYu0+Y+d4FTFYUSss1X9YdMLq3/ULVt8bBsEU3YFOqdT3evw4UJ8Bd fCdTYCDONNCQ
R3sXRs4YmoQPgjMpJVLBZChMizAQDS7JvUxnIAJiDETAhIGgslLrkYEAtnoU p1AHUssGBoJq
X+uOVLChrxUZCGr3EgaFGIiAGANB2JQwZWEWUIteW75jZFk21gC1qBzGagwE MMqAF6hC7xsD
QV+YKzALPCY7jx0ZiIAJa0D9ATVdYCCobixCG9W9fPoqLL+tqptz+OlzvWTR xz5idro2cgCY
QfJoyKw5RnDtRsLZipxt7UrF98C5713AzPcOGFmnbH0BSTwodsagFhRtHqis ruZ7F7Doe0er
knzv6Ik87kh75k+/4XtH+jHyvSPtWfC949LLz/R1v+F7R98h3zv6TvC9oywp nI0dT5Ruk7LU
+lP0vTv7I2s955vSi9azRD0q+97REymJGmyI/hR97y4lMr2U2KIelf3d6Omx jr/oezddj8qe
a61pant6Gqo9DU8X37u/ri4/Gxetx7R6nKfRrB7tVg8dN32Tnlj32FN8+onv Hd2z8RsZ+5F7
jicJpaWs2lR/+j5nfxeOOibt7+2cjTmFXOq4RHKpu4QkU3fMsqnjTTGEaPr2 Dh61h+TpeHOg
m3ukgnS9JTuO3FDSRVa3lOoXRHKqB0ySqgPpe3CaTcmqDqx2yX5LadVrl+01 5FWvlId4Sv5b
TqyOFok9TzOrd8r/Kb4q2/pCkldrbnVHPLm6Y5pdnUxChZNVS3p16sO6Qu50 1Guoi55eZIBW
5jQjFbKKiruHpFgPmOVYx5uW453T+aMvanQA0b4oOVI1SX3nedaB9bTYBZMS rQfEMq1fMEq1
Tm0cRZLBcq51fDHloYZHqObR7p3Y0CbZ1qn2SZ05Od06WklRKpZvHUjPmn+S E65XSo0x2TBO
1vCAWJrkgEnOdSp9Z3bykqTrNF/3uKyQ+zoi6b5L8A8b1P2n227rQLzu1aXR MTEOhxfNMzRg
xc0bVtgTFjxDK26Dp1nGNbOfsRZQ4l8N7wEzSzPZXkbMUwjjQRr94uYCbPZ6 oRqePVBv78G9
7VPTp/XGVIIMu7/HMOofFD1yqV9+qnvLBetyhw+l7NBU/nKJDwwonMqryw09 o7FZwZAXt3fl
FqmsV4Zd5GOYjiFyorK/bDbt+EAso7hcqnYcqVs5+1RWvTf0tXDfUIR18otn llEpgvTje48L
FfZQ1Y5nTaK/Ve8N7a+kFFft+BBFlFMN0YSQm5toxwccUCXReINKMCDTtOOO DdGOIxetJY4U
7fgQEdUnyKlXzbteptGpvax/o7I2dtf8GuZTdxbOOvyMLdOOO4ZMiZttIuSy glEy7fjZdnvn
9S7a8cLefzQiqh2HtRAtqEX13okPIEOk5ZTr0qi+zBXWjofRNO14aL1px5EV r4RM3/hqG/2S
+5ssZkkzFBMVZl6Rk02142PzLWh8rwy0445M0447prsm2jl7dUSsbznVSHVv 0UssimNu2zXt
p3uow3wwWu7PmK44unR8shePadkT3w5ojiXQ0HM/uPsJ2xf2ilQQrsVXSbXs B6PsF+b2HBBz
ew7YUMskYpw0R6paJhfvd+bQjHrRnZrB7Zlqz45cSnWQ3fXUVC07Un/LBiVa dkOma9mzpoie
boVcrMe4YZLJeqvNEU6qJbg4c836qiEv4qX3g2VyabjBcC174sxOwe05YF1t jrovutsz1S2V
Ganu5bOWHfqJok6d/jMck1Dra5ZcwyDwr3DEApF8u5XvE3+Rfl4ujsF9LbjE 2BEEPfOG4RhS
ayU2fRzGkx2V22xqrNhjcRJKyrRGJo1VkiNsbKEUL4Z9BMxmvxENDjP9JIzy 9xjGDadbHg2j
SnTZncmwwZab1iUCgjKVBqRxWq8LVWM+nuw7IzP3QfHN3MgxE3Og7G2wRIsc bnAI9Q9XOMDE
MGDB15HUn2FTh2WCLzp4wpxv2cmvsRIzAfJs5osDO7DGWbkDVd9LDhe5f9ox c88FVtsOzrhA
ct/BWf3FtWgjOPGGupp7rmM6uruJw7S758KyMvaKe9uGZ8qWYA254BhmnZbE wZVuOHbEXEYD
Js6yVFaRPJt6OTFsOZyj1joHjnYpX7sQKsd5oaJoqnIta7KaNHzREHOLDZi4 53JZcl2aXna8
RckZeuLeXy/txS6SqN53DLvHxVUwIKEehunp6S33M3ZXzQNrVIaEvq4hWyx/ 8V4vru0Sl0J3
