Home » Eclipse Projects » Standard Widget Toolkit (SWT) » display.getClientArea is incorrect (gtk)
display.getClientArea is incorrect (gtk) [message #483212] Mon, 31 August 2009 11:22 Go to next message
Dear list,
Please consider the following snippet.
import org.eclipse.swt.graphics.Rectangle;
public class GtkClientArea {
public static void main(final String[] args) {
final Display display = new Display();
final Rectangle clientArea = display.getClientArea();
System.out.println("Client area: " + clientArea.toString());
display.dispose();
On my system (debian lenny, gtk), it gives: "Client area: Rectangle {0,
0, 1280, 1024}". My screen is indeed 1280*1024, but I have (as is usual
in Linux) a top bar and a bottom task bar, meaning that this is not the
area which can be used by applications.
If in my app I try to create a shell and set its size to 1280*1024, when
opening it, I see it is automatically resized after opening to (about)
1280*974, I guess, by the windows manager.
So the method getClientArea does not seem to return the area my
application can use to display itself. Is it a bug?
Thank you.
Olivier
Re: display.getClientArea is incorrect (gtk) [message #483490 is a reply to message #483212] Tue, 01 September 2009 14:01 Go to previous messageGo to next message
This is logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=33659 .
Grant
"Olivier Cailloux" <mlsmg@ulb.ac.be> wrote in message
news:h7gprc$nlr$1@build.eclipse.org...
> Dear list,
> import org.eclipse.swt.widgets.Display;
> display.dispose();
> Thank you.
> Olivier
Re: display.getClientArea is incorrect (gtk) [message #483660 is a reply to message #483490] Wed, 02 September 2009 09:54 Go to previous message
Ooops. Being new at SWT, I didn't thought I would have found a real bug
but rather something I was not understanding correctly, so I did not
even bother to check there... My fault!
Thank you for your time.
Olivier
> Grant
>> Dear list,
>> display.dispose();
>> Thank you.
>> Olivier
Previous Topic:setting margin for the nested composite.
Next Topic:Create an DragSourceEvent
Current Time: Wed Jul 23 15:36:45 EDT 2025
Powered by FUDForum. Page generated in 0.03866 seconds
