Home » Eclipse Projects » Rich Client Platform (RCP) » [DataBinding] Does there exist a BufferedObservable?
[DataBinding] Does there exist a BufferedObservable? [message #485109] |
Thu, 10 September 2009 10:20  |
I'm currently evaluating a switch from jgoodies databinding
(using mostly self-defined SWT bindings) to jface/eclipse
databinding.
JGoodies databinding provides two useful concepts among others -
BufferedValueModel and PresentationModel - where I currently
found no counter parts in jface databinding, even though I'm
sure they could be easily built on top of the API. Before I roll
my own implementation I would like to ask, whether they are
already provided, but possibly with a different name (which would
be not surprising to me, because jface databinding clearly and
intentionally defines it's own concepts).
Here a short description of what I mean:
A BufferedValueModel is actually some IObservableValue which holds
a reference to another IObservableValue (like a delegate). We could
represent it by the following interface
interface IBufferedObservableValue extends IObservableValue {
void triggerCommit();
void triggerFlush();
Any modifications on the wrapper *only* act on the wrapper (which
has it's own value element), and *no* delegation happens to the
wrapped observable. But if anyone invokes triggerCommit() on the
IBufferedObservableValue, then the internally hold observable's
value is set with the current value of the buffer. On the other
hand, if triggerFlush() is used, the buffer is reset to the value of
the internally hold observable - quite simple but useful.
A Presentation model is more or less a access point for observables.
It is typically constructed with a bean and is used as the actual
API for clients that ask for observables. Clients aren't aware,
which kind of data is wrapped, they just ask for a property from a
bean (This is very similar to querying BeanProperties, but the
difference is that the PresentationModel already knows the bean,
so the client query *only* provides the property name to access the
corresponding property).
I would be happy to know, if anyone is aware of existing
implementation in jface databinding that already match these
concepts or - if not - if jface databinding would be interested
in some contribution of such concepts.
Thanks in advance,
Daniel Krügler
Re: [DataBinding] Does there exist a BufferedObservable? [message #485129 is a reply to message #485109] |
Thu, 10 September 2009 11:05   |
Daniel, see responses below:
In Eclipse DataBinding we don't have an equivalent observable, but we do
have a method of handling these situations:
1. To hold off on updating the model until a certain trigger action
occurs (e.g. the user clicks "Apply"), use an
UpdateValueStrategy(UpdateValueStrategy.POLICY_ON_REQUEST) for the
target-to-model update strategy:
bindingContext.bindValue(
WidgetProperties.text(SWT.Modify).observe(nameText),
BeanProperties.value("name").observe(person),
new UpdateValueStrategy(UpdateValueStrategy.POLICY_ON_REQUEST),
null);
When you are ready to update the model, you can either call
DataBindingContext.updateModels() (to update all bindings at once) or
Binding.updateTargetToModel() to update a single binding.
2. To hold off on updating the model until some cross-field validation
constraint is satisfied (e.g. in a date range, the start date must be on
or before the end date) you can use MultiValidator:
final IObservableValue startDateObs =
WidgetProperties.selection().observe(startDate);
final IObservableValue endDateObs =
WidgetProperties.selection().observe(endDate);
MultiValidator dateRangeValidator = new MultiValidator() {
protected IStatus validate() {
// Using ObservableTracker magic, MultiValidator knows which
// observables you access inside this method and listens for
// changes to them so that it can revalidate as necessary
Date start = startDateObs.getValue();
Date end = endDateObs.getValue();
if (start.compareTo(end) > 0)
return ValidationStatus.error(
"Start date cannot be later than end date");
return ValidationStatus.ok();
bindingContext.addValidationStatusProvider(dateRangeValidato r);
// Wrap the start and end date observables in validated wrappers so that
// they only change when the validation constraints are satisfied
dateRangeValidator.observeValidatedValue(startDateObs),
BeanProperties.value("startDate").observe(eventObject));
dateRangeValidator.observeValidatedValue(endDateObs),
BeanProperties.value("endDate").observe(eventObject));
This sounds like an inverse of BeanProperties, where instead of:
BeanValueProperty {
PropertyDescriptor property;
public Object getValue(Object source);
public void setValue(Object source, Object value);
you have:
BeanPropertyAccessor {
Object bean;
public Object getValue(String propertyName);
public void setValue(String propertyName, Object value);
If my understanding is correct, then no, we don't have anything like
that. Could you provide some sample code to show how this would be useful?
