Capabilities and Key Bindings [message #485167] |
Thu, 10 September 2009 12:58  |
Hello.
I'm wondering if Eclipse capabilities should also disable keybindings ?
I'm using Platform 3.4.2 with Subversive 0.7.8 plugin. I disable the "SVN
capability" provided by the subversive plugin, and all the UI
contributions disappear (views, perspectives, menu contributions, new
wizards, ...)
BUT the keybindings are still active !!
In the Project Explorer view, the CTRL-ALT-Z keys execute the "SVN update"
command.
And in the "Keys" preference page, the "Subversive key bindings scheme" is
available ...
I would like to have the SVN key bindings disabled, is it the capability
responsibility or should I use contexts to obtain this result ?
Thank for your help.
JM.D
Re: Capabilities and Key Bindings [message #485374 is a reply to message #485314] |
Fri, 11 September 2009 10:13  |
that's likely to blow up at some point, or at least generate a lot of messages in your log file (<workspace>/.metadata/.log)
If the keybindings are in a SVN scheme, why isn't setting RCP app scheme to the default good enough (the SVN keybindings won't work unless their scheme or some child scheme is active).
PW
FUDForum. Page generated in 0.10802 seconds
