Home » Eclipse Projects » GEF » Cannot change the link line from straight line to another path.
Cannot change the link line from straight line to another path. [message #484063] Fri, 04 September 2009 03:29 Go to next message
Hi all,
I have the following problem,
there is a composite figure A with compartment which contains figure B1, B2.
The connection from A to B is always straight line and cannot be modeled - it is always straight line.
The links between B1 and B2 can be modeled as I want.
What can I do to be able to change the straight line of the connection from A to B1 or B2 to have the shape I decide?
Ivo
p.s. if it is important - the starting and ending points of these connections are fixed
Re: Cannot change the link line from straight line to another path. [message #484181 is a reply to message #484063] Fri, 04 September 2009 09:57 Go to previous message
Ivo Petkov wrote:
> Hi all,
> B2.
> Regards,
> Ivo
By supposing you have a different connection edit part from A to B then
A to B1,B2, you could use a BendpointEditPolicy on that edit part.
Pascal Gélinas | Software Developer
*Nu Echo Inc.*
http://www.nuecho.com/ | http://blog.nuecho.com/
*Because performance matters.*
Previous Topic:How to translate absolute mouse coordinates to relative coordinates in an editor
Next Topic:Zest: separated two way links
Current Time: Sat Jul 26 20:38:20 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
