Home » Modeling » OCL » OCLConsole Saving Error: The 'no duplicates' constraint is violated
OCLConsole Saving Error: The 'no duplicates' constraint is violated [message #486027] Tue, 15 September 2009 19:58 Go to next message
I am getting this error when I try to save an OCL expression to an xmi file.
public void setOCLExpression(OCLExpression<Object> expr) {
// add my expression as the first root, because I already contain
// variables and EPackages defining dynamically-generated types
getContents().add(0, expr);
Exception:
"Error Saving OCL Expression, The 'no duplicates' constraint is violated"
Any help is appreciated.
Richard Catlin
Re: OCLConsole Saving Error: The 'no duplicates' constraint is violated [message #486051 is a reply to message #486027] Wed, 16 September 2009 01:49 Go to previous messageGo to next message
Hi Richard
You provide no clues as to what you are saving, so I can do little more
than elaborate the message, which occurs when the same EObject is added
more than once to an EList that enforces unique content.
So for some reason you are adding a duplicate expression; most likely
a singleton value such as (Ocl)Invalid that may have arisen more than once.
You need to investigate waht is duplicated and where each one came from.
When you tell us how to reproduce the problem we may be able to improve
the error message.
Ed Willink
> file.
> Exception:
> Regards,
> Richard Catlin
Re: OCLConsole Saving Error: The 'no duplicates' constraint is violated [message #486153 is a reply to message #486051] Wed, 16 September 2009 10:25 Go to previous messageGo to next message
Ed,
Thanks for the response. I should have elaborated.
I have simply created an ecore model, generated the code, and run the
generated editor. I have also included the OCL Interpreter that
Christian wrote.
Within the OCLConsolePage, there is an input window (SourceViewer) and
an output window (Read-only TextViewer).
When I enter a valid OCL expression and hit Enter, the OCL expression is
parsed and evaluated, and the results are outputted in the TextViewer.
There is a button to save the OCL Expression (lastExpression variable)
to the default persistence mechanism, an XMI file. After I select the
file location, the Error dialog pops up. I have tried many expressions
such as:
self.title
self.question->size() > 1
which are valid OCL expressions.
My understanding is that the OCL expression that I enter is parsed into
the AST (OCL is an ecore model), and that this AST structure is
persisted, just like any ecore model.
Thanks for the heads up about an EList's uniqueness constraint.
It is interesting that Christian put this comment in his code:
When I debug, it seems that getContents() already has 3 strucutres in
it. Do you know why? Typically when I save an instance of an ecore
model that I have created it is the only strucutre in the file. The EMF
book also says to use this code to do
getContents().add(expr)
I presume that OCL has some special requirements and that is why
there are already 3 structures. Any ideas here?
When I modify the code to
I don't get the error, but the OCL expression can not be loaded from the
file.
Richard Catlin
On 9/15/2009 10:49 PM, Ed Willink wrote:
> Hi Richard
> the error message.
> Regards
> Ed Willink
>> file.
>> Exception:
>> Regards,
>> Richard Catlin
EXTLibrary Model also throws OCLConsole Saving Error: The 'no duplicates' constraint is violated [message #486223 is a reply to message #486153] Wed, 16 September 2009 15:40 Go to previous messageGo to next message
I tried this on the EXTLibrary example and get the same error for simple
OCL expressions.
1. I installed eclipse-modeling-galileo-incubation-win32.zip
2. I start and switch to the Plug-in Development Perspective
3. I switch to the Plugins tab and import as source
org.eclipse.emf.ocl.examples
4. I then Import "Existing Projects into Workspace" for each of the zip
files: interpreter.zip, library.zip, libraryEdit.zip, and
libraryEditor.zip and get four projects that build properly.
5. I run the Editor project, which launches an Eclipse Runtime.
6. I create a new EMF Project, and then create an EXTLibrary Model.
7. In the Editor, I add a Library Child and give it a name.
8. I right-click on the Library Node, and start the OCL Interpreter.
9. In the bottom pane (the SourceViewer), I enter: name and then hit
enter. In the TextViewer pane, I see the Results with the correct
information for the name displayed.
10. I want to save this OCL Expression to an xmi file and click on the
Save button. I select a directory and create a new file name. When I
hit OK, I get the ERROR dialog:
Am I doing something wrong?
Richard Catlin
On 9/16/2009 7:25 AM, Richard Catlin wrote:
> Ed,
> Christian wrote.
> such as:
> self.title
> I presume that OCL has some special requirements and that is why there
> file.
> Regards,
> Richard Catlin
>> Hi Richard
>> more than elaborate the message, which occurs when the same EObject is
>> added
>> once.
>> improve the error message.
>> Regards
>> Ed Willink
>>> xmi file.
>>> Exception:
>>> violated"
>>> Regards,
>>> Richard Catlin
Re: EXTLibrary Model also throws OCLConsole Saving Error: The 'no duplicates' constraint is violated [message #486255 is a reply to message #486223] Wed, 16 September 2009 17:28 Go to previous message
Hi Richard
No you're doing nothing wrong.
Thank you for the clear repro.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289660 raised.
There is a good chance that deleting the
res.setOCLExpression(parsed);
at line 135 of OCLResource will cure the problem.
When OCL is persisted there are a variety of orphan elements. For a
complete OCL model this may just be any collection tyupe declarations.
For a partial model your example needs a self variable. FOr some reason
two (no-duplicate) self variables are persisted.
In general it is a responsibility of the OCL AST consumer to resolve the
orphans. THe OCL interpreter does this by placing them all at the root.
Step 4: New->Example->OCL Plugins->OCL Interpreter does this in one hit.
Ed Willink
> OCL expressions.
> Regards,
> Richard Catlin
>> Ed,
>> Christian wrote.
>> is parsed and evaluated, and the results are outputted in the
>> TextViewer. There is a button to save the OCL Expression
>> (lastExpression variable) to the default persistence mechanism, an XMI
>> file. After I select the file location, the Error dialog pops up. I
>> have tried many expressions such as:
>> self.title
>> into the AST (OCL is an ecore model), and that this AST structure is
>> EMF book also says to use this code to do
>> the file.
>> Regards,
>> Richard Catlin
>>> Hi Richard
>>> is added
>>> once.
>>> Regards
>>> Ed Willink
>>>> xmi file.
>>>> Exception:
>>>> violated"
>>>> Regards,
>>>> Richard Catlin
Previous Topic:OCL query to find classes
Next Topic:Query for not all elements of a model
Current Time: Thu Jul 24 21:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.30358 seconds