Matthew
Re: [DataBinding] Does there exist a BufferedObservable? [message #485273 is a reply to message #485129] |
Fri, 11 September 2009 02:48   |
After having written this description out of my head I tried to code
it down and found out that I gave some misleading descriptions :-(
Here a corrected form:
1) BufferedValueModel: Like in the following hierarchy:
public interface IBufferedObservable extends IObservable {
// Observable with value type boolean.class
IObservableValue getTriggerChannel();
void setTriggerChannel(IObservableValue trigger);
// Signals whether the buffered observable returns data from
// the wrapped observable or it's copy of the data:
boolean isBuffering();
public interface IBufferedObservableValue extends IBufferedObservable,
IObservableValue {
// The actually wrapped observable. It's value type is
// the value type of IBufferedObservableValue:
IObservableValue getObservable();
void setObservable(IObservableValue value);
Where are the triggerCommit() and triggerFlush() methods I were talking
about? They are provided by the presentation model described in bullet
(2), not by IBufferedObservableValue! The trigger channel is the
"button" that ensures that the buffered value will be flushed or
committed depending on it's value (true or false). PresentationModel is
the one who's pressing the "button".
2) PresentationModel:
interface PresentationModel extends IBufferedObservable {
// Flush all buffered models/observables:
// Commit all buffered models/observables:
// Get the observable that corresponds to the property name:
IObservableValue getModel(String property);
// Get the buffered observable that corresponds to the property name:
IBufferedObservableValue getBufferedModel(String property);
I omitted some further details, but the rough picture should now be
corrected, I hope ;-)
> null);
I agree that this is also some form of buffering strategy, but it is
local to one binding (which sometimes is an advantage, of-course) and
validation is also deferred according to my understanding of
POLICY_ON_REQUEST. This is an important difference, because we use
at several locations buffered models, which do validate on-the-fly,
but still don't transfer it's data until
PresentationModel.triggerCommit() is performed.
Thanks, this looks very cool! Nevertheless, I assume that I need
at least some form of adaption to the jgoodies binding for easier
adaption of the new binding.
> BeanValueProperty {
> you have:
> Object bean;
I wasn't very clear in my first descriptions and even made some
blatant errors describing the BufferedValueModel and PresentationModel.
So one difference is that PresentationModel is more or less a map
from property to observable (not to the value, even though for
convenience reasons they are also accessible). Let me give a sketch
in which way we use PresentationModel's and BufferedValueModel's in
our code:
1) Per service we get some simple value object (POJO):
class SomeDTO {
2) We currently need to wrap this POJO in a Bean, that simply forwards
all properties of the POJO but sends proper Java Bean property change
events (I'm very impressed that JFace databinding allows direct usage
of POJO's!).
3) Before entering the UI layer, the beans are wrapped as presentation
models:
PresentationModel pres = new PresentationModel(bean);
4) The UI layer gets the presentation model(s) and simply binds it's
observables "by name" to the corresponding widgets:
Text txt = new Text(parent, ...);
BufferedModel firstName = pres.getBufferedModel("firstName");
BindingFacade.bind(txt, firstName);
They are actually not aware of the direct nature of the complete
bean. They only need to now that there are some properties to
bind to widget's.
5) Especially inside a local scope (dialog/wizard) it's nice to
simply say on Ok-pressed: pres.triggerCommit() and on any cancelling
step (either cancel-pressed or undo) triggerFlush() which unrolls
the current changes back to the original ones.
Does that give a somewhat clearer picture?
Finally let me add one further remark: In the jgoodies databinding
framework you don't always need to have an individual observable
just to observe changes of some characteristic property: E.g. I
can add or remove change listener's to the buffering state of
the IBufferedObservableValue without access to the actual observable,
because in this case I only need the change deltas in the property
observer and nowhere else. I sometimes miss that fact in Jface
databinding, although it (usually) provides what I need: With further
wrapper techniques I could provide a *constant* view onto the
buffering state or the trigger channel (jface has ConstantObservable)
which do only exist such that clients can register
IValueChangeListener's on them.
Thanks for your interest,
Daniel
Re: [DataBinding] Does there exist a BufferedObservable? [message #485489 is a reply to message #485273] |
Fri, 11 September 2009 20:30   |
Just a short question is all this buffering needed because of undo/redo?
Or is there a deeper reason behind it?
Tom
> IObservableValue {
>> do have a method of handling these situations:
>> null);
>> on or before the end date) you can use MultiValidator:
>> BeanValueProperty {
>> you have:
>> Object bean;
>> useful?
> our code:
> class SomeDTO {
> of POJO's!).
> models:
> bind to widget's.
> Daniel
Re: [DataBinding] Does there exist a BufferedObservable? [message #485496 is a reply to message #485273] |
Sat, 12 September 2009 00:47   |
<snip>
I also went through the PresentationModel pdf at JGoodies.com which
filled in the rest of the picture. I think I follow you now.