EXUsTPa9lWl9wmwBwCwjK1/GBYaQUeflIo+Wit7VZFTwj5H9QaxpZGrZ4u5I 1rSAmItowMRF
FEjiID5zEcUXW4vzGPVqNSaSfnHtrye5t3G79Uux6CIaKJfbZcQSYW/jq8Uc v0Wrnwrv6IHK
EHMRDZgsam7BDE6j3ILBp61tEFavEa1pyOwr8WKq7E8rXPPFfYT7Qta89tGQ ACWn6uwVFfgY
mN0mX4UmfExAjI8JmPAxZMkqen2MKPvPF9PKgY9BvZJeDajK/lP71GOQF5DD P7TIx6Dd+TTc
+ZiAGB/DWL3wMajZ7GveMTlahUNBzUigD3wM6lHS3pEq9L4r+xPyv5QLH0Nj wkyp8TEBEw6F
+qOuEND14rqVPSLVvXw2MSQJh6hs8UkeHREMZex6/4j54s9Fb7/RZQ2DFZy6 4uKHeeqydZPh
bKumQJT9jtnpB6xxeJguAUSf8qD4EkAtWh+Ryupqp59jcvrBYMJ8hp9+ZDC5 OJYDEc3Hdusl
AqDExVusl4Yst14a1t0S2Dj96jMWOtvefcKqWy87p6gN8agBC+9ODo54xkJd 7N0nbLn10jDd
wTIuo9gXV3hgdGtOoJp830qIR3WMBoYKomsffQjuA6XWy51WjgfZqfGZy7Nb UZNVhZdWL700
w7FicuaCq24T29ba4zoCUIrerrjDJzkgIp4NsEmRf4qsMfvpckErYqt8xoxd bedbq4hk8BUz
gR3v1i63nn3FLPI8vPuA6dog9cywPcJ+hoZT/N1qz9iXclznGDBvuBf2hAWd Y6tiX5Sa2U+X
4VuFQXCnZ0xrVsVzM67+2jmS0KceLnTXk05XP1zTkwTs8up3xFe/Y76ScPV7 K/MbLHSjvfuE
+eqvdhr56ncsvDtZjf6MhbrYu0+Yr/4aT0Fa1xUhQPPK5SDTkd46KFR0RV26 rH7DeMnWYSn2
dQjuA0WrvxlD6ewMLMcivcq7lMVntws7U32P0C/gzkW5+k3ZGYRdLrmgjNkZ R5ydcUzZmYo7
yPa+sDOUIy+HCyZQL2ETnZ1pquZzKrjSiB5b2RlY2vPW+w/Bzjji7Axh7RJ5 jlrIlVsXTFIh
KKNCadp1yxZ2BvGTJUWmJ/a+szNVVZCBnaH4ANGjKzvjmDIq5Ja1wt0U3Gut Cb/BVF/K55nQ
cE2wqmX8Z5jrrYu+9BFzduZgfFeTMSqIG0z5oj1udMvrXJEKPb8vsbYBc3am meJHGRW4RI2Y
n+LFteD4XqOyujo7Y9jlLgo6PCRmCpdFkNgGq5Y/xZipLzbjjaez4n5iM67D bcZYpyRB4knu
ISjxqUZD+dVmvMTgg0z9Ioc6Vkzm7PgztNiPWHUDkur6MDfZNJQlGlmRF5mo yAM4UNE95IPK
Uq9OpD7vVI8qXp2OIC3w7FeqIV6dA1mTN0XcmVfnKHKVcFsiYeJSRZg5DHlx 7WkBGJW3cZoc
6tgOcqijw+x6yG4Pnxt7G1+l/HSxPKTXp9uancqQbl6djlWRMKkFVHo1FRS+ SHZWo/J6NZdD
yTxGyTPa0nAj/unDOwanO3jGwpAPyWrhgykO/JchV8ORUy25NE/TtzGVYNV0 bwizqteGT9ZS
Xho+5EIzp7K6NtO9OcYuG7BaUKpwG/FPirjh/Ds+V7Zc996m6d5w4WShoobo 3hzppg9yrIkm
jMpavGpUX4YvgkPyzpmqcQ9dCNsVRTI7FdJpUk1DWVXSTtgXHemm83JsiO6N ygIH1Kbp3qYe
atYTX/pLrVmsEdEZ/EnvUlZDn9WOhHoYVtW+ZS2v0b7F94YalSOhrw2zL97r pbFNrG0Ke55j
PtmnCjyPmC+AiZOo7DguS3I3xNEDv53jzniQSWluwp6HeJ5F9dA9zxHf8xzT PQ/xPH3Oy56H
q/jqZR7jGkLSIYc9D7Un1t2prI2+RzkW9zxHfc+DjYyyH/konO2ArniN5W25 GtapDPE9zzFd
1NO2EV/6FBu0ZqSyesU9z2wVSCUAZRdbUWaiNaWtR4J5ZLiPfUQJ5euMVAWa qs3190gdumSH
RkUjdQTpMVJHsOaROikPmd0eqcNaR8wWjdQZyPNqCNtVRus9Up1JMmX/Nxsi WCvI1RSESjZE
Q3qM1JGTA5wSm2GXqnSuGFvL0XKN1Ml8wk+3ISL98ViRKvT+JVKHL1VrzW2I TdJGKfYRseqR
OhQ3Zgj3GvsKOdW9fI3UYamLTz//6QsdUTmU9PAR88WPmxrJrmjLeiGH0OyX xb8h5Fy27m2H
jJ9+jvnpdzAKUfLJjdggHhRfAmtJnj2nsrr66eeYnH5bxfFw+sFaRBeA21zf qoNBKhCZLTCl
