Home » Modeling » OCL » How to check the types of containment?
How to check the types of containment? [message #485315] |
Fri, 11 September 2009 06:55  |
Originally posted by: formatzeh.gmx.de
imagine I have class defined (CompositionModel) in my meta model which
has a containment reference (1..*) to an abstract class (AbstractModel).
I have several concrete classes (ModelA, ModelB, ...) inheriting from
that abstract class. Now I want to write an ocl constraint for
CompositionModel expressing that every concrete class can only be
contained once in the CompositionModel class. How can I express this? I
have to count the contained types for every ModelA, ModelB, ... anyway.
Can you help me?
best regards,
Gilbert
Re: How to check the types of containment? [message #485349 is a reply to message #485315] |
Fri, 11 September 2009 09:22   |
--=-K714bR8dVcNUtJJGi5Ee
Content-Type: text/plain
Hi, Gilbert,
You can either wait for the MDT OCL release that the excellent new
committer team is working on that will support OCL 2.1 spec with with
the new oclType() operation:
context CompositionModel
inv: containedModel->unique(oclType())
(assuming your containment reference is named "containedModel") or, with
the latest release, you can use set the "implicit root class" parser
option to EObject and do this:
inv: containedModel->unique(eClass())
Either way, you are checking that the members of the collection are of
unique classes.
HTH,
Christian
On Fri, 2009-09-11 at 12:55 +0200, Gilbert Mirenque wrote:
> Hello,
> Can you help me?
> best regards,
> Gilbert
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
You can either wait for the MDT OCL release that the excellent new committer team is working on that will support OCL 2.1 spec with with the new oclType() operation:<BR>
<BR>
context CompositionModel<BR>
inv: containedModel->unique(oclType())<BR>
<BR>
(assuming your containment reference is named "containedModel") or, with the latest release, you can use set the "implicit root class" parser option to EObject and do this:<BR>
<BR>
inv: containedModel->unique(eClass())<BR>
<BR>
Either way, you are checking that the members of the collection are of unique classes.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Can you help me?
best regards,
Gilbert
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-K714bR8dVcNUtJJGi5Ee--
Re: How to check the types of containment? [message #485372 is a reply to message #485359] |
Fri, 11 September 2009 09:59   |
--=-80CJtH/WYzeQwmY4IgVZ
Hi, Gilbert,
Oops, yes, I did. I always get confused by the fact that this is the
one boolean-valued iterator that uses "is" in the name. Unlike exists,
forAll, one. :-)
Until OCL 2.1 is implemented, the Ecore-specific eClass() is the only
work-around available to the problem of access to the type of an object
(unless, of course, you define an operation or an attribute in your
model that gets the object's type, but I can't recommend that). OCL 1.x
had the OclAny::oclType attribute, OCL 2.0 removed it, and OCL 2.1 will
restore it in the form of an operation: OclAny::oclType().
Christian
On Fri, 2009-09-11 at 15:41 +0200, Gilbert Mirenque wrote:
> Hi Christian,
> didn't you mean the containedModel->isUnique(..) method?
> eClass() is emf specific and not pure ocl spec isn't it?
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
Oops, yes, I did. I always get confused by the fact that this is the one boolean-valued iterator that uses "is" in the name. Unlike exists, forAll, one. :-)<BR>
<BR>
Until OCL 2.1 is implemented, the Ecore-specific eClass() is the only work-around available to the problem of access to the type of an object (unless, of course, you define an operation or an attribute in your model that gets the object's type, but I can't recommend that). OCL 1.x had the OclAny::oclType attribute, OCL 2.0 removed it, and OCL 2.1 will restore it in the form of an operation: OclAny::oclType().<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
Hi Christian,
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-80CJtH/WYzeQwmY4IgVZ--
Re: How to check the types of containment? [message #485402 is a reply to message #485382] |
Fri, 11 September 2009 11:22   |
--=-2ORX0iR4eSBN957L8tLN
Hi, Gilbert,
How about something like this:
inv: let epkg : ecore::EPackage = self.eClass().ePackage,
supertype : ecore::EClass =
epkg.getEClassifier("AbstractModel"),
concreteTypes : Set(ecore::EClass) =
epkg.eClassifiers->select(c |
not c.isAbstract and
supertype.isSuperClassOf(c))->asSet()
in
containedModel->unique(eClass()) and
containedModel.eClass()->asSet() = concreteTypes
The idea is to find all of the concrete subclasses of AbstractModel and
then check that the elements in the containedModel collection are all of
different types and that all of the concrete types are instantiated.