> POLICY_ON_REQUEST
You are correct, I should have said POLICY_CONVERT. The basic data
binding pipeline is:
1. get source observable value
2. validate after get
3. convert to destination type
4. validate after convert
5. validate before set
6. set destination observable value
POLICY_ON_REQUEST does not execute this pipeline automatically, but
waits until Binding.updateModel() is called. POLICY_CONVERT, by
contrast, performs steps 1 through 4. POLICY_UPDATE performs all steps.
I not sure what you mean here.
> our code:
Question: from what I saw in the JGoodies slideshow, it looks like the
PresentationModel is intimately familiar with the model object. However
using strings to distinguish property names is not going to be portable
to, say, EMF. So I'm wonder However the way you describe it makes it
look like a generic switchboard:
interface IPresentationModel {
public IObservableValue getBufferedValue(IValueProperty)
public IObservableList getBufferedList(IListProperty)
public IObservableSet getBufferedSet(ISetProperty)
public IObservableMap getBufferedMap(IMapProperty)
We wouldn't need to create IBufferedObservable* interfaces since we can
use IObservable.isStale and IStaleListener to track whether each
observable is "buffering" (i.e. out of sync with model)
> of POJO's!).
Quick note, the POJO observables only send change events if the change
is initiated *through the IObservable's interface*, and only for that
particular observable instance. So setting values directly on the POJO
is discouraged since you don't get updates.
> models:
> bind to widget's.
This sounds essentially like a two-stage binding. The presentation
model would bind directly to the bean (or whatever type of model object)
using POLICY_CONVERT update policies. In turn each UI form would bind
its controls to the PM's observables.
void triggerCommit() { bindingContext.updateModels(); }
void triggerFlush() { bindingContext.updateTargets(); }
We've tried to reduce the cost of creating observables by not
registering listeners on the underlying object (e.g. bean) until you
actually add listeners to the observable--not sure if that mitigates
your concern but I thought I'd mention it.
I don't follow you here.
It sounds like this is something we should take a closer look at. Would
you submit a feature enhancement so we can discuss this further?
Matthew
Re: [DataBinding] Does there exist a BufferedObservable? [message #485614 is a reply to message #485496] |
Mon, 14 September 2009 03:00   |
>> POLICY_ON_REQUEST
Yes, you are right, this seems to be the right way to go!
>>> validation constraint is satisfied (e.g. in a date range, the start
>>> date must be on or before the end date) you can use MultiValidator:
I simply meant that even though JFace Databinding gives us a huge
amount of capabilities for free I probably still need to provide
an adaptor to the jgoodies-style data binding to ensure that large
code parts don't need to be touched yet.
This seems like an excellent approach to me! With the existing
property-framework in JFace Databinding this seems the best way to
go.
>> of POJO's!).
This really doesn't matter in our use-cases, because the POJO object
wont be touched by the layer which gets the presentation model.
>> bind to widget's.
Yes, this description is quite correct. I think for this reason my
own opinion to that was that it should be simply possible to
get the jgoodies presentation model adapted purely based on public
JFace DataBinding API. In some sense the PresentationModel can be
thought of a higher-level access level to JFace DataBinding
functionality.
<nod> yes that seems to be adequate operation assuming the user
selected the right policy for all corresponding bindings.
I agree that this is a good foundation the JFace DataBinding
architecture is based on, because it consequently supports
lazy-loading.
I tried to describe my workaround here. Users typically need to know,
when the buffering state of the presentation model changes. The JFace
way is to provide the observable of the buffer state as part of the
interface, the jgoodies way is to provide
void addBufferingChangeListener(...);
void removeBufferingChangeListener(...);
as part of the presentation model interface. The latter interface is
restricted, because users cannot unintentionally access the buffering
observable and actively change it's state, but with a normal (mutable)
JFace Databinding observable the user indeed might change the value
of this property. So my current workaround in the JFace Databinding
world is to provide immutable observables just to allow the user
to register as listener for it's changes.
Thanks for your encouraging opinion. I will start as soon as possible to
prepare this issue.
- Daniel
Re: [DataBinding] Does there exist a BufferedObservable? [message #488490 is a reply to message #487941] |
Mon, 28 September 2009 17:09  |
Tamar, see comments below:
Tamar Cohen wrote:
> Does anyone know the ETA for WorkbenchProperties support for undoable?
I do not work on Eclipse full-time and unfortunately I have very little
spare time to work on this at the moment. I'm hoping to get this done
in time for 3.6 though.
> Is this definitely going to be the way we go?
I think so, this seems to be the only solution proposed so far that
solves the major issue without crazy side effects or turning your code
into an ugly mess.
> What are we supposed to do in the meantime when we can't use EMF? Will
> we have to do something like Daniel is doing?
Using WorkbenchProperties.undoable() will essentially accomplish the
same thing that EMFEditProperties is doing.
Matthew
Current Time: Wed Jul 23 04:09:24 EDT 2025
Powered by FUDForum. Page generated in 0.97402 seconds