8fkxWfoOyFDpO2BVJVk0aMGX/hnzzvZ3n7Cs0jfqyxYGyDMsfQcsvFvZEeIZ C3Wxd5+wodJ3
wHQH27J84z63VekaqRbSrhLC0nfAllSLjUg+BPeBYiOSOmSGg2yre6QU1cQT J7YaR+Ydg+ag
CD/AujfYo9qqtxGAEiH3+7vCh4azAdagmYtymOGn6Mw5RmjM9h227uVUdjS6 FGa1CC8+YfLu
h9hgyE1Ua2Y/kym9cmXXsmcsmwYwJw6Ye8YqhxaIBh382TMmKYcv7z5hk++9 ZyV0LjV9gy3T
rE++X3CpPzA0xpvHVDDSZ3eZj+IPHLCh/sAUbDIzz3fy9G2as94Q1iK3IcMs VFCmZi5f/IGh
/WWHuiZa5gsi/sAB6+wPTOEWfckZxf7Arl1WURwIHTDoxMMwaagMq3WwHbI/ MPpiNNrXGvsD
U8jLWMx7ij8w9QWfIJX9gQNS1B84YBKIi7JkcWb1B0Yt2FsamhZ4+lJdyYKk iITPzJoi1Tlk
ElQ/BxF/4IBl9QfGm5QGAhjtU1Q+WewU0b6gLcKoTCzK6g9MtoWZebqTP3BA ivoDXzAaBmpj
kX1W/IGBsYWdON3KFohEKXuwMtkfGNhh/IVPYX9gtJJuy8AYkT+wBQQBEX9g aP8Lud8gsh9O
VQEZ6g8cMOl0Kr033p3FH5h6v6/LCrmvIw7WUaObn50UycKzTDAg7CbiZyfs HGe/SX52BsTO
zoDZOQSMU7Q9Yr7v+btPmJ2dqJ20zM7OgIV3q6RIe8RCXezdJ8zOzoDJqYje ZPutn53AKKVB
oIKHQS3x7AzYEuPQKGvHIbgPFA9fQ07NrIeA/wwthOKvfIcZCwhsr6jNgsEn zXLReQETKSVQ
kaAdWMCAVY+1krhy69VG+TpT4Kvw5oD6vEYqq6uxgAGTQ6LQNXDJ+sF+hjZv fv0Z+1JOdhOT
YX6K+otPWI4mJnUU4Zr5T69FPUNLCTwfMR+hilDMqIOEvYdviA4jVCUnTqBC oOhiaUrc2oGx
oR79jM0jIE3d2gO2xLy0hKm+/mzq1h4w4TOADIp9Iu4lD6ljI901jXLKREWH lyEvbu/sK1JZ
rzR1aw+YjGGl44MVI+LWDmxOZk3VrR3WFb7MuW12WCcrQRYWUNzaYV9IPPpK 5chUt/aADXVr
JztEkoVPikSymmwRt8WtHbWoLa9IderKapGpbu3AZNkN1vcGpKtbe8Aae6AA WTr04taOL7a9
UpwgSKFYL4qeRtkwS9wOvI2m0gqYT11Ymlg1+IQNdWsP2GS3dpS25iauX93a yV7UE8sM5NYO
5EgSnUeE3dpRW84D2hM7rNNYsrEiqVs7Ws7HsFPd5wpbgcJoilv7pfVqEac+ msV7pFFS1JQv
fVSp4jlSSUId4qPZrZ2sf5RTGtHMcGsPSFe39oDp4V/VKVsR7o2aWsC+tuj1 4xKhSJn+6KnT
XoaT2J9+I9OfRhdKhGLI9Mela4TqYyRk/70I1cz7M77TPUK1IbcNXziNJ2L7 Kb+ZP0Wr1VlL
mpdP6cU0ZZn+EEfAmf7oiXaPQRdr21PM9HcpcYVMfy15iV2y69HTYx1/MdPf 4ghVuiiS8uSN
tCQnHj1Rfj/6qz9dMv39dXX5blxiPabVY0p+P65Hu9VDx03fpCcy+/Vc4tNP Mv01ONj+eqa/
jsQNNEnoiUKwqan+9JOLyafmfLG79frhrgfHiAvWITlxnrGhEmnAukqkeJMi VO3ONJRPMle4
Ra0jG3+SnClCtThClUL+WSIFJtmkOkukF0Qk0oA1lkiBUIQq3eHDEmmnZAdN Ev9AIkW9JAFA
1QjVTgkdJmMikaJFFKFKaQhxqKPdFKFKsffb+oJiT4GRRBqQrBJpwBJLpCid IlSBiERKfUj3
3ugNgqgXRaiGewaplTnNSLU5GhWISKSOQUpliRRvli13ahH3T31RJUmjSKTc FyVHqsERqpYP
hOtKsad0KxQk0oBklUgvGEmk1MYhF0uLRIovpqx3xoINpXbvxIkbRCKl2ifJ RCYSKVqZW+fc
eySRApF8iJBb55a+oNhTSlEBiTQgcjvkhUpyjFHpW7KPiERK83WPywq5ryMc Sqd+ej0ddtzw
01JFdJKFdv8G4604vGiZbhzzrDb+4hMWM910XAWotyt9xp+hFp2VPc+YJbYA JlekS8qKDmEr
jZCK73QZooBnLpFqsVnRygIVhjINz1PSKxKHthqzmQDbdsEvU2VN5nYm1KLr IYHJZlQOa3Nk