Thus, unique instances of every type.
HTH,
Christian
On Fri, 2009-09-11 at 17:05 +0200, Gilbert Mirenque wrote:
> And how could I realize it that generically all sub types of
> AbstractModel will be checked? I can't do the test for every type
> because it can be that the metamodel will be extended.
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
How about something like this:<BR>
<BR>
inv: let epkg : ecore::EPackage = self.eClass().ePackage,<BR>
supertype : ecore::EClass = epkg.getEClassifier("AbstractModel"),<BR>
concreteTypes : Set(ecore::EClass) = epkg.eClassifiers->select(c |<BR>
not c.isAbstract and supertype.isSuperClassOf(c))->asSet()<BR>
in<BR>
containedModel->unique(eClass()) and<BR>
containedModel.eClass()->asSet() = concreteTypes<BR>
<BR>
The idea is to find all of the concrete subclasses of AbstractModel and then check that the elements in the containedModel collection are all of different types and that all of the concrete types are instantiated. Thus, unique instances of every type.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-2ORX0iR4eSBN957L8tLN--
Re: How to check the types of containment? [message #485481 is a reply to message #485402] |
Fri, 11 September 2009 17:50   |
Hi Gilbert, Christain
I think the double argument forAll idiom should suit
context AbstractModel
inv: containedModel->forAll(a, b |
a <> b implies a.oclType() <> b.oclType())
Ed Willink
Christian W. Damus wrote:
> Hi, Gilbert,
> in
> HTH,
> Christian
Re: How to check the types of containment? [message #485685 is a reply to message #485481] |
Mon, 14 September 2009 09:19   |
--=-T5TUmtUfH6w5hUltUnWj
Hi, Ed,
Yes, that's a good way to do the uniqueness condition, but there is
still the covering condition to consider: the other requirement was to
check that all concrete subclasses of AbstractModel are instantiated in
the containedModel collection.
Christian
> Regards
> Ed Willink
> > Hi, Gilbert,
> > in
> > HTH,
> > Christian
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Ed,<BR>
<BR>
Yes, that's a good way to do the uniqueness condition, but there is still the covering condition to consider: the other requirement was to check that all concrete subclasses of AbstractModel are instantiated in the containedModel collection.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Ed Willink
> Hi, Gilbert,
> in
> HTH,
> Christian
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-T5TUmtUfH6w5hUltUnWj--
Re: How to check the types of containment? [message #485889 is a reply to message #485774] |
Tue, 15 September 2009 09:06   |
--=-clCxHl51g8vJDpDwfD98
Hi, Gilbert,
Ah! I see ... I misunderstood your original statement on that subject.
I see that Ed has the correct context declaration, then. So the
following is, perhaps, the most succinct definition:
inv: containedModel->isUnique(oclType())
or, until OCL 2.1 is implemented,
inv: containedModel->isUnique(eClass())
cW
On Mon, 2009-09-14 at 23:55 +0200, Gilbert Mirenque wrote:
> Hi Christian,
> no - not all concrete sublasses have to isntantiated but this who are
> only must be instantiated once.
> cheers
> Gilbert
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
Ah! I see ... I misunderstood your original statement on that subject. I see that Ed has the correct context declaration, then. So the following is, perhaps, the most succinct definition:<BR>
<BR>
<TT><FONT COLOR="#000000">context AbstractModel</FONT></TT><BR>
<TT><FONT COLOR="#000000">inv: containedModel-></FONT></TT><TT>isUnique</TT><TT ><FONT COLOR="#000000">(oclType())</FONT></TT><BR>
<BR>
or, until OCL 2.1 is implemented,<BR>
<BR>
<TT><FONT COLOR="#000000">inv: containedModel-></FONT></TT><TT>isUnique</TT><TT ><FONT COLOR="#000000">(</FONT></TT>eClass<FONT COLOR="#000000">())</FONT><BR>
<BR>
cW<BR>
<BR>
<BR>
<PRE>
Hi Christian,
cheers
Gilbert
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-clCxHl51g8vJDpDwfD98--
Re: How to check the types of containment? [message #485944 is a reply to message #485943] |
Tue, 15 September 2009 11:22   |
--=-Wsv8x9CA8MMGZhj4m17z
Hi, Gilbert,
Update the interpreter example code to set the "implicit root class"
parser option to EcorePackage.Literals.EObject in the initialization of
the M1 environment. This is required to access the EObject features in
models that do not explicitly extend EObject.
