Home » Eclipse Projects » JFace » How To Set Size For InputDialog Properly
How To Set Size For InputDialog Properly [message #482909] Fri, 28 August 2009 10:04 Go to next message
Originally posted by: runzhou.li.gmail.com
I don't really want to rewrite a dialog that does the same thing as
InputDialog, but the size of InputDialog is not desired.
How should I set a size for InputDialog properly?
Thanks in advance!
Runzhou Li
Re: How To Set Size For InputDialog Properly [message #483769 is a reply to message #482909] Wed, 02 September 2009 17:19 Go to previous messageGo to next message
How about writing a subclass and overridding configureShell? For example,
protected void configureShell(Shell shell) {
super.configureShell(shell);
shell.setBounds(100, 100, 100, 100); // or whatever you want
"Runzhou Li" <runzhou.li@gmail.com> wrote in message
news:h78o4h$c3l$1@build.eclipse.org...
> Thanks in advance!
> Runzhou Li
Re: How To Set Size For InputDialog Properly [message #484254 is a reply to message #483769] Fri, 04 September 2009 15:49 Go to previous messageGo to next message
Thank you Will.
I also have a minor question, what's the best way to center this dialog?
Currently I'm doing something like this:
protected void configureShell( Shell shell ) {
Point centerPoint = Geometry.centerPoint(
shell.getParent().getBounds() );
super.configureShell( shell );
shell.setBounds( centerPoint.x, centerPoint.y, 800, 400 );
Apparently it's not the perfect way, it somewhat places the dialog near
middle, but not as perfect as the original InputDialog.
"Will Horn" <will.horn@gmail.com> 写入消息
news:h7mngu$br0$1@build.eclipse.org...
>> Hi,
>> Thanks in advance!
>> Runzhou Li
Re: How To Set Size For InputDialog Properly [message #486752 is a reply to message #484254] Fri, 18 September 2009 18:42 Go to previous messageGo to next message
Maybe:
shell.setBounds(shell.getBounds().x, shell.getBounds().y, 800, 400);
news:h7rr08$5uk$1@build.eclipse.org...
> Thank you Will.
>> example,
>>> Hi,
>>> Thanks in advance!
>>> Runzhou Li
Re: How To Set Size For InputDialog Properly [message #487309 is a reply to message #486752] Tue, 22 September 2009 13:56 Go to previous message
I guess not. The way I was doing is acceptable, but not precise.
news:h912di$1v7$1@build.eclipse.org...
> Maybe:
>> Thank you Will.
>>> example,
>>>> Hi,
>>>> Thanks in advance!
>>>> Runzhou Li
Previous Topic:How to display all the selection when the filtering option is true in content proposal provider
Next Topic:TreeViewer Auto Scroll
Current Time: Sun Jul 27 15:31:47 EDT 2025
Powered by FUDForum. Page generated in 0.04734 seconds
