Home » Eclipse Projects » DSDP - Target Management » Cannot Transfer Files
Cannot Transfer Files [message #481150] Wed, 19 August 2009 15:05 Go to next message
I use RSE to manage files on my remote system. Recently I have been
unable to transfer files from my workstation to any of my systems using
RSE. When I transfer a file I see the progress indicator refreshing the
folder but the file never gets transfered and no errors are thrown or
logged. I have tried uninstalling and reinstalling TM and have even
tried a fresh install of eclipse 3.5 with TM3.1 and it still fails to
transfer. This was working before. I have tried on several different
servers but with no luck. Please help.
Mike
Re: Cannot Transfer Files [message #481368 is a reply to message #481150] Thu, 20 August 2009 12:19 Go to previous messageGo to next message
Hi Mike,
Which client are you on (i.e. windows, linux, etc.)? Could you describe how
you do the transfers? Is this via copy/paste from the "Local" system to a
remote system?
Dave
"Michael Yara" <michaely@i9technologies.com> wrote in message
news:h6hiek$t6u$1@build.eclipse.org...
> Hello,
> I use RSE to manage files on my remote system. Recently I have been unable
> to transfer files from my workstation to any of my systems using RSE. When
> I transfer a file I see the progress indicator refreshing the folder but
> the file never gets transfered and no errors are thrown or logged. I have
> tried uninstalling and reinstalling TM and have even tried a fresh install
> of eclipse 3.5 with TM3.1 and it still fails to transfer. This was working
> before. I have tried on several different servers but with no luck. Please
> help.
> Mike
Re: Cannot Transfer Files [message #482771 is a reply to message #481368] Thu, 27 August 2009 17:42 Go to previous messageGo to next message
This is a windows system and I transfer using copy/paste and/or drag and
drop. I cannot transfer files from my local system to a remote system or
from remote to remote. If i go from local to remote the previously
described behavior occurs. If i do a remote to remote i get this error.
Message reported from file system: java.io.FileNotFoundException:
C:\Documents and
Settings\Mike\XXX\Workspaces\XXXXXXXXX\RemoteSystemsTempFile s\PHONE.XXXXXXXXXX.COM\root\old\encode_template.xml
(The system cannot find the path specified)
Xs masking sensitive data.
David McKnight wrote:
> Hi Mike,
> remote system?
> Dave
>> Hello,
>> help.
>> Thanks,
>> Mike
Re: Cannot Transfer Files [message #482781 is a reply to message #482771] Thu, 27 August 2009 19:02 Go to previous messageGo to next message
I just tried on a fresh install of Eclipse 3.5 with TM 3.1 pulled from
the update site, new workspace and still shows the same behavior.
> C:\Documents and
>> Hi Mike,
>> describe how you do the transfers? Is this via copy/paste from the
>> "Local" system to a remote system?
>> Thanks,
>> Dave
>>> Hello,
>>> using RSE. When I transfer a file I see the progress indicator
>>> refreshing the folder but the file never gets transfered and no
>>> errors are thrown or logged. I have tried uninstalling and
>>> reinstalling TM and have even tried a fresh install of eclipse 3.5
>>> with TM3.1 and it still fails to transfer. This was working before. I
>>> have tried on several different servers but with no luck. Please help.
>>> Thanks,
>>> Mike
Re: Cannot Transfer Files [message #483175 is a reply to message #482781] Mon, 31 August 2009 09:21 Go to previous messageGo to next message
Hi Michael,
It's possible that the problem is the file path is too long for Windows
(there are path restrictions). Could you try this using a workspace with a
shorter path? For example, instead of using this:
C:\Documents and Settings\Mike\XXX\Workspaces\XXXXXXXXX\
could you try somethign like this:
C:\Workspace\
Dave
news:h7739t$7fv$1@build.eclipse.org...
>I just tried on a fresh install of Eclipse 3.5 with TM 3.1 pulled from the
>> C:\Documents and
>>> Hi Mike,
>>> how you do the transfers? Is this via copy/paste from the "Local"
>>> Thanks,
>>> Dave
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #484892 is a reply to message #483175] Wed, 09 September 2009 11:50 Go to previous messageGo to next message
David,
Unfortunately your suggestion did not work. I thought for sure this was
the issue since I am seeing it occur even on a fresh install with a
brand new workspace.
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Re: Cannot Transfer Files [message #582192 is a reply to message #481150] Thu, 20 August 2009 12:19 Go to previous messageGo to next message
Hi Mike,
remote system?
Dave
> Hello,
> help.
> Mike
Re: Cannot Transfer Files [message #582337 is a reply to message #481368] Thu, 27 August 2009 17:42 Go to previous messageGo to next message
C:\Documents and
> Hi Mike,
> remote system?
> Dave
>> Hello,
>> help.
>> Thanks,
>> Mike
Re: Cannot Transfer Files [message #582352 is a reply to message #482771] Thu, 27 August 2009 19:02 Go to previous messageGo to next message
> C:\Documents and
>> Hi Mike,
>> Thanks,
>> Dave
>>> Hello,
>>> Thanks,
>>> Mike
Re: Cannot Transfer Files [message #582374 is a reply to message #482781] Mon, 31 August 2009 09:21 Go to previous messageGo to next message
Hi Michael,
C:\Workspace\
Dave
>> C:\Documents and
>>> Hi Mike,
>>> Thanks,
>>> Dave
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #582469 is a reply to message #483175] Wed, 09 September 2009 11:50 Go to previous messageGo to next message
David,
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Re: Cannot Transfer Files [message #1017200 is a reply to message #484892] Mon, 11 March 2013 01:52 Go to previous message
Check out Long Path Tool. It is indeed very useful in this type of situation. It will help you solve your problems, it help me I have same problem.
Previous Topic:Could RSE be used to mirror local project to remote system
Next Topic:RSE Export / Import All Connections
Current Time: Wed Jul 23 11:59:29 EDT 2025
Powered by FUDForum. Page generated in 0.35501 seconds
