Newbie question: background services/shared objects [message #483265] |
Mon, 31 August 2009 15:28  |
Originally posted by: k.sramko.a-cube.eu
Hi Group,
I'm new to Eclipse and RPC. As first project I'm trying to build a client
for a online-game, containing three main parts:
- the RPC-based frontend
- a local database
- a HTTP-Client for gathering informations and executing commands to the
online-game
I'm making very good progress on the RPC-part. A standalone database is no
problem and the HTTP-Client (based on Apache's HTTP-Client) isn't a
problem, too. But I have no clue, how to bind the three parts into one
application.
The HTTP-Client has to be always active, to keep the session alive.
Frequently it should check the online-game for new information. If a new
information exists, it should be written into the database and the
views/editors have to be updated. The database should be embedded into the
application (SQLite/HSQLDB) and the connection should be active while my
program runs and should be shared and pooled for the RCP-GUI and the
HTTP-Client.
How to start separate threats at start-up and bind them to the workbench?
Can somebody give me a link to a framework or even better to a How-To?
Is the 'plug-in' functionality responsible for such task or 'Jobs'? Or is
the answer somewhere in 'org.eclipse.ui.services'?
I've searched the internet and the eclipse page a lot, without finding an
answer on that.
Thanks for your hints.
Kiril
Re: Newbie question: background services/shared objects [message #483271 is a reply to message #483265] |
Mon, 31 August 2009 16:03   |
Hi Kiril,
This sounds like a lot of fun and you have come to the perfect place for such
an application design. The answer to your questions is "OSGi services". You
have one OSGi bundle/plugin/module (same thing) that takes care of the
database and exposes the interface using an OSGi service. You have a HTTP
client in a separate OSGi bundle that pokes around on the internet and
exposes its interface also via an OSGi service. Finally you use both services
in yet another OSGi bundle which is your RCP core plugin.
Voila, the perfect solution for your challenge and using OSGi makes it even
more fun.
Now If you are new to OSGi then please read the first chapter of the
excellent online book by Neil Bartlett on this address:
http://neilbartlett.name/blog/osgibook/ and see if you can stop reading.
Here is a quick link to a working services example on OSGi
http://java.dzone.com/articles/simple-osgi-service but there are many more.
Wim Jongman
Posted with Salvo, the Eclipse based newsreader.... On a Mac!!
> Hi Group,
> - a local database
> online-game
> application.
> HTTP-Client.
> answer on that.
> Kiril
FUDForum. Page generated in 0.03274 seconds
