Home » Archived » Visual Editor (VE) » Error Log filling up
Error Log filling up [message #486215] Wed, 16 September 2009 14:56 Go to next message
I've been using visual editor for a while now and it's been working fine. However , starting today I noticed that I am getting errors in the error log with vague descriptions that I'm not sure how to fix. My visual component is a simple window with a text area and a few buttons. The errors happen when I'm editing the code. Here are two of them and I'm hoping someone can help.
1. Exception Thrown
Plugin - org.eclipse.ve. java.core
at org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.create Instance(CodeGenUtil.java:103)
at org.eclipse.ve.internal.java.codegen.util.CodeGenUtil.create Instance(CodeGenUtil.java:116)
at org.eclipse.ve.internal.java.codegen.model.BeanPart.createEO bject(BeanPart.java:809)
2. Exception Thrown
plugin - org.eclipse.ve. java.core
java.lang.ArrayIndexOutOfBoundsException: -1
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:5 14)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectF orURIFragmentRootSegment(ResourceImpl.java:642)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject( ResourceImpl.java:692)
Thanks in advance
Re: Error Log filling up [message #486245 is a reply to message #486215] Wed, 16 September 2009 17:15 Go to previous messageGo to next message
Sometimes there is a stalecache problem. This may be a symptom of that.
The way to get the cache cleared is to:
1) Open a VE
2) Close the VE
3) Project->Clean->Clean all
4) Wait for build to finish
5) Open a VE.
Hopefully you won't get any more such errors.
> Thanks in advance
Rich Kulp
Re: Error Log filling up [message #486247 is a reply to message #486245] Wed, 16 September 2009 17:20 Go to previous messageGo to next message
I thought that might be the issue because Eclipse opened with an error today so I did run a -clean on it when I opened it again but that didn't fix this error. I'm not sure what the issue could be.
Re: Error Log filling up [message #486371 is a reply to message #486247] Thu, 17 September 2009 09:17 Go to previous messageGo to next message
Not -clean. That clears only the plugin configurations. It doesn't clear
cached metadata. You need to use the procedure I outlined to clear the
cached metadata.
Actually -clean should rarely be needed except if you are just putting
plugins directly into the eclipse configuration without using the
install manager or the dropins folder.
Rich Kulp
Re: Error Log filling up [message #486432 is a reply to message #486371] Thu, 17 September 2009 11:44 Go to previous messageGo to next message
Thanks , I tried that but it didn't seem to fix it. I think I may know what the problem is. I have modified the section where the visual editor creates the jTable and the visual editor doesn't like this.
Visual Editor likes this:
String[] columnNames = {"Column1", "Column2"};
Vector<String> columnNamesV = new Vector<String>(Arrays.asList(columnNames));
jTable = new JTable(getRowData(),columnNamesV);
My modified code which it doesn't like:
jTable = new JTable(getRowData(),columnNamesV){
...custom table code here including creating a rendered to modify the color of the rows
Any ideas ?
Re: Error Log filling up [message #486441 is a reply to message #486432] Thu, 17 September 2009 11:58 Go to previous messageGo to next message
Yeah, I could see that being a problem. The VE needs to be able to
instantiate a visual component. A non-static inner class can't be
instantiated.
> color of the rows
> Any ideas ?
Rich Kulp
Re: Error Log filling up [message #486452 is a reply to message #486441] Thu, 17 September 2009 12:57 Go to previous messageGo to next message
I'm also getting errors in another class that doesn't have any tables and for the most part it's got the same code that VE inserted.
The error is :
Is this something I should be worried about ? Could my install of VE be corrupted ?
Any suggestions ?
Re: Error Log filling up [message #486481 is a reply to message #486452] Thu, 17 September 2009 15:24 Go to previous messageGo to next message
I think I may have found the issue. I removed GUI components one by one from the frame to see when I could add a space in the source and watch the GUI sync and generate an error. When I removed the jTextArea I no longer get the error when the GUI syncs. I'm not sure why this is happening but at least I am getting somewhere.
Re: Error Log filling up [message #486482 is a reply to message #486481] Thu, 17 September 2009 15:28 Go to previous messageGo to next message
I found the line that is causing the problem.
jTextArea.getDocument().addDocumentListener(new MyDocumentListener());
I'm not sure why VE doesn't like this line. The code compiles fine and it also runs fine but when syncing the GUI it generates an error in the Error Log.
Re: Error Log filling up [message #486495 is a reply to message #486482] Thu, 17 September 2009 16:50 Go to previous messageGo to next message
I'm not sure why either but there is a workaround you can use to have VE
ignore the line. It's kind of kludgy. We never got to put in an
annotation that would tell VE to ignore something when I was working on
VE. :-(
if(false)
else
This will work because VE is designed to ignore the else block of an if
statement.
> Error Log.
Rich Kulp
Re: Error Log filling up [message #486498 is a reply to message #486495] Thu, 17 September 2009 16:58 Go to previous messageGo to next message
> VE. :-(
A little bit of grammar problem there. It is not that we never put in
code to have something ignored only when I was working on VE! And so by
corollary when I'm not working on the VE it wouldn't ignore something. :-)
Rich Kulp
Re: Error Log filling up [message #486633 is a reply to message #486495] Fri, 18 September 2009 09:35 Go to previous messageGo to next message
Are there any issues with just leaving my code as is and let VE generate those errors ?
My concern with adding the code as described is it will make the code harder to read and also what happens if in a future release the issue is fixed ?
Re: Error Log filling up [message #486641 is a reply to message #486633] Fri, 18 September 2009 09:40 Go to previous message
If the VE is working otherwise, I guess it is ok.
> those errors ?
> fixed ?
Rich Kulp
Re: Error Log filling up [message #617423 is a reply to message #486245] Wed, 16 September 2009 17:20 Go to previous message
Re: Error Log filling up [message #617425 is a reply to message #486247] Thu, 17 September 2009 09:17 Go to previous message
cached metadata.
Rich Kulp
Re: Error Log filling up [message #617426 is a reply to message #486371] Thu, 17 September 2009 11:44 Go to previous message
Any ideas ?
Re: Error Log filling up [message #617427 is a reply to message #486432] Thu, 17 September 2009 11:58 Go to previous message
instantiated.
> color of the rows
> Any ideas ?
Rich Kulp
Re: Error Log filling up [message #617428 is a reply to message #486441] Thu, 17 September 2009 12:57 Go to previous message
The error is :
Any suggestions ?
Re: Error Log filling up [message #617429 is a reply to message #486452] Thu, 17 September 2009 15:24 Go to previous message
Re: Error Log filling up [message #617431 is a reply to message #486482] Thu, 17 September 2009 16:50 Go to previous message
VE. :-(
if(false)
else
statement.
> Error Log.
Rich Kulp
Re: Error Log filling up [message #617432 is a reply to message #486495] Thu, 17 September 2009 16:58 Go to previous message
> VE. :-(
Rich Kulp
Re: Error Log filling up [message #617433 is a reply to message #486495] Fri, 18 September 2009 09:35 Go to previous message
Re: Error Log filling up [message #617434 is a reply to message #617433] Fri, 18 September 2009 09:40 Go to previous message
> those errors ?
> fixed ?
Rich Kulp
Previous Topic:Re: Error Log filling up
Next Topic:possible VE involvement?
Current Time: Fri Jul 25 06:47:44 EDT 2025
Powered by FUDForum. Page generated in 0.21174 seconds
