Home » Modeling » TMF (Xtext) » [TCS] Operators
[TCS] Operators [message #4149] Wed, 27 February 2008 08:12 Go to next message
I struggle a lot with how TCS defines Operators. I found out through trial
and error that i.e. priorities in OperatorLists always have to start with
0 and increase by 1, that just saying operatored in a ClassTemplate means
implicitly that the anonymous OperatorList will be used, things like that.
Is there any documentation about TCS somewhere where such things would be
explained?
Is there any way planned to make such constraints as above explicit
somewhere so that i.e. Injector generation fails with a meaningful error
message?
Re: [TCS] Operators [message #4217 is a reply to message #4149] Wed, 27 February 2008 08:25 Go to previous messageGo to next message
Also,
could two different operatored ClassTemplates (not extending each other or
a common superclass) ever share the same OperatorList?
I see that for me, the Grammar generation works, and the parser compiles,
but the generated grammar only mentions one of the classtemplates in
production rule
priority_0
when 2 ClassTemplates are operatored (without named operatorList)
I guess this would be an error in the TCS definition, so it should be
forbidden to attempt so.
Re: [TCS] Operators [message #4848 is a reply to message #4217] Tue, 11 March 2008 10:26 Go to previous message
> trial and error that i.e. priorities in OperatorLists always have to
> start with 0 and increase by 1, that just saying operatored in a
> ClassTemplate means implicitly that the anonymous OperatorList will be
> be explained?
We are working on the documentation. In the mean time, you can look at
the TCS Zoo for examples (e.g., the LOTOS language uses advanced
operator features).
> message?
Yes, it is planned.
We are going to release a new version of the TCS constraints checker
that checks for more problems. Additionally, we can also accept bugzilla
entries for test cases presenting problems that should be detected.
> or a common superclass) ever share the same OperatorList?
Operator support in TCS basically corresponds to the need for left
recursion. In the case that you describe, you would not have
left-recursion in one of the case, would you?
When there is no left-recursion problem, you should not need to add the
operator to the table. That being said, we are of course interested by a
counterexample.
> compiles, but the generated grammar only mentions one of the
> classtemplates in production rule
> priority_0 when 2 ClassTemplates are operatored (without named
> operatorList)
You are correct.
Frédéric Jouault
Previous Topic:Availability?
Next Topic:[TCS] Expression and AndExp
Current Time: Wed Sep 03 03:03:09 EDT 2025
Powered by FUDForum. Page generated in 0.04817 seconds
