limiting tree control height with formlayout [message #485669] |
Mon, 14 September 2009 08:27  |
Hi all,
I am having difficult limiting the height of a tree control with
FormLayout. The code is below:
Tree dbTree = getWidgetFactory().createTree(composite, SWT.SINGLE |
SWT.V_SCROLL);
fDBTreeViewer = new TreeViewer(dbTree);
formData = new FormData();
formData.left = new FormAttachment(0, 0);
formData.right = new FormAttachment(100, 0);
formData.top = new FormAttachment(0, 0);
// formData.bottom = new FormAttachment(100, 0);
final int NUM_ROWS = 10;
FontMetrics fontMetrics =
FigureUtilities.getFontMetrics(parent.getFont());
formData.height = fontMetrics.getHeight() * NUM_ROWS;
dbTree.setLayoutData(formData);
I set the auto expand for the viewer to 2. If there are many items at
this level then the tree control becomes very tall and looks ridiculous.
(The tree control is part of a section within a TabbedPropertySheet).
As you can see I do set the height of the formData to 10 * font height,
but that doesn't seem to do anything. If I don't set auto expand to 2,
then with just 1 root element, the tree control is ridiculously short,
perhaps only 2 rows tall. Uncommenting out the line where
formData.bottom is set appears to make little difference either.
How can I set the height of the tree control to consistently be 10 rows
tall?
Thanks in advance,
Matt D.
Re: limiting tree control height with formlayout [message #486152 is a reply to message #485669] |
Wed, 16 September 2009 10:26  |
Hi Matt,
Putting your code into a snippet (with minor changes that should not make a
difference) seems to work for me, the snippet is pasted below. Maybe it's
not a problem with your Tree's FormData, but with its parent Composite?
final Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new FormLayout());
Tree dbTree = new Tree(shell, SWT.SINGLE | SWT.V_SCROLL);
for (int i = 0; i < 99; i++) {
TreeItem root = new TreeItem(dbTree, SWT.NONE);
root.setText("root " + i);
TreeItem item = root;
for (int j = 0; j < 99; j++) {
item = new TreeItem(item, SWT.NONE);
item.setText("descendent " + j);
root.setExpanded(true);
dbTree.setLinesVisible(true);
//TreeViewer fDBTreeViewer = new TreeViewer(dbTree);
FormData formData = new FormData();
// FontMetrics fontMetrics =
shell.getFont().getFontData().FigureUtilities.getFontMetrics (parent.getFont(
formData.height = /*fontMetrics.getHeight()*/dbTree.getItemHeight() *
NUM_ROWS;
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
HTH,
Grant
"Matt Dickie" <m.dickie@querix.com> wrote in message
news:h8lcte$kfq$1@build.eclipse.org...
> Hi all,
> SWT.V_SCROLL);
> tall?
> Thanks in advance,
> Matt D.
FUDForum. Page generated in 0.05672 seconds
