SWT. Table with Table Editor [message #486073] |
Wed, 16 September 2009 04:53  |
We are creating a Table with different type of items. To carry out it we
use one Table Item per row and one Table Editor per column. The problem is
that we donŽt know how to get the data (items) from the table, Here some
example code:
Table table = new Table(atributeGroup, SWT.BORDER | SWT.V_SCROLL);
table.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
String[] titles = {"PK","Nombre", "Tipo", "Relación"};
for (int i=0; i<titles.length; i++) {
TableColumn column = new TableColumn (table, SWT.NONE);
column.setText (titles [i]);
column.setWidth(103);
TableEditor editor = new TableEditor(table);
TableItem item= new TableItem(table, SWT.NONE);
Display display = Display.getCurrent();
Button clave_B= new Button(table, SWT.CHECK);
clave_B.setBackground(display.getSystemColor(SWT.COLOR_WHITE ));
editor.grabHorizontal = true;
editor.setEditor(clave_B, item, 0);
Text nombre_T= new Text(table, SWT.NONE);
editor.setEditor(nombre_T, item, 1);
CCombo tipo_CC = new CCombo(table, SWT.NONE);
tipo_CC.add("String");
tipo_CC.setEditable(false);
editor.setEditor(tipo_CC, item, 2);
CCombo relacion_CC = new CCombo(table, SWT.NONE);
relacion_CC.setEditable(false);
relacion_CC.add("1 ... 1");
editor.grabHorizontal = true; editor.setEditor(relacion_CC, item,
3);
Ones the user introduce data in each field, How can we recover this
information? ItŽs mean recover each Button, Text and CCombo from the Table
table variable.
Thank you in advance.
Re: SWT. Table with Table Editor [message #487440 is a reply to message #486415] |
Wed, 23 September 2009 05:41  |
Hello Grant,
Thank you for answer me, finally I will do that you say me, also I have thought to save the pointer into array list, but I will use the method setData.
Thank you again.
Best Regards.
FUDForum. Page generated in 0.03530 seconds