HTH,
Christian
On Tue, 2009-09-15 at 17:07 +0200, Gilbert Mirenque wrote:
> I have another problem now. Until now I took an evaluation copy of
> Together for designing my ocl constraints in the ocl editor and just
> pasted them into my ecore model annotations. But as my copy ran out now
> I can't use it anymore and I wanted to try to create my constraints like
> described in [1] with the OCL console. Now the problem is if I select M2
> as modeling level I can use expressions like eClass(). But with the
> statement
> self.model->isUnique(eClass())
> I get the message "Unrecognized variable: (model)". So I activated level
> M1 and now I can access self.model for example but not eClass() anymore.
> Am I doing something wrong? Or how do you create your ocl expressions?
> best regards,
> Gilbert
> [1]
> http://help.eclipse.org/galileo/topic/org.eclipse.ocl.doc/re ferences/examples/oclInterpreterExample.html
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
Update the interpreter example code to set the "implicit root class" parser option to EcorePackage.Literals.EObject in the initialization of the M1 environment. This is required to access the EObject features in models that do not explicitly extend EObject.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
statement
best regards,
Gilbert
[1]
<A HREF=" http://help.eclipse.org/galileo/topic/org.eclipse.ocl.doc/re ferences/examples/oclInterpreterExample.html"> http://help.eclipse.org/galileo/topic/org.eclipse.ocl.doc/re ferences/examples/oclInterpreterExample.html</A>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-Wsv8x9CA8MMGZhj4m17z--
Re: How to check the types of containment? [message #485966 is a reply to message #485955] |
Tue, 15 September 2009 13:53   |
--=-z2QICUAgTQ3+qb1sbXfh
Hi, Gilbert,
See some replies in-line, below.
HTH,
Christian
On Tue, 2009-09-15 at 18:04 +0200, Gilbert Mirenque wrote:
> Sorry Christian,
> I don't understand what you mean.
> I meant that I found the posted link and wanted to create some ocl
> expressions with at least a little kind of editor. I don't use the
> example described in the link. What is the "implicit root class" parser
But, you said in your post that you were getting error messages from
expressions and "activated level M1" etc. If you weren't doing this in
the OCL interpreter example (the "interactive console") then I don't
know what you were using. AFAIK, the only UI that uses labels like "M2"
and "M1" is that example.
The MDT OCL SDK provides a "New Example" wizard that creates the
interpreter/console example as a source project in your workspace. You
can edit the code to customize the parser behaviour, if you need to, as
in this case.
The implicit root class option is a customization option for the parser:
the details of the API escape me now, it's been so long since I've
worked with the OCL code. Look for the ParserOptions type in the OCL
source. This option is used to tell the parser to assume that all
classes in your model that don't have an explicit superclass have the
given class (in this case, EObject) as a superclass. This covers the
case in Ecore models where on a Java level all generated classes extend
EObject whether your Ecore model makes it explicit or not.
> option? I have a meta model based on ecore. What do I have to change
> that I can invent some ocl expressions?
You don't necessarily have to do anything special to work with Ecore
models. It's just that, in your case, you need to do reflection on the
meta-model level of a sort that OCL (the language) does not support, so
we need to pull a trick to work around it in the MDT implementation.
> Another question: Under [1] I found in the last snippet the following line:
> self.allOwnedElements()
> But allOwnedElements() can't be found here. Is this an old snippet? I
No, this snippet pertains to the UML metamodel. In UML models you can
use allOwnedElements because it is defined by the uml::Element
metaclass. The only thing similar in the Ecore metamodel is
eAllContents(), but it returns a data type (an iterator) which isn't of
any use in OCL.
> want to check if all referenced events of a model element are contained
> in its own hierarchy are and not events of model elements outside its
> own hierarchy. That means the referenced events mustn't be events of
> sibling model elements. So I tried to do something like this:
> self.exportedEvents ->forAll(ev|
> ->select(x|
> x.oclIsTypeOf(MyMetaModel::Event))
> ->includes(ev)
Try this:
self.exportedEvents ->forAll(ev |
ev->closure(eContainer())->contains(self))
Unfortunately, this again requires that either you explicitly extend
EObject in your model or you use the implicit root class option, in
order to access the eContainer()) operation. Alternatively, perhaps
your model already has some feature that generically returns the
containing element?
