Home » Modeling » M2T (model-to-text transformation) » Check: How to activate the EMF Validation Adapter?
Check: How to activate the EMF Validation Adapter? [message #373318] Wed, 29 July 2009 09:44 Go to next message
I am currently trying to include my constraints that are in oAW check files
into the standard EMF validation.
As far as I have seen, the extension point
"org.eclipse.xtend.typesystem.emf.checks" is the new EMF Validation Adapter.
Unfortunately, I cannot get this working - it simply does nothing... No log
entries, no exceptions, no registering of an EValidator.
In the extension point description it says:
"To enable this extension point, make sure the plug-in is loaded, e.g. by
calling Activator.getDefault() explicitly. Otherwise the extensions will not
be parsed and no EValidator will be registered."
But this extension point is contained in the plugin
org.eclipse.xtend.typesystem.emf, which has no Activator :-( So how do I
enable this extension point?
It would be great if anybody had a working example of this - thanks in
advance!
Kai
Re: Check: How to activate the EMF Validation Adapter? [message #484484 is a reply to message #373318] Mon, 07 September 2009 12:56 Go to previous messageGo to next message
I'm also curious about this. Had the same problem. Any hints anyone?
Hauke
Kai Kreuzer schrieb:
> Hello,
> advance!
> Kai
Re: Check: How to activate the EMF Validation Adapter? [message #484553 is a reply to message #373318] Tue, 08 September 2009 04:20 Go to previous messageGo to next message
Hi Kai,
please ensure that the plugin org.eclipse.xtend.typesystem.emf.ui is
registered. It will call CheckRegistry.getInstance() which in turn will
register any validator.
If this does not work, please file a ticket.
Sebastian
> Hello,
> advance!
> Kai
Re: Check: How to activate the EMF Validation Adapter? [message #484640 is a reply to message #484553] Tue, 08 September 2009 10:22 Go to previous messageGo to next message
> registered.
Where and how? The extension point documentation does not say anything
about this step.
The plugin is activated in my run configuration but nothing else.
Hauke
Sebastian Zarnekow schrieb:
> Hi Kai,
> Regards,
> Sebastian
Re: Check: How to activate the EMF Validation Adapter? [message #484644 is a reply to message #484640] Tue, 08 September 2009 11:07 Go to previous messageGo to next message
Hi Hauke,
please file a ticket as we should have a look at this one.
So far you'll have to register the CheckValidatorAdapter on your own.
Please have a look at the EValidator.Registry.
Sorry for inconvenience,
Sebastian
> > registered.
> about this step.
> Hauke
>> Hi Kai,
>> will register any validator.
>> Regards,
>> Sebastian
Re: Check: How to activate the EMF Validation Adapter? [message #484805 is a reply to message #484644] Wed, 09 September 2009 07:56 Go to previous message
Hi Sebastian,
registering manually works fine. I filed a ticket at
https://bugs.eclipse.org/288930
Hauke
Previous Topic:[Acceleo] Code Beautifying
Next Topic:[XPAND] 50 % slowdown compared to OAW XPAND
Current Time: Sun Jul 27 14:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.25155 seconds