s4BUTpF/oUJfo+jZSv76UxIwXTBYMjDpD5I0cRMh3JKiFxUzlbcXzru9Sq8I Rp8jD6RUvv70
rzuGcs+p2OH00+d0BOVi9l6pbOTC1w2TeYZLGvjuQcsoFjCfBhVb68jfYD41 qgTs+6DjNsCk
qV5laoDV19tQhQp3QeuV0myH7RAuhuR8IztsQCyjWMAkoxjKmk0z+LEdFliG Fd3S9KBeJGWE
ZD5U+5EvVNZGy0QUsJBRLKCWUQzlUWPsbSC0iV3Km3qzrVEZYhnFAiZ5XLgF K+RX4hZYdnuh
snqFjGIdR8ZYmpHLf3qOq44TpMr9CV8wnT/YInkntsRJHZesTt0ZqRehJpRZ bn3dql3QqVTQ
Iq1L5sWO2cytlsRJAbHESQGTxEmdFJ/pknmxN3EN9U0EGn66/jdsNai95Qtl Ktx+1C+ZF6nd
Y4fMiwGxxEmM9UvmxU5uIqncMcm6JymRUIs8U8hMyzWbmilMqELvmz2XvjDa JfMivZvqJfNi
wCQlUqdLEHfITMu9RolaA9W9fP4qYkeTZlLzn+FgQjJ/yvAcscw37RjWe2Fn Z8ogzTGhwCgY
gVgRxIQGJGtMaMAKx4Si9F3lNvs2SRsBLPcpm0hZaBA+nZojaDY8LEd17CNi OvsNqBoTSoVx
DtqqMaFo+Jm73TGqRJO7SiUmFJikgCwcExqQrDGhF4w45053H2xO6Scxofii pNSSNH+o124j
ZJu+NDJkoO6U8UWy+56qwUejI6cJ5wDW1YqE/GWE7Hb4auMbWgIVdASF5YOZ eL/rCIxZkvEO
DgoBQfKIsa9UjS9qRulnJBipMGfxF8lSQFw9Qr1Qe0kQLsiLWkSaZcM+rlhB Mt0LJhlu0e6u
GVZFJYJvnvPlQlX15ujCS5TrL1jmhK8fXNsSr3bu3fZKPx27ZL0IVOPwODLZ 90pcPox7clMK
H/iOSIsuVJ09wj8ihuaeDQDIzpL5khB+kzTqgWrxzWuE1MrlL8+QSU5kXL7k 47ZZMC3/o88V
8VwOVPd595LZKGOCEC6Weh0Tzp7HjuKbCSuZawIntxEwGgHm2uHMwrt0h84q cU7ChHTDF4SE
rhsVDSyQoZlwVYb18iUnYe/GclmWQmCL90qjureS2j4O2zvz5UZnYGevLLHf ts4qyyoJrOUV
bnQOiGWVDJhlaMSITvh7PWPO/fm7T5hJHqgvTc+QVTJg/u7IHIzwjHld/N0n zLJKBky5qoGc
l/tyozMwUkBeqGar1/FybEq1yl4h8ezXgeLhQ36mvK/DB59Cyj5s71Y2WMbh g/t03zkMnyM+
fI6FriiqfnnCQtfau09YGL6m6QPD8BkW3sVGOec3WKiLvfuEheEzzAams+Pk Zfg6h5deqJpu
WzZ8hk2pFjnyhCG4DxQN34TYN7kKytuOzeaN8O6+ZXnFB20/NSpSEsisEt52 DA7rcN7WEedt
HVPedsCfoIioJ7wtuWO3yLWOxVGIkbdF7UuOwjblz1EdjPC2aLfmmmXe1hHn bYENyduvfOyY
vM3esGG5XIlrxRUeswQ+lmtG/hZOFXvfeVt8YUjuSuVth9w5GHlbx5RrRX+k yMdyr8mtHEZ1
L59nQuFjRnhb/+lzHa7bu/ZvMBeQ4fQ9WtCUnHHArYVXFmAGTYxR1ZElES8b qgNmSUGB5SyT
gwXACUYthw0TbzZYr6KY6HW1pKABE34XdzwUSqzK/WA/Q5uRLLzXb7DQD7AF zcgKzc0RmrEf
cJFCvTBMSNnTNrdPzMHAhNktnPUnIBW6vHqlol0AeYr2bF9/SvsvWGFzMJAz c0XlweZgYIfd
1r5MmagoRZEhL27vGD1SWa9UNQcHTHp84WLWZHK6/QwS1Arq4y+YM/aHS9ZL I54wy/KNd4sy
AF8xy/Id3n3CtP5L72Hh+uvPWFckBCjpGdNyth+wKMd+Bt3EhqxX+zNm5Uge vHgkI+d6iYc3
ELrjMR7Ju3L8mx/JjviR7JgfbxtX6c7yDebLxN99wvxIRjaTIfdA6pHsWHh3 qFz4hIW62LtP
mB/JjulhuztfKxeP5H3XcNE3eVL4kewYzRsUxPcq2BDcBwob8UDajyUsnBzJ IyW9JMTe3Zr7
2o/kjcxGJR76uHiglHo5kjeO6TLCkeyIH8mO6ZG84WCp+mA5ksl1dwQ9NuoF +2M8klF7Sk1n
GJDDXM54JKPd5ONgR3JA7EgmjHd1P363ZIK7YXW2cNjimym3cF0S10yy/RtV 6H0/krcZaOxI
