Home » Language IDEs » C / C++ IDE (CDT) » Convert project from C to C++
Convert project from C to C++ [message #485306] Fri, 11 September 2009 05:55 Go to next message
Originally posted by: augustbering.yahoo.com
Anybody knows if it's possible to convert a C project to C++? Currently I
don't see the Cygwin C++ Compiler in my "C/C++ Build->Settings" pane.
Re: Convert project from C to C++ [message #485820 is a reply to message #485306] Tue, 15 September 2009 03:59 Go to previous messageGo to next message
Originally posted by: billinares.bluewin.ch
What do you mean convert to C++? A C++ compiler should be able to compile
c code with no problems (actually, you might catch some problems that the
c-compiler let through).
Re: Convert project from C to C++ [message #485854 is a reply to message #485820] Tue, 15 September 2009 06:34 Go to previous messageGo to next message
Yes, but I created a C project with CDT and now this project won't build
c++ files, because there is no c++ compiler tool in the tool settings...
Lots of the files in my project have individual settings so I'd like to
not have to recreate the project from scratch as a C project.
Re: Convert project from C to C++ [message #485866 is a reply to message #485854] Tue, 15 September 2009 07:04 Go to previous messageGo to next message
Correct me if I'm wrong, but I don't think Eclipse makes any difference
between C and C++ projects. In any case you need a C++ compiler (maybe you
forgot to install it along with the C compiler). Then instruct your
builder to use it to compile your C-code. As long as you are not mixing C
and C++ code that should do it.
Re: Convert project from C to C++ [message #485867 is a reply to message #485854] Tue, 15 September 2009 07:20 Go to previous messageGo to next message
I don't know of a way to convert a C project into a C++ project. I think
you need to create your project again.
Derek
Re: Convert project from C to C++ [message #486101 is a reply to message #485866] Wed, 16 September 2009 07:10 Go to previous messageGo to next message
Unfortunately it does... Just create a C and C++ project and compare the
tool settings you get. This should probably be an easy fix for anybody
working on CDT, but I guess I'll just have to recreate the project and
take the road of pain.
Re: Convert project from C to C++ [message #880308 is a reply to message #486101] Fri, 01 June 2012 16:37 Go to previous messageGo to next message
If anyone still cares... Just add
<nature>org.eclipse.cdt.core.ccnature</nature>
to the the <natures></natures> tag of your .project file.
Re: Convert project from C to C++ [message #1763510 is a reply to message #880308] Tue, 16 May 2017 16:17 Go to previous message
Thanks! That actually works perfectly!
Previous Topic:Organizing imports automation
Next Topic:Build not Found error
Current Time: Fri Jul 25 06:21:45 EDT 2025
Powered by FUDForum. Page generated in 0.05813 seconds