> Sorry for the annoying questions but for a novice it's just an ocl
> jungle. A central documentation with what is possible in MDT OCL and how
> would be nice. Hope you can help.
> best regards,
> Gilbert
> [ http://wiki.eclipse.org/OCLSnippets#Finding_all_classifiers_ that_specialize_an_arbitrary_classifier_named_.27foo::Bar.27]
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
See some replies in-line, below.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Sorry Christian,
</PRE>
</BLOCKQUOTE>
<BR>
But, you said in your post that you were getting error messages from expressions and "activated level M1" etc. If you weren't doing this in the OCL interpreter example (the "interactive console") then I don't know what you were using. AFAIK, the only UI that uses labels like "M2" and "M1" is that example.<BR>
<BR>
The MDT OCL SDK provides a "New Example" wizard that creates the interpreter/console example as a source project in your workspace. You can edit the code to customize the parser behaviour, if you need to, as in this case.<BR>
<BR>
The implicit root class option is a customization option for the parser: the details of the API escape me now, it's been so long since I've worked with the OCL code. Look for the ParserOptions type in the OCL source. This option is used to tell the parser to assume that all classes in your model that don't have an explicit superclass have the given class (in this case, EObject) as a superclass. This covers the case in Ecore models where on a Java level all generated classes extend EObject whether your Ecore model makes it explicit or not.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
You don't necessarily have to do anything special to work with Ecore models. It's just that, in your case, you need to do reflection on the meta-model level of a sort that OCL (the language) does not support, so we need to pull a trick to work around it in the MDT implementation.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
No, this snippet pertains to the UML metamodel. In UML models you can use allOwnedElements because it is defined by the uml::Element metaclass. The only thing similar in the Ecore metamodel is eAllContents(), but it returns a data type (an iterator) which isn't of any use in OCL.<BR>
<BR>
<BR>
<PRE>
->select(x|
->includes(ev)
</PRE>
</BLOCKQUOTE>
<BR>
Try this:<BR>
<BR>
self.exportedEvents ->forAll(ev |<BR>
ev->closure(eContainer())->contains(self))<BR >
<BR>
Unfortunately, this again requires that either you explicitly extend EObject in your model or you use the implicit root class option, in order to access the eContainer()) operation. Alternatively, perhaps your model already has some feature that generically returns the containing element?<BR>
<BR>
<PRE>
best regards,
Gilbert
[<A HREF=" http://wiki.eclipse.org/OCLSnippets#Finding_all_classifiers_ that_specialize_an_arbitrary_classifier_named_.27foo::Bar.27"> http://wiki.eclipse.org/OCLSnippets#Finding_all_classifiers_ that_specialize_an_arbitrary_classifier_named_.27foo::Bar.27</A>]
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-z2QICUAgTQ3+qb1sbXfh--
Re: How to check the types of containment? [message #486096 is a reply to message #485966] |
Wed, 16 September 2009 07:03   |
Hi Christian,
thanks for your patience
I was doing it in the console but I'm not using the example.
> in this case.
Ok thanks for the hint with the wizard. I will have a look. But at the
moment I don't need any code for running OCL statements or so. I just
need a way for developing some ocl expressions for my meta model. After
creating correct expressions I want to add them as EAnnotations on my
meta model elements in hope that the bug 255786 [1] will be solved soon.
And therefore I thought that I can use the OCL console just to see if
the expressions are correct - not more. And that's why I don't
understand why I have to switch M2 and M1 if I want to get code
completion in the console for this element or for that element. Thought
when I develop a new ecore meta model I am on the M2 level because it's
a meta model for my DSL.
> metaclass.
Ok I assumed that.
Neither on level M1 nor M2 the code assist shows me the closure(..) on
ev. The same with contains(..). And if I let this expression interprete
by the console in level M1 I get this output:
illegal operation signature: (eContainer())
and in level M2:
Unrecognized variable: (exportedEvents)
It's just not very comprehensible for me why I have to switch always.
Thought that when I create a new ecore meta model all the elements
inherit from EObject. At least the generated classes extend EObject. But
one does not have to generate classes at all. Isn't it possible at all
to use the OCL console in this case because no classes are generated?