pjFpIxyjHxHTw3YjrlUSxOuRjLpVVQQz1b18nglVBc9JH7SfNtfPKfmea5/f YHYUAZspHkUD
+U70Tg05ioDxnddOZRpkO5IDZkcy3lw93vIAZPCg2JFMtehpRyqrqx3JAYt5 usn2TXm66Ymy
KJMZ2J9+I0+3WrDFCh7ydHPp5WfW9t/I003fGVW/E/J0w/r9ef5lR3ZatvYU 28GG7e/Kl+v1
UPxbpvuI/3DpKPTzB5r454vXUqX87uXT3dUds56eyCGhIGjIn3pw6BC7v5by +QPK50yrIcMV
VZ70G3aF5m995Zda80tf/5N9SNdF0AygwJbQhwXO8NQ6euI2wd3bnx76UEtB eUvqTolk5Vb3
cuvD3/vKr7Tm177+Z+fhltTrLCb4NISDxiC8vNEOj8QI9tDHwxSkAjAH+hvd lY5stPIgZdv0
++XSf6UB//ZX/+i0Q1QfdRmeQpfBJZ8ahQdyHDvnuz/8RqPKoR3tb/uFKt12 To7hjnCYcSvT
lB5vG7wnjiJ7WPnLF2TtwKsCzhRr8vH26dDmqbzYJHL9peSAJifUeoKGnvD+ 4iOURmkX6Jyn
sB6hLuRDo8DrrKjEPkRGc4ANZSFdJEfeKQ7BoSQtWoiJr+ZeTS51RF4kZCNT 4EUtp1SBkeYI
FVROzlNpuMO6XOsZAMqdEWm8sSWxj/YTZB33lwMiN+Ea6O5P/xXfgkd86k/Q Ltcylpm8HWoq
zHlBD1B3D5WCJCLlFC01kl+rqTRXSmf34QfIarT51r9dVLwruN1gUrFy9TVS S40zfDurcAeo
HaHzje53w6lhQFLRzqAw/eCIAd/WJyj0mr74AFn7Uc1WzgxCjC4LdQ6FF6HX muMRCpXQF79C
O6k851CW27kpZyTWY7YrvCks4MzvSDNXpc4TWc4hrQ7Z4r27b0MC9p1cHSEM IK6Vw8ALnOjB
V9uLtXKco79YKu7a2zPQIOvypoETGa6Qt87hMjB0gy5gFmBtleAcWizAoZy6 T4EIQ2b5rVD2
8ErDRoIZ6kMOgQq8uM4lt0CDjMCDdjmR3aip8IM6EAsQBmyV3AgaeG2rkIYa kVbiCm3oHdHY
RQ6n8NQ501UBrtFhCFag8Z42mY0KhwPOWiqy0YsQYhT6CNCUa3LRAyltA15U Et2S5TS3ovl7
g43ivLT1V5jEcGWHOPYETZXUChzIEZ+A7l7imnKWTzcAFZL+ijQDTj0omqU0 h6YKafRa5gnA
18tDi0T9P+0OergawZXJabSKS4N7DNINCWIsrgQOGxJJ+qn6JIYeB6ZLLAYO hnAIjm+Jzm97
TZciioY7RViukGqRoCDSbLibIVUyonBBA9XT4d9RtBnABaAkKleabNe6QU2x NhvjX1SfjRiL
Bf3nYgZAvDOgvmtqNCJgcR6UV6BBlFVnZUg+axjjsyeFAJBALacRjyE+f6Z+ HGdynJgt0FQ2
Hy/T2ZHGYGcqesIJ+CNAZ+gbKTeppMVr1nynyP9CAa5RX7zTC40D5JsWaRZn VqcBWqdFWAqJ
Uo2TgwAyJSFZQGpaow6/U2wHdQRXBiSpTo1fQ1QT9/WeovUhAJtc6TXS4Awr lbVT5CmyEQ5b
dOzTipvzfXp6ZMU5Wt8GH+mHb55U0+YPI0ZVXBg9eHTWw6/gKm32L8dJkxAp oVChxHFnk8DV
4HDpeNHBOei1Ijc9GwBDbl6RBvddoEVUTj18BBmZuIn4FnQJuNSEbDuoD5Qt CvD2T+GIRkO3
TsxLOTXzQrZvKYD6IMQl0OCuCvKM0HLoyvOa4re87bf+eQnfkuEhNBHQtmib qIk/rJADiZ2I
Xk4zJl9C4o0VgPkWiupxGgFixyqk37rXh3dxeBCegZ4kedgvhIjWLQcGuWA+ QRyFgb2fNhIp
Q3+FFyb70T1BzfbUiYuoYfRMg/fUwor+sTiejvdLig2E4Y+vYyMI2RrpvhS5 bNSAVnUVKyTK
SXgaTyqn4oKyl1SBfGqR7yitIts62ZfQrZVS0bGL1plfsBEXZo9QGiLmxEe2 1UaVJqMyl5zY
h0qL+eTjCmmL9GOy0yIRkb7K0ISvqJSckH5NP8zDh+xHZ7FpH33KqVeT9aQU g2HV5uq2fr6L
LtHgAgWs2wI05JpV8svT7tfG0d6MfGWTwnaoE0pbBnEfUTzAWOxRzRAlJQNU xFiahtAU8peh
kISWW6CBxY8nRVFW5B9NTsbVKSwo8xV9hbLS2lP6doOj6+ayCN988Rz2MmAf jCVqhtB9/H9+
9XsJ/ffr8acVoKTlgBzrKog/VjjlUsl/i8JzLD2qtKDzIKXTeaB5l8fyhyeV FheAkobolM4O
