Home » Archived » Buckminster » buckminster.prebind: no action, group, or local artifact named manifest
buckminster.prebind: no action, group, or local artifact named manifest [message #483051] Sun, 30 August 2009 08:48 Go to next message
Hi again,
I'm trying to simplify my build setup a bit. And one thing I'd like to do is add a prebind action to one of my features that has
org.eclipse.platform:osgi.bunde#manifest as a prerequisite:
<cspecExtension
xmlns:com="http://www.eclipse.org/buckminster/Common-1.0"
xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
<actions>
<public name="buckminster.prebind" actor="ant">
<actorProperties>
<property key="buildFile" value="build/patch.ant"/>
<property key="targets" value="remove.signatures"/>
</actorProperties>
<prerequisites>
<attribute component="org.eclipse.platform" componentType="osgi.bundle" name="manifest" alias="manifest"/>
</prerequisites>
</public>
</actions>
</cspecExtension>
The prebind action works just fine if I call it manually after everything is materialized. It also works fine if I first materialize
org.eclipse.platform and then separately materialize my feature. However, if I simply materialize my feature and let buckminster pick up
org.eclipse.platform as a dependency (materializing the source bundle into my workspace), I end up with this:
org.eclipse.platform:osgi.bundle: Trying provider eclipse.import(${p2.url.platform}?importType=source)
org.eclipse.platform:osgi.bundle: Found match 3.3.200.v200906111540
org.eclipse.platform:osgi.bundle: Using provider eclipse.import(${p2.url.platform}?importType=source)
my.feature:eclipse.feature: Trying provider svn(${svn.url.myfeature}/{2}-feature)
my.feature:eclipse.feature: trunk/head will be searched
my.feature:eclipse.feature: Found match 0.2.0.qualifier
my.feature:eclipse.feature: Using provider svn(${svn.url.myfeature}/{2}-feature)
Reading remote file svn+ssh://path/to/svn/trunk/my.feature-feature/build.propert ies#HEAD
Reading remote file svn+ssh://path/to/svn/trunk/my.feature-feature/umllab.produc t#HEAD
Listing remote folder svn+ssh://path/to/svn/trunk/my.feature-feature#HEAD
Provider svn(svn+ssh://null:null@path/to/svn/trunk/my.feature-feature): materializing to C:/Users/creckord/bm/workspace/features/my.feature/
ERROR [0001] : CSpec org.eclipse.platform:osgi.bundle$3.3.200.v200906111540 has no action, group, or local artifact named manifest
INFO: TAG-ID 0001 = Query for my.feature:eclipse.feature
Buckminster again happily obliges when I now call the prebind action manually.
Oh, and one other thing I observed: My feature used to have no direct dependency to org.eclipse.platform:osgi.bundle, but to
org.eclipse.platform:eclipse.feature. With that setup, the CSpec Buckminster builds for my feature is missing the
componentType="osgi.bundle" in my prerequisites and my prebind action triggered the org.eclipse.platform:eclipse.feature#manifest action
instead. This was fixed by adding the org.eclipse.platform:osgi.bundle directly to my feature.
Carsten
Re: buckminster.prebind: no action, group, or local artifact named manifest [message #483052 is a reply to message #483051] Sun, 30 August 2009 09:55 Go to previous message
Hi Carsten,
Some answers inline.
On 08/30/2009 02:48 PM, Carsten Reckord wrote:
> Hi again,
> <cspecExtension
> <actions>
> <actorProperties>
> </actorProperties>
> <prerequisites>
> </prerequisites>
> </public>
> </actions>
> </cspecExtension>
> Reading remote file
> Reading remote file
> manually.
Some of the more advanced build actions are generated by the local reader after the component has been bound to the
workspace. This is because the resolver doesn't really care about those actions in order to do the actual resolution and
materialization and thus, can skip the explicit remote access to some files (like build.properties). You get hit by that
when you use the prebind action.
This should probably be considered a bug since any additions to the cspec that are performed once the component is
materialized should be made before the prebind actions are called.
I can see that happening if the prereuquisite didn't include the component type. Yours do however, so if that happens
with the sample cspec, it must be considered a bug. The correct action should be to report the missing prerequisite and
give up.
Thomas Hallgren
Previous Topic:P2 materializer and profiles
Next Topic:Use of Headless
Current Time: Mon Jul 21 05:00:02 EDT 2025
Powered by FUDForum. Page generated in 0.34926 seconds
