Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » comparing 0.95 with 1.0
comparing 0.95 with 1.0 [message #479944] Thu, 13 August 2009 04:24 Go to next message
Hi!
I am considering porting our Erlang IDE (http://erlide.org) on DLTK, but
am stuck on Eclipse 3.4, which means DLTK 0.95.
I couldn't find an executive summary of things that are changed in 1.0,
is there any?
The big thing I notice is the use of EMF, which probably has a bunch of
new stuff in the 3.5 release.
Will there be any maintenance on 0.95? I suppose not, but it doesn't
hurt to ask.
best regards,
Vlad
Re: comparing 0.95 with 1.0 [message #479962 is a reply to message #479944] Thu, 13 August 2009 05:38 Go to previous messageGo to next message
Hi Vlad,
DLTK 1.0 is compatible with Eclipse 3.4 (you should use appropriate
version of EMF as well).
There is no maintenance planned for 0.95, since most problems could not
be solved without changing API. And API changes require to increment
version number.
Alex
Vlad Dumitrescu wrote:
> Hi!
> is there any?
> hurt to ask.
> best regards,
> Vlad
Re: comparing 0.95 with 1.0 [message #479991 is a reply to message #479962] Thu, 13 August 2009 07:31 Go to previous messageGo to next message
Is it? That's great, I suppose I got the wrong EMF version somehow. I
will try again.
Thanks for the answer!
/Vlad
Re: comparing 0.95 with 1.0 [message #484305 is a reply to message #479962] Sat, 05 September 2009 18:46 Go to previous messageGo to next message
Hmm, would I be foolish to ask: is it compatible with 3.3 as well?
Gergo
Re: comparing 0.95 with 1.0 [message #484342 is a reply to message #484305] Sun, 06 September 2009 23:38 Go to previous message
> Hmm, would I be foolish to ask: is it compatible with 3.3 as well? Thanks,
> Gergo
DLTK Core, Javascript and Ruby should are believed to be compatible with
3.3.
DLTK Tcl is compatible with 3.4+.
Alex
Previous Topic:generating an IDE
Next Topic:TCL Open Method
Current Time: Wed Jul 23 17:03:45 EDT 2025
Powered by FUDForum. Page generated in 0.04272 seconds
