Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Problem with svn and jmunit exclusions
Problem with svn and jmunit exclusions [message #483060] Sun, 30 August 2009 10:32 Go to next message
Hello!
I use Subversion for my project storage and, thus, use project "**/.svn/*"
exclusion for removing all svn files from build. I start use jmunit and
set $my_project->Mobile Tools for Java->Enable JMUnit. Unfortunately,
setting this option rewrite my exclusion with
"**/*Test.java|**/*TestSuite.java". Then I set $my_project->Mobile Tools
for Java->Disable JMUnit exclusions for my project is empty. So,
Enable/Disable JMUnit simply rewrite all exclusions for project. But it
must only set and clear only "**/*Test.java|**/*TestSuite.java".
Pls, fix this problem.
PS I use MTJ 1.0
Re: Problem with svn and jmunit exclusions [message #483158 is a reply to message #483060] Mon, 31 August 2009 08:20 Go to previous messageGo to next message
Hi Andrey,
This problem was resolved on MTJ 1.0.1 RC1
Re: Problem with svn and jmunit exclusions [message #483257 is a reply to message #483158] Mon, 31 August 2009 14:46 Go to previous messageGo to next message
Sorry, but i was wrong. This problem persist on mtj 1.0.1RC1.
Bug 288165 was opened to fix this issue.
Diego
Re: Problem with svn and jmunit exclusions [message #483267 is a reply to message #483257] Mon, 31 August 2009 15:40 Go to previous messageGo to next message
Is it right that this bug already fixed?
So I can update my MTJ 1.0 to MTJ 1.0.1 RC for have this fix? Or I should
wait MTJ 1.0.1 release? BTW When do you plane to do it?
Re: Problem with svn and jmunit exclusions [message #483447 is a reply to message #483267] Tue, 01 September 2009 11:58 Go to previous messageGo to next message
This issue will be available in the MTJ 1.0.1RC2 that will be publish later today.
Re: Problem with svn and jmunit exclusions [message #483450 is a reply to message #483447] Tue, 01 September 2009 12:03 Go to previous messageGo to next message
Great! Thanks!
Also, pls, see this annoying problem
http://www.eclipse.org/newsportal/article.php?id=770&gro up=eclipse.dsdp.mtj#770
Re: Problem with svn and jmunit exclusions [message #483491 is a reply to message #483450] Tue, 01 September 2009 14:05 Go to previous messageGo to next message
The 1.0.1RC2 is available for testing. Please try it and notify us if it solved your problem.
Diego
Re: Problem with svn and jmunit exclusions [message #576956 is a reply to message #483060] Mon, 31 August 2009 08:20 Go to previous messageGo to next message
Hi Andrey,
This problem was resolved on http://download.eclipse.org/dsdp/mtj/downloads/drops/S-1.0.1 RC1-200908251016/index.html
Re: Problem with svn and jmunit exclusions [message #577018 is a reply to message #576956] Mon, 31 August 2009 14:46 Go to previous messageGo to next message
Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=288165 was opened to fix this issue.
Diego
Re: Problem with svn and jmunit exclusions [message #577027 is a reply to message #483257] Mon, 31 August 2009 15:40 Go to previous messageGo to next message
Re: Problem with svn and jmunit exclusions [message #577207 is a reply to message #483267] Tue, 01 September 2009 11:58 Go to previous messageGo to next message
Re: Problem with svn and jmunit exclusions [message #577225 is a reply to message #577207] Tue, 01 September 2009 12:03 Go to previous messageGo to next message
Great! Thanks!
Re: Problem with svn and jmunit exclusions [message #577396 is a reply to message #483450] Tue, 01 September 2009 14:05 Go to previous message
The http://download.eclipse.org/dsdp/mtj/downloads/drops/S-1.0.1 RC2-200909011251/index.html is available for testing. Please try it and notify us if it solved your problem.
Diego
Previous Topic:Preprocessing dependant projects
Next Topic:MTJ 1.0.1 RC2 Available
Current Time: Fri Oct 31 12:43:34 EDT 2025
Powered by FUDForum. Page generated in 0.10439 seconds