Can't imagine.
> containing element?
Ok I can consider this. Until now I don't have any operations in my meta
model because I wanted to let it open if it will be used with Eclipse or
any other platform.
Thanks in advance Christian.
best regards,
Gilbert
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786
Re: How to check the types of containment? [message #486135 is a reply to message #486096] |
Wed, 16 September 2009 09:35   |
--=-MKRiOzOr3EZFTMSvvb90
Hi, Gilbert,
See some more comments in-line.
HTH,
Christian
On Wed, 2009-09-16 at 13:03 +0200, Gilbert Mirenque wrote:
> Hi Christian,
Ah, but you are. The interactive console *is* the example. :-)
> > in this case.
Yes, the console example is primarily intended as a scratchpad for
development and testing of OCL constraints, in the manner that you
intend to use it.
In the "M2" mode, your expressions are in the Ecore (metamodel) context,
so they are generally expected to be queries on the model that you are
editing. The context of any expression that you type is the metaclass
of the selected element. Thus, in "M2" mode you have expressions on
EClass, EDataType, EReference, EPackage, etc. The idea is that you can
query your model to analyze its structure (e.g., are there any abstract
EClasses that have no concrete subclasses?).
In the "M1" mode, your expressions are boolean constraints in the
context of your model (as an Ecore instance). The kind of constraint
depends on the selected element: when an EClass is selected, the
console treats your expression as an invariant constraint. When an
EOperation is selected, as a postcondition (as its syntax is a superset
of the possible operation constraints). When an EStructuralFeature is
selected, as a derivation expression. You want to use "M1" mode to
author the model constraints for your annotations and eventual execution
at run-time.
Note that, for "M1" mode, the interpreter only parses the constraints
and reports syntax problems if necessary, because there is no model
instance to evaluate the constraint on. In "M2" mode, you are really
defining queries on your model as an Ecore instance, so the console
evaluates them on your model.
You can create a dynamic instance of any EClass in your model, of
course, and then evaluate expressions on that. These might be
invariants that you parsed in "M1" mode in the model, but then you need
"M2" mode on the dynamic instance because it is at a lower meta-level.
This is why the M1/M2 labeling in the UI is unfortunate.
> > metaclass.
> Ok I assumed that.
Sorry ... too much Java. This should, of course, be "includes" instead
of "contains."
Content assist may not show you the "closure" iterator because it is not
OMG-standard OCL. However, it should parse.
That is only because you need to update the console to set EObject as
the implicit root class when parsing, unless your EClasses explicitly
extend EObject (which I generally wouldn't recommend).
> and in level M2:
Because EClass does not have an exportedEvents feature. Your model
class does. You need the M1 setting to author model constraints.
It's just a way to tell the parser whether the context of an expression
is the *metaclass* of the selected element (M2 case) or the selected
element, itself (M1). For what you are doing, M2 is not interesting.
For background on this nomenclature, you might read the chapter on the
OMG's MDA architecture and the 4-layer modeling stack (M0 through M3) in
the Meta-Object Facility (MOF) 2.0 specification.
Yes, the Java *implementation* of your model extends EObject, but in
abstract terms your model classes do not. The EMF run-time requires the
features of EObject but your business logic does not. OR, if it does,
then your model may benefit from explicitly extending EObject. The
point is whether your EClasses actually list EObject as an eSuperClass
or not.
> Can't imagine.
Yes, it works equally well with dynamic EMF as with generated models.
You can try it right in the model editor on a dynamic instance!
Evaluate one of your invariant constraint expressions on a dynamic
object and you'll see.
> > containing element?
> any other platform.
> best regards,
> Gilbert
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
See some more comments in-line.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Christian,
</PRE>
</BLOCKQUOTE>
<BR>
Ah, but you are. The interactive console *is* the example. :-)<BR>
<BR>
<BR>
<PRE>
> in this case.
