Home » Modeling » Epsilon » [EuGENia | EOL] delete creation tool
[EuGENia | EOL] delete creation tool [message #483784] Wed, 02 September 2009 20:20 Go to next message
I'm trying to delete some creation tools so that they don't appear on
the tools palette.
I've tried experimenting different ways but if I delete any tool then in
gmfmap the tool property in node mapping selects some other tool
available. I want it to map to no tool. I tried deleting from gmftool
anf gmfmap as well. But no luck. Please help me with this.
var rule = ECore!EClass.all.selectOne(o|o.name = 'Rule');
ruleTool = GmfTool!CreationTool.selectOne(t|t.title = 'Rule');
var nodeMapping =
GmfMap!NodeMapping.all.selectOne(nm|nm.domainMetaElement = rule);
--delete nodeMapping.tool;
nodeMapping.tool = ruleTool;
-- even though I do this it does not maps the same tool instead some
other tool is mapped
var r = ECore!EClass.all.selectOne(o|o.name = 'OclExp');
var nodeMapping =
GmfMap!NodeMapping.all.selectOne(nm|nm.domainMetaElement = r);
--this deletes the tool but in gmfmap some other random tool is selected.
Mihir
Re: [EuGENia | EOL] delete creation tool [message #483833 is a reply to message #483784] Thu, 03 September 2009 05:41 Go to previous messageGo to next message
Hi Mihir,
You need to unset nodeMapping.tool. An example follows:
------ notool.emf ------
@namespace(uri="notool", prefix="notool")
package notool;
@gmf.diagram
class Model {
val ModelElement[*] contents;
@gmf.node(label="name")
abstract class ModelElement {
attr String name;
class A extends ModelElement {}
class B extends ModelElement {}
class C extends ModelElement {} // We don't want a tool for this class
class D extends ModelElement {}
class E extends ModelElement {}
------ ECore2GMF.eol ------
var tool = GmfTool!CreationTool.all.selectOne(t|t.title = 'C');
var nodeMapping = GmfMap!NodeMapping.all.selectOne(nm|nm.tool = tool);
delete tool;
nodeMapping.unset('tool');
nodeMapping.tool.println();
operation Any unset(feature:String) {
var sf = self.eClass().eAllStructuralFeatures.
selectOne(sf|sf.name = feature);
self.eUnset(sf);
Dimitris
Mihir wrote:
> Hello,
> the tools palette.
> var nodeMapping =
> var nodeMapping =
> Mihir
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
{solved} [EuGENia | EOL] delete creation tool [message #483865 is a reply to message #483833] Thu, 03 September 2009 08:16 Go to previous messageGo to next message
Thanks a million Dimitris.. it solved my problem.. :)
Mihir
Dimitris Kolovos wrote:
> Hi Mihir,
> package notool;
> @gmf.diagram
> class Model {
> attr String name;
> delete tool;
> self.eUnset(sf);
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> the tools palette.
>> in gmfmap the tool property in node mapping selects some other tool
>> var nodeMapping =
>> var nodeMapping =
>> Thanks,
>> Mihir
Re: [EuGENia | EOL] delete creation tool [message #580178 is a reply to message #483784] Thu, 03 September 2009 05:41 Go to previous messageGo to next message
Hi Mihir,
package notool;
@gmf.diagram
class Model {
attr String name;
delete tool;
self.eUnset(sf);
Dimitris
Mihir wrote:
> Hello,
> the tools palette.
> var nodeMapping =
> var nodeMapping =
> Mihir
{solved} [EuGENia | EOL] delete creation tool [message #580219 is a reply to message #483833] Thu, 03 September 2009 08:16 Go to previous messageGo to next message
Mihir
> Hi Mihir,
> package notool;
> @gmf.diagram
> class Model {
> attr String name;
> delete tool;
> self.eUnset(sf);
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> the tools palette.
>> var nodeMapping =
>> var nodeMapping =
>> Thanks,
>> Mihir
Re: [EuGENia | EOL] delete creation tool [message #758285 is a reply to message #483784] Tue, 22 November 2011 09:53 Go to previous messageGo to next message
Hello Dimitrios,
when i tried to use your code in ECore2GMF.eol to delete a Tool, i got the following error :
Method 'eClass' not found.
How can that be ?
Greeting
Snakebyte
Re: [EuGENia | EOL] delete creation tool [message #758312 is a reply to message #758285] Tue, 22 November 2011 12:07 Go to previous messageGo to next message
It'd be really hard to guess without additional information. See http://eclipse.org/gmt/epsilon/doc/articles/minimal-examples/
Dimitris
Re: [EuGENia | EOL] delete creation tool [message #758317 is a reply to message #758312] Tue, 22 November 2011 12:22 Go to previous messageGo to next message
Take this example again :
@namespace(uri="argumentmodel", prefix="argumentmodel")
@gmf(foo="bar")
package argumentmodel;
@gmf.diagram(onefile="false")
class ArgumentModel {
   val Claim[*] claims;
   val Assumption[*] assumptions;
class Claim {
   attr String name;
   attr String description;
   @gmf.link(incoming="true")
   val ArgumentStrategy[*] ConnectArg;
@gmf.node(label="name",phantom="true")
class ArgumentStrategy {
   attr String name;
   ref Assumption [*] assumptions;
class Assumption {
   attr String name;
now i tried to add the following in the ECore2GMF.eol:
var tool = GmfTool!CreationTool.all.selectOne(t|t.title = 'assumptions');
delete tool;
self.eUnset(sf);
What i want to achieve is, that i dont want to see the relation "assumptions" in the connections palette.
and i get the error:
what im doing wrong ?
[Updated on: Tue, 22 November 2011 14:16] by Moderator
Re: [EuGENia | EOL] delete creation tool [message #758352 is a reply to message #758317] Tue, 22 November 2011 16:09 Go to previous messageGo to next message
It's not a NodeMapping, it's a LinkMapping you're looking for. The following should work:
var tool = GmfTool!CreationTool.all.selectOne(t|t.title = 'Assumptions');
var linkMapping = GmfMap!LinkMapping.all.selectOne(nm|nm.tool = tool);
delete tool;
linkMapping.unset('tool');
self.eUnset(sf);
Dimitris
Re: [EuGENia | EOL] delete creation tool [message #758379 is a reply to message #758352] Tue, 22 November 2011 18:17 Go to previous message
Works. Big Thanks !
Previous Topic:[Eugenia] Validation Problem
Next Topic:[Eugenia] Negation
Current Time: Tue Jul 22 23:02:19 EDT 2025
Powered by FUDForum. Page generated in 0.05474 seconds