yw9atqm0frn0X6n/v/3VP9ljHGYkd57IdZESGDn5AsdPfiL9D9zTwtNoX/pN S0GyHOhD5WYc
fbJvWJjnb33lV1rza1//o32IFBR8ieXOf35SS6FnNyAJ5Q+XLoVy6VHhSE4z wKfMZRw79vCw
ZKSA88apMM1ZyDn8oGXbhvnLpf9K/f/tr/7JHuukDiCXcGSg+eMGIi2VEgr9 DcrXUqX8sOTp
HhtajPRESxCKjfD0sOS1FErRIkutIf/IlERAtyX/e1/5pdb80tfRxv8HxskR ZAplbmRzdHJl
YW0KZW5kb2JqCjUgMCBvYmoKPDwgL1R5cGUgL1BhZ2UKL1BhcmVudCAxIDAg UgovTWVkaWFC
b3ggWyAwIDAgNDY1IDIxNSBdCi9SZXNvdXJjZXMgMyAwIFIKL0NvbnRlbnRz IDEwNCAwIFIK
Pj4KZW5kb2JqCjEwNSAwIG9iagoyMTk2MAplbmRvYmoKMSAwIG9iago8PCAv VHlwZSAvUGFn
ZXMKL0NvdW50IDEKL0tpZHMgWzUgMCBSIF0gPj4KZW5kb2JqCjIgMCBvYmoK PDwgL1R5cGUg
L0NhdGFsb2cKL1BhZ2VzIDEgMCBSCj4+CmVuZG9iagozIDAgb2JqCjw8Ci9T aGFkaW5nIDw8
CiAgL1NoMiAzNCAwIFIgICAvU2g2IDc4IDAgUiAgIC9TaDggMTAyIDAgUiAg IC9TaDQgNTgg
MCBSICAgL1NoMSAxNiAwIFIgICAvU2g1IDY4IDAgUiAgIC9TaDMgNDggMCBS ICAgL1NoNyA4
OCAwIFIgPj4KL1BhdHRlcm4gPDwKICAvUGE3IDg5IDAgUiAgIC9QYTMgNDkg MCBSICAgL1Bh
NiA3OSAwIFIgICAvUGE0IDU5IDAgUiAgIC9QYTEgMTcgMCBSICAgL1BhNSA2 OSAwIFIgICAv
UGEyIDM1IDAgUiAgIC9QYTggMTAzIDAgUiA+PgovUHJvY1NldCBbIC9QREYg L0ltYWdlQiAv
SW1hZ2VDIC9UZXh0IF0KL1hPYmplY3QgPDwKICAvSW0yMSA1NCAwIFIKICAv SW0zOCA5NiAw
IFIKICAvSW0zNiA5MiAwIFIKICAvSW0zMyA4NCAwIFIKICAvSW01IDE4IDAg UgogIC9JbTkg
MjYgMCBSCiAgL0ltMTMgMzYgMCBSCiAgL0ltMjkgNzQgMCBSCiAgL0ltMyAx MCAwIFIKICAv
SW0xOCA0NiAwIFIKICAvSW0yNCA2MiAwIFIKICAvSW0yMyA2MCAwIFIKICAv SW0yMCA1MiAw
IFIKICAvSW03IDIyIDAgUgogIC9JbTIyIDU2IDAgUgogIC9JbTIgOCAwIFIK ICAvSW0zMiA4
MiAwIFIKICAvSW0xMSAzMCAwIFIKICAvSW04IDI0IDAgUgogIC9JbTEgNiAw IFIKICAvSW0x
NiA0MiAwIFIKICAvSW0yOCA3MiAwIFIKICAvSW0zMSA4MCAwIFIKICAvSW0y NyA3MCAwIFIK
ICAvSW0xNyA0NCAwIFIKICAvSW00MCAxMDAgMCBSCiAgL0ltMjYgNjYgMCBS CiAgL0ltNCAx
MiAwIFIKICAvSW0xNSA0MCAwIFIKICAvSW0zOSA5OCAwIFIKICAvSW0xMCAy OCAwIFIKICAv
SW0xOSA1MCAwIFIKICAvSW0zNyA5NCAwIFIKICAvSW0xMiAzMiAwIFIKICAv SW0yNSA2NCAw
IFIKICAvSW0zNSA5MCAwIFIKICAvSW0zNCA4NiAwIFIKICAvSW0zMCA3NiAw IFIKICAvSW02
IDIwIDAgUgogIC9JbTE0IDM4IDAgUgo+Pgo+PgplbmRvYmoKeHJlZgowIDEw NgowMDAwMDAw
MDAwIDY1NTM1IGYgCjAwMDAwMzU1NjUgMDAwMDAgbiAKMDAwMDAzNTYyMyAw MDAwMCBuIAow
MDAwMDM1NjcyIDAwMDAwIG4gCjAwMDAwMDAwMTUgMDAwMDAgbiAKMDAwMDAz NTQzNCAwMDAw
MCBuIAowMDAwMDAwMzEwIDAwMDAwIG4gCjAwMDAwMDA1MzAgMDAwMDAgbiAK MDAwMDAwMDU0
OCAwMDAwMCBuIAowMDAwMDAwODM3IDAwMDAwIG4gCjAwMDAwMDA4NTUgMDAw MDAgbiAKMDAw
MDAwMTA3NyAwMDAwMCBuIAowMDAwMDAxMDk2IDAwMDAwIG4gCjAwMDAwMDEz ODggMDAwMDAg