</PRE>
</BLOCKQUOTE>
<BR>
Yes, the console example is primarily intended as a scratchpad for development and testing of OCL constraints, in the manner that you intend to use it.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
In the "M2" mode, your expressions are in the Ecore (metamodel) context, so they are generally expected to be queries on the model that you are editing. The context of any expression that you type is the metaclass of the selected element. Thus, in "M2" mode you have expressions on EClass, EDataType, EReference, EPackage, etc. The idea is that you can query your model to analyze its structure (e.g., are there any abstract EClasses that have no concrete subclasses?).<BR>
<BR>
In the "M1" mode, your expressions are boolean constraints in the context of your model (as an Ecore instance). The kind of constraint depends on the selected element: when an EClass is selected, the console treats your expression as an invariant constraint. When an EOperation is selected, as a postcondition (as its syntax is a superset of the possible operation constraints). When an EStructuralFeature is selected, as a derivation expression. You want to use "M1" mode to author the model constraints for your annotations and eventual execution at run-time.<BR>
<BR>
Note that, for "M1" mode, the interpreter only parses the constraints and reports syntax problems if necessary, because there is no model instance to evaluate the constraint on. In "M2" mode, you are really defining queries on your model as an Ecore instance, so the console evaluates them on your model.<BR>
<BR>
You can create a dynamic instance of any EClass in your model, of course, and then evaluate expressions on that. These might be invariants that you parsed in "M1" mode in the model, but then you need "M2" mode on the dynamic instance because it is at a lower meta-level. This is why the M1/M2 labeling in the UI is unfortunate.<BR>
<BR>
<BR>
<PRE>
> metaclass.
Ok I assumed that.
</PRE>
</BLOCKQUOTE>
<BR>
Sorry ... too much Java. This should, of course, be "includes" instead of "contains."<BR>
<BR>
Content assist may not show you the "closure" iterator because it is not OMG-standard OCL. However, it should parse.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
That is only because you need to update the console to set EObject as the implicit root class when parsing, unless your EClasses explicitly extend EObject (which I generally wouldn't recommend).<BR>
<BR>
<BR>
<PRE>
and in level M2:
</PRE>
</BLOCKQUOTE>
<BR>
Because EClass does not have an exportedEvents feature. Your model class does. You need the M1 setting to author model constraints.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
It's just a way to tell the parser whether the context of an expression is the *metaclass* of the selected element (M2 case) or the selected element, itself (M1). For what you are doing, M2 is not interesting.<BR>
<BR>
For background on this nomenclature, you might read the chapter on the OMG's MDA architecture and the 4-layer modeling stack (M0 through M3) in the Meta-Object Facility (MOF) 2.0 specification.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
Yes, the Java *implementation* of your model extends EObject, but in abstract terms your model classes do not. The EMF run-time requires the features of EObject but your business logic does not. OR, if it does, then your model may benefit from explicitly extending EObject. The point is whether your EClasses actually list EObject as an eSuperClass or not.<BR>
<BR>
<PRE>
Can't imagine.
</PRE>
</BLOCKQUOTE>
<BR>
Yes, it works equally well with dynamic EMF as with generated models. You can try it right in the model editor on a dynamic instance! Evaluate one of your invariant constraint expressions on a dynamic object and you'll see.<BR>
<BR>
<BR>
<PRE>
> containing element?
any other platform.
best regards,
Gilbert
[1]<A HREF="https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786">https://bugs.eclipse.org/bugs/show_bug.cgi?id=255786</A>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-MKRiOzOr3EZFTMSvvb90--
Re: How to check the types of containment? [message #486372 is a reply to message #486194] |
Thu, 17 September 2009 09:20   |
--=-KbtoLmtfA+RaEcD1Ux3x
Hi, Gilbert,
Thanks for your patience in dealing with my inaccuracies ... I hope the
process has led you to an even better understanding of things than if I
had been more accurate! ;-) I've been away from the code so long,
now, that probably I should add a disclaimer to every message!
Christian
On Wed, 2009-09-16 at 18:58 +0200, Gilbert Mirenque wrote:
> Hi Christian
> Ohh :)
> Ok I now have the code from the example wizards. I now searched like
> hell for something about the ParserOptions as you mentioned before.
> Couldn't find anything. But fortunately I searched "implicit root class"
> and found a little test suite of yourself [1]. There to see that its
> name isn't PerserOptions but ParsingOptions ;) Now I could solve the
> problem. In the class ModelingLevel in the method setContext(..) I added
> those two lines in the M1 case:
> OCL ocl = helper.getOCL();
> ParsingOptions.setOption(ocl.getEnvironment(),
> ParsingOptions.implicitRootClass(ocl.getEnvironment()),
> EcorePackage.Literals.EOBJECT);
> Now it works finally :) Thanks a lot again for your patience Christian.
