Home » Archived » Riena » Use Ridgets without the UI concept
Use Ridgets without the UI concept [message #485304] Fri, 11 September 2009 05:42 Go to next message
Originally posted by: eclipsixusenet.mmartl.dfgh.net
I am currently trying to setup an eclipse RCP application that has the
normal Eclipse look but is using Riena under the hood.
I am currently trying to build a view which is using Rienas ridgets.
I have created a View that extends SubModuleView<MyController> and
MyController extends SubModuleController
I have started to use this in the normal Riena UI and it worked like a
charm in there.
But now I am having problems to have the Ridget and the Widgets in the
View to work together after I have changed my application class to
startup a normal eclipse RCP application.
Can somebody tell me what I have to do so the Ridgets can be used in a
normal eclipse application?
Thanks!
Michael
Re: Use Ridgets without the UI concept [message #485305 is a reply to message #485304] Fri, 11 September 2009 05:53 Go to previous messageGo to next message
Hi Michael,
(why do you want something that doesnot work like a charm :-) )
Ok seriously, there is a sample that shows just that. Its the project org.eclipse.riena.sample.app.client.rcpmail with
the launcher "Mail Sample (RCP UI)" that does exactly that. In org.eclipse.riena.sample.snippets there are also many
snippets that show how to use Ridgets without the navigation concept....
christian
Michael Huber schrieb:
> charm in there.
> Thanks!
> Michael
Re: Use Ridgets without the UI concept [message #485307 is a reply to message #485305] Fri, 11 September 2009 05:56 Go to previous message
Christian Campo schrieb:
> Hi Michael,
> org.eclipse.riena.sample.app.client.rcpmail with the launcher "Mail
> org.eclipse.riena.sample.snippets there are also many snippets that show
Cool, thanks for the fast reply.
Have a nice weekend!
Michael Huber
Re: Use Ridgets without the UI concept [message #583426 is a reply to message #485304] Fri, 11 September 2009 05:53 Go to previous message
Hi Michael,
christian
> charm in there.
> Thanks!
> Michael
Re: Use Ridgets without the UI concept [message #583443 is a reply to message #485305] Fri, 11 September 2009 05:56 Go to previous message
> Hi Michael,
Michael Huber
Previous Topic:Use Ridgets without the UI concept
Next Topic:riena security start
Current Time: Sat Jul 26 14:47:22 EDT 2025
Powered by FUDForum. Page generated in 0.05122 seconds
