Home » Eclipse Projects » Subversive » Get Repository Folder Children' operation finished / An error occured while accessing the repository
Get Repository Folder Children' operation finished / An error occured while accessing the repository [message #485862] Tue, 15 September 2009 06:57 Go to next message
Hi all,
i try to connect to a local svn repository.
This repository is delivered by an apache svn module under:
http://127.0.0.1/allrepos/client428_project1022
I can access this repo via firefox and tortoiseSVN, but not with subversive.
When adding a "New Repository Location" to the "SVN Repositories" view i
get a "< An error occured while accessing the repository entry" when
clicking on "Browse".
In the "error log" view i can see a more detailed error message (3 times):
<MESSAGE>
null
Error
Tue Sep 15 12:51:57 CEST 2009
SVN: '0x00400107: Get Repository Resource Revision' operation finished
with error
Error
Get repository resource revision operation failed.
org.eclipse.team.svn.core.operation.UnreportableException: Selected SVN
connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available or install and select pure Java Subversion connector from the
plug-in connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
at
org.eclipse.team.svn.core.extension.factory.ISVNConnectorFac tory$1.newInstance(ISVNConnectorFactory.java:105)
at
org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.n ewProxyInstance(SVNRepositoryLocation.java:744)
at
org.eclipse.team.svn.core.svnstorage.SVNRepositoryLocation.a cquireSVNProxy(SVNRepositoryLocation.java:536)
at
org.eclipse.team.svn.core.svnstorage.SVNRepositoryResource.g etRevision(SVNRepositoryResource.java:95)
at
org.eclipse.team.svn.ui.operation.GetRemoteResourceRevisionO peration.runImpl(GetRemoteResourceRevisionOperation.java:39)
at
org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:77)
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:104)
at
org.eclipse.team.svn.core.operation.CompositeOperation.runIm pl(CompositeOperation.java:94)
at
at
org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:38)
at
at
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:90)
at
org.eclipse.team.svn.ui.utility.DefaultCancellableOperationW rapper.run(DefaultCancellableOperationWrapper.java:55)
at
org.eclipse.team.svn.ui.utility.ScheduledOperationWrapper.ru n(ScheduledOperationWrapper.java:37)
</MESSAGE>
My version:
Subversive SVN Team Provider (Incubation) 0.7.8.I20090506-1500
As far as i can see version 0.7.8 is newer than 1.1 (this is due to a
different version numbering guideline of the eclipse project, as far as
i know.)
Can any one help?
Best regards
Daniela Waranie
Re: Get Repository Folder Children' operation finished / An error occured while accessing the reposi [message #485873 is a reply to message #485862] Tue, 15 September 2009 07:30 Go to previous messageGo to next message
Hi Daniela,
please find below the important portion of the log:
If you selected the JavaHL connector, you need the native binary libraries installed on your system.
But I suggest to use the pure java SVNKit connector as a first try. It works perfectly for us.
Cheers, Jörg
Re: Get Repository Folder Children' operation finished / An error occured while accessing the reposi [message #486077 is a reply to message #485873] Wed, 16 September 2009 05:20 Go to previous message
Hi Jörg,
in installed subversive in addition to the eclipse+pdt bundle, and used
that svn views instead of the bundled.
I removed the subversive client that was installed by me and then used
the build in SVN client and this works. I think the connector ships with
the bundle. Thanks.
Best regards
Daniela Waranie
Previous Topic:Subversive inside RCP app
Next Topic:Eclipse Subversive Installation guide
Current Time: Thu Jul 24 20:46:13 EDT 2025
Powered by FUDForum. Page generated in 0.03359 seconds