> Now I just need to export the modified plugin and add it into my eclipse.
> best regards,
> Gilbert
> [1]
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.ocl/tests/org.eclipse.ocl.ecore.tests/src/org/eclip se/ocl/ecore/tests/ParsingOptionsTest.java?root=Modeling_Pro ject&view=co
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
Thanks for your patience in dealing with my inaccuracies ... I hope the process has led you to an even better understanding of things than if I had been more accurate! ;-) I've been away from the code so long, now, that probably I should add a disclaimer to every message!<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<PRE>
Hi Christian
Ohh :)
best regards,
Gilbert
[1]
<A HREF=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.ocl/tests/org.eclipse.ocl.ecore.tests/src/org/eclip se/ocl/ecore/tests/ParsingOptionsTest.java?root=Modeling_Pro ject&view=co"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mdt/org .eclipse.ocl/tests/org.eclipse.ocl.ecore.tests/src/org/eclip se/ocl/ecore/tests/ParsingOptionsTest.java?root=Modeling_Pro ject&view=co</A>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-KbtoLmtfA+RaEcD1Ux3x--
Re: How to check the types of containment? [message #486385 is a reply to message #486200] |
Thu, 17 September 2009 09:28   |
--=-I4t1+fFEDydCrJQswETF
Hi, Gilbert,
cW
On Wed, 2009-09-16 at 19:22 +0200, Gilbert Mirenque wrote:
> Hi Christian,
> only for completeness...
> ...this result comes:
> Usage of non-standard "closure" iterator
> Can you please explain a little bit this expression:
> self.exportedEvents->forAll(ev|
> ev->closure(eContainer())->includes(self)
What this is intended to do is to use the closure() iterator to compute
the set of container elements (recursively) of the element and check
that "self" is in it. This is one way of testing whether an object is
contained in self's subtree; another would be to iterate that sub-tree
looking for "ev."
> Especially closure(eContainer())does what exactly? Does it return all
> elements contain ev? Then it should only be one and self should be
> included in this closure, right. Do I understand this correctly?
Almost. The closure iterator computes the transitive closure of the
body expression evaluated on the elements of the source collection (in
this case, the singleton set "Set{ev}"). So, it finds the eContainer()
of ev, and the eContainer() of that, etc. until it finds no more new
eContainers.
> Just for curiosity. The following expressions parses correctly
> self.eContents()
> ->select(x|
> x.oclIsTypeOf(CRUISeMetaModel::Event))
> ->includes(ev)
> But I wonder about self.eContents(). Is the semantic like I used it here?
I don't understand your question. One point to note is that eContents()
is not recursive: it computes only the immediately contained elements.
The problem that the closure-of-eContainer approach addresses is that
EObject does not provide a variant of eAllContents() that yields a
collection; the tree iterator result is useless in OCL.
> best regards,
> Gilbert
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
<BR>
cW<BR>
<BR>
<BR>
<PRE>
Hi Christian,
....this result comes:
</PRE>
</BLOCKQUOTE>
<BR>
What this is intended to do is to use the closure() iterator to compute the set of container elements (recursively) of the element and check that "self" is in it. This is one way of testing whether an object is contained in self's subtree; another would be to iterate that sub-tree looking for "ev."<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
Almost. The closure iterator computes the transitive closure of the body expression evaluated on the elements of the source collection (in this case, the singleton set "Set{ev}"). So, it finds the eContainer() of ev, and the eContainer() of that, etc. until it finds no more new eContainers.<BR>
<BR>
<BR>
<PRE>
self.eContents()
->select(x|
->includes(ev)
</PRE>
</BLOCKQUOTE>
<BR>
I don't understand your question. One point to note is that eContents() is not recursive: it computes only the immediately contained elements. The problem that the closure-of-eContainer approach addresses is that EObject does not provide a variant of eAllContents() that yields a collection; the tree iterator result is useless in OCL.<BR>
<BR>
<BR>
<PRE>
best regards,
Gilbert
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-I4t1+fFEDydCrJQswETF--
Re: How to check the types of containment? [message #486570 is a reply to message #486372] |
Fri, 18 September 2009 05:13  |
Hi Christian,
Yes, the process helped a lot to come more into it :)
best regards,
Gilbert
Current Time: Sat Jul 26 10:10:28 EDT 2025
Powered by FUDForum. Page generated in 0.08513 seconds
