Home » Eclipse Projects » JFace » Databinding text to model
Databinding text to model [message #486173] Wed, 16 September 2009 11:27 Go to next message
Originally posted by: mirko.bernardoni.gmail.com
I have converted a rcp application from eclipse 3.4 to eclipse 3.5.
In my application I bind some text widget to model object. My model's
object aren't of type String.
When the class ValueBinding set the converted value to text widget, I have
an Exception.
The reason is class WidgetStringValueProperty, method:
protected void doSetValue(Object source, Object value) {
doSetStringValue(source, (String) value);
It's possibile to change to
doSetStringValue(source, value == null ? "": value.toString());
Or exists another solution?
Re: Databinding text to model [message #486196 is a reply to message #486173] Wed, 16 September 2009 13:13 Go to previous messageGo to next message
Mirko B. wrote:
> have an Exception.
Are you setting an explicit converter? Typically UpdateValueStrategy
will provide an object-to-string converter automatically for you if you
do not set a converter yourself.
Would you file a bug for this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=E clipse&product=Platform&component=UI&short_desc=[DataBinding]&version=3.6
Matthew
Re: Databinding text to model [message #486318 is a reply to message #486196] Thu, 17 September 2009 04:58 Go to previous messageGo to next message
Matthew Hall wrote:
> Mirko B. wrote:
>> Hi,
>> have an Exception.
Yes, I have setting an explicit converter.
I have submit a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289700
Mirko B.
> Matthew
Re: Databinding text to model [message #486443 is a reply to message #486318] Thu, 17 September 2009 12:06 Go to previous message
Mirko B. wrote:
> Matthew Hall wrote:
>> Mirko B. wrote:
>>> Hi,
>>> have an Exception.
>> you do not set a converter yourself.
This being the case, your converter should be returning a String instead
of some other Object.
Matthew
Previous Topic:checkbox state change (checked-grayed-unchecked) logic in CheckboxTreeviewer
Next Topic:TreeViewer Partial update
Current Time: Sat Jul 26 03:09:55 EDT 2025
Powered by FUDForum. Page generated in 0.40329 seconds