biAKMDAwMDAwMTQwNyAwMDAwMCBuIAowMDAwMDAxNTA3IDAwMDAwIG4gCjAw MDAwMDE2MTgg
MDAwMDAgbiAKMDAwMDAwMTc2NyAwMDAwMCBuIAowMDAwMDAxODQxIDAwMDAw IG4gCjAwMDAw
MDIwNjggMDAwMDAgbiAKMDAwMDAwMjA4NyAwMDAwMCBuIAowMDAwMDAyNjY0 IDAwMDAwIG4g
CjAwMDAwMDI2ODQgMDAwMDAgbiAKMDAwMDAwMjkwNSAwMDAwMCBuIAowMDAw MDAyOTI0IDAw
MDAwIG4gCjAwMDAwMDMyNjggMDAwMDAgbiAKMDAwMDAwMzI4OCAwMDAwMCBu IAowMDAwMDAz
NTAzIDAwMDAwIG4gCjAwMDAwMDM1MjIgMDAwMDAgbiAKMDAwMDAwMzc5MiAw MDAwMCBuIAow
MDAwMDAzODExIDAwMDAwIG4gCjAwMDAwMDQwMjcgMDAwMDAgbiAKMDAwMDAw NDA0NiAwMDAw
MCBuIAowMDAwMDA0MzE2IDAwMDAwIG4gCjAwMDAwMDQzMzUgMDAwMDAgbiAK MDAwMDAwNDQ4
NCAwMDAwMCBuIAowMDAwMDA0NTU4IDAwMDAwIG4gCjAwMDAwMDQ3NjMgMDAw MDAgbiAKMDAw
MDAwNDc4MiAwMDAwMCBuIAowMDAwMDA1MTY1IDAwMDAwIG4gCjAwMDAwMDUx ODUgMDAwMDAg
biAKMDAwMDAwNTQwMSAwMDAwMCBuIAowMDAwMDA1NDIwIDAwMDAwIG4gCjAw MDAwMDU2OTAg
MDAwMDAgbiAKMDAwMDAwNTcwOSAwMDAwMCBuIAowMDAwMDA1OTI1IDAwMDAw IG4gCjAwMDAw
MDU5NDQgMDAwMDAgbiAKMDAwMDAwNjIxNCAwMDAwMCBuIAowMDAwMDA2MjMz IDAwMDAwIG4g
CjAwMDAwMDYzODIgMDAwMDAgbiAKMDAwMDAwNjQ1NiAwMDAwMCBuIAowMDAw MDA2NjcyIDAw
MDAwIG4gCjAwMDAwMDY2OTEgMDAwMDAgbiAKMDAwMDAwNjk2MSAwMDAwMCBu IAowMDAwMDA2
OTgwIDAwMDAwIG4gCjAwMDAwMDcxOTYgMDAwMDAgbiAKMDAwMDAwNzIxNSAw MDAwMCBuIAow
MDAwMDA3NDg1IDAwMDAwIG4gCjAwMDAwMDc1MDQgMDAwMDAgbiAKMDAwMDAw NzY1NSAwMDAw
MCBuIAowMDAwMDA3NzI5IDAwMDAwIG4gCjAwMDAwMDc5NDUgMDAwMDAgbiAK MDAwMDAwNzk2
NCAwMDAwMCBuIAowMDAwMDA4MjM0IDAwMDAwIG4gCjAwMDAwMDgyNTMgMDAw MDAgbiAKMDAw
MDAwODQ2OSAwMDAwMCBuIAowMDAwMDA4NDg4IDAwMDAwIG4gCjAwMDAwMDg3 NTggMDAwMDAg
biAKMDAwMDAwODc3NyAwMDAwMCBuIAowMDAwMDA4OTI4IDAwMDAwIG4gCjAw MDAwMDkwMDIg
MDAwMDAgbiAKMDAwMDAwOTIxOCAwMDAwMCBuIAowMDAwMDA5MjM3IDAwMDAw IG4gCjAwMDAw
MDk1MDcgMDAwMDAgbiAKMDAwMDAwOTUyNiAwMDAwMCBuIAowMDAwMDA5NzQy IDAwMDAwIG4g
CjAwMDAwMDk3NjEgMDAwMDAgbiAKMDAwMDAxMDAzMSAwMDAwMCBuIAowMDAw MDEwMDUwIDAw
MDAwIG4gCjAwMDAwMTAyMDEgMDAwMDAgbiAKMDAwMDAxMDI3NSAwMDAwMCBu IAowMDAwMDEw
NDkyIDAwMDAwIG4gCjAwMDAwMTA1MTEgMDAwMDAgbiAKMDAwMDAxMDc4NSAw MDAwMCBuIAow
MDAwMDEwODA0IDAwMDAwIG4gCjAwMDAwMTEwMjEgMDAwMDAgbiAKMDAwMDAx MTA0MCAwMDAw
MCBuIAowMDAwMDExMzE0IDAwMDAwIG4gCjAwMDAwMTEzMzMgMDAwMDAgbiAK MDAwMDAxMTQ4
NCAwMDAwMCBuIAowMDAwMDExNTU4IDAwMDAwIG4gCjAwMDAwMTE3NjQgMDAw MDAgbiAKMDAw
MDAxMTc4MyAwMDAwMCBuIAowMDAwMDEyMDkwIDAwMDAwIG4gCjAwMDAwMTIx MDkgMDAwMDAg
biAKMDAwMDAxMjMyNSAwMDAwMCBuIAowMDAwMDEyMzQ0IDAwMDAwIG4gCjAw MDAwMTI2MTYg
