Problems while configuring EBERT [message #486779] |
Tue, 17 March 2009 06:37  |
Hi All,
I have recently checkout EBERT from CVS. I am getting errors while
configuring. as org.eclipse.examples.expenses.widgets.datefield.common
package is missing in the source.
-arun
Re: Problems while configuring EBERT [message #486784 is a reply to message #486783] |
Thu, 19 March 2009 10:30  |
The same solution should work in the Windows Desktop version of eRCP
(you may have to add the -console option in the launcher).
Are you running it on a device? If so, which device?
I apologise for not being able to respond faster. I'm only working a few
hours this week (I'm on "vacation"), and I haven't had enough time to
work on this.
Wayne
Arunagiri.K wrote:
> Thanks. EBERT RCP is working for me. Any solution on eRCP part?
> -arun
Re: Problems while configuring EBERT [message #562476 is a reply to message #486779] |
Tue, 17 March 2009 11:36  |
Hi Arun. It seems that I messed up two things with the team project set.
First, I didn't change the extssh to pserver so that non-committers
could easily use it. Second, I neglected to include the
org.eclipse.examples.expenses.widgets.datefield.common project.
I'll fix both of these problems. In the meantime, you can get the
missing package from CVS; it's in the same location as the other projects.
Sorry for the mix up, and thanks for testing it for me :-)
Wayne
Arunagiri K wrote:
> Hi All,
> Regards,
> -arun
Re: Problems while configuring EBERT [message #562503 is a reply to message #486780] |
Wed, 18 March 2009 08:40  |
First of all I say thanks for this excellent application sample.
In RCP :
I had updated the package and it runs fine. After running the app I don't
know where to start. The application shows all the views perfectly, except
"Title" text field and "Add" button all other fields are disabled. What is
the starting point? How can I input the data?
In eRCP : Using eRCP 1.2 & Eclipse 3.4.1
This shows one empty List and "Add", "Remove", "Edit" menus in "Command"
but nothing works for me. What I am missing?
-arun
Re: Problems while configuring EBERT [message #562527 is a reply to message #486781] |
Wed, 18 March 2009 12:42  |
I guess that the example isn't all that excellent :-)
I expect that the org.eclipse.examples.expenses.context.standalone
bundle needs to be started.
If you're using the launch configurations that I created, they should
already have the -console option in them and so should be able to
interact with the OSGi console.
In the console, get a list of the bundles with the "ss" commands. Find
the number for the org.eclipse.examples.expenses.context.standalone
bundle and type "start ##". That should get everything going.
I'll add this to my list of things that I didn't test well enough and
make it work without the console gymnastics.
Wayne
Arunagiri.K wrote:
> In RCP :
> don't know where to start. The application shows all the views
> perfectly, except "Title" text field and "Add" button all other fields
> are disabled. What is the starting point? How can I input the data?
> Regards,
> -arun
Re: Problems while configuring EBERT [message #562570 is a reply to message #486783] |
work on this.
Wayne
Arunagiri.K wrote:
> -arun
FUDForum. Page generated in 0.12341 seconds
