Home » Eclipse Projects » Rich Client Platform (RCP) » Re: Edit, Cut, Copy
Re: Edit, Cut, Copy [message #484142] Fri, 04 September 2009 08:39
Kevin Pollet schrieb:
> I have an eclipse application. I want to put the default eclipse command
> in it. For example for the copy menu I have extented the
> org.eclipse.ui.menus anp put a command with id org.eclipse.ui.edit.copy.
> My problem is that menu is already active why ?
> Best regards,
> Kevin
because copy-command only needs some control to be in Focus.. and then
calls the copy handler which uses the execution event to find the
control with focus and then calls copy() on that control.
So why shouldn't it be active?
Previous Topic:How to set the default location in New Wizard for GMF plug-in
Next Topic:3.5 RCP Export Do We have a Bug?
Current Time: Mon Jul 21 03:39:36 EDT 2025
Powered by FUDForum. Page generated in 0.10316 seconds