MDAwMDAgbiAKMDAwMDAxMjYzNSAwMDAwMCBuIAowMDAwMDEyODUxIDAwMDAw IG4gCjAwMDAw
MTI4NzAgMDAwMDAgbiAKMDAwMDAxMzE0NCAwMDAwMCBuIAowMDAwMDEzMTY0 IDAwMDAwIG4g
CjAwMDAwMTMzMTYgMDAwMDAgbiAKMDAwMDAxMzM5MiAwMDAwMCBuIAowMDAw MDM1NTQyIDAw
MDAwIG4gCnRyYWlsZXIKPDwKL1NpemUgMTA2Ci9Sb290IDIgMCBSCi9JbmZv IDQgMCBSCj4+
CnN0YXJ0eHJlZgozNjU5NAolJUVPRgo=
--------------060308080003000300090903--
Re: b3 - resolver model [message #486625 is a reply to message #486588] Fri, 18 September 2009 09:10 Go to previous messageGo to next message
Yikes, if you are reading this using the Eclipse forum software, the attachment shows up as encoded text.... This post is an experiment to see what happens when adding attachments in the forum client (will news client get it ok?).
Hm, attachments made in the forum just disappears when posting.
[Updated on: Fri, 18 September 2009 09:13] by Moderator
Re: b3 - resolver model [message #486640 is a reply to message #486625] Fri, 18 September 2009 09:34 Go to previous messageGo to next message
> client get it ok?).
Well, it seems like the forum client screws this up - an attachment
added in the forum client just disappears.
Also noted that if edits are made in the forum, those edit are not sent
out as news. (The post I am commenting on here was edited as a test).
Now you know...
- henrik
Re: b3 - resolver model [message #486797 is a reply to message #486640] Sat, 19 September 2009 02:22 Go to previous message
I have no problem reading the attachment with the Thunderbird news reader. Looks good to me.
- thomas
> Now you know...
> - henrik
Re: b3 - resolver model [message #571226 is a reply to message #486588] Fri, 18 September 2009 08:34 Go to previous message
- henrik
>> matching operator.
name="Filter.pdf"
Re: b3 - resolver model [message #571318 is a reply to message #486588] Fri, 18 September 2009 09:10 Go to previous message
Re: b3 - resolver model [message #571356 is a reply to message #571318] Fri, 18 September 2009 09:34 Go to previous message
> client get it ok?).
Now you know...
- henrik
Re: b3 - resolver model [message #577630 is a reply to message #486640] Sat, 19 September 2009 02:22 Go to previous message
- thomas
> Now you know...
> - henrik
Previous Topic:Query model r10645
Next Topic:advice in b3
Current Time: Sat Jul 26 11:52:05 EDT 2025
Powered by FUDForum. Page generated in 0.68451 seconds
