Double-Click Text Selections [message #483541] |
Tue, 01 September 2009 20:43  |
I have a partition scanner defined for an editor to provide syntax
highlighting, hover help and contents assist. I'd also like the
double-click action at an offset in the text to select the entire
partition containing the offset.
Is there a way to do this leveraging the partitions I already have defined?
- Paul
Re: Double-Click Text Selections [message #483775 is a reply to message #483772] |
Wed, 02 September 2009 18:24  |
Thanks. I wasn't sure about the difference.
Curtis Windatt wrote:
> I don't think you'll be able to get an answer here. This forum is for
> questions about PDE code. You might have more luck in the Eclipse
> platform forum, as the editor framework is part of it.
Re: Double-Click Text Selections [message #601122 is a reply to message #483541] |
Wed, 02 September 2009 05:10  |
> defined?
> - Paul
Re: Double-Click Text Selections [message #601131 is a reply to message #483591] |
Wed, 02 September 2009 05:11  |
Sorry for the wrong reply.
>> defined?
>> Thanks,
>> - Paul
Re: Double-Click Text Selections [message #601136 is a reply to message #483541] |
Wed, 02 September 2009 17:38  |
I don't think you'll be able to get an answer here. This forum is for questions about PDE code. You might have more luck in the Eclipse platform forum, as the editor framework is part of it.
Re: Double-Click Text Selections [message #601143 is a reply to message #601136] |
FUDForum. Page generated in 0.04188 seconds
