Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Code Beautifying
[Acceleo] Code Beautifying [message #484528] Tue, 08 September 2009 02:57 Go to next message
Hey,
just started yesterday my first steps with Acceleo. I've some general
questions concerning the beautification of the generated code.
1. Is there a common rule for indentation? When i write my templates
with normal indentation, like this
[file (testContext.name.concat('.ttcn3'), false)]
module [testContext.name/]{
[for (dPool : DataPool | testContext.allDataPool)]
[for (dp:DataPartition|dPool.ownedPartition)]
[genTypes(dp)/]
[/for]
[/for]
[/file]
the outcoming is very ugly aligned, since the whole [genTypes/] part is
too much indented.
2. How to use the seperator(',') construct correctly in a for-loop.
Currentlty, the , will be inserted in the next line, not after the
generated line
boolean confirmationExpected
, integer data optional
The loop looks like
[for (p:Property | c.oclAsType(Classifier).attribute) separator(',')]
[if (p.type.oclIsTypeOf(PrimitiveType))][iterateBasicType(p)/]
[else]
Complex
[/if]
[/for]
3. Is it possible to pass a Set as a template parameter?
4. I've tried to pass a parameter like c.oclAsKindOf(Class), where c is
a Classifier, but Acceleo told me, that such an template doesn't exist.
Well, the template is there.
[template public class2type(c:Class)]
Is it possible to downcast an object during the invocation of a template?
Thanks a lot
/Timothy
Re: [Acceleo] Code Beautifying [message #484554 is a reply to message #484528] Tue, 08 September 2009 04:29 Go to previous message
--------------020205090400080304000605
Hi Timothy,
Comments inlined below.
Timothy Marc a
Previous Topic:xtext for metamodeling
Next Topic:Check: How to activate the EMF Validation Adapter?
Current Time: Wed Jul 23 06:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.03355 seconds
