Home » Language IDEs » AspectJ » Aspectj export fails because IMessageHandler cannot be found
Aspectj export fails because IMessageHandler cannot be found [message #482870] Fri, 28 August 2009 08:02 Go to next message
I'm trying to export an aspectj feature/plugin and I get following exception:
org.eclipse.core.runtime.CoreException: C:\iloncar\workspaces\uredsko\.metadata\.plugins\org.eclipse .pde.core\temp\org.eclipse.pde.container.feature\build.xml:3 3:
The following error occurred while executing this line:
C:\iloncar\workspaces\uredsko\.metadata\.plugins\org.eclipse .pde.core\temp\org.eclipse.pde.container.feature\build.xml:1 4:
C:\iloncar\workspaces\uredsko\net.croz.aspect\build.xml:188: The following
C:\iloncar\workspaces\uredsko\net.croz.aspect\build.xml:140: taskdef A class
needed by class org.aspectj.tools.ant.taskdefs.AjcTask cannot be found: org/aspectj/bridge/IMessageHandler
Generated build.xml does not have aspectjweaver.jar in ajde.classpath:
136: <!-- compile the source code -->
137: <path id="ajde.classpath">
138: <pathelement path="../../ajdt/org.aspectj.ajde/ajde.jar"/>
139: </path>
140: <taskdef resource="org/aspectj/tools/ant/taskdefs/aspectjTaskdefs.properties ">
141: <classpath refid="ajde.classpath" />
142: </taskdef>
143: <property name="ajcArgFile" value=""/>
144: <iajc destDir="${temp.folder}/@dot.bin" failonerror="true" argfiles="${ajcArgFile}"
verbose="true" fork="true" maxmem="512m" debug="${javacDebugInfo}" bootclasspath="${bundleBootClasspath}"
source="${bundleJavacSource}" target="${bundleJavacTarget}">
145: <forkclasspath refid="@dot.classpath" />
146: <forkclasspath refid="ajde.classpath" />
147: <src path="src/" />
148: </iajc>
This is a recent AJDT from 1.7 branch.
If it's relevant: I use custom target that contains aspectjruntime and aspectjweaver.jar
AJDE depends on aspectjweaver, but it's not added to the classpath.
It seems that AJModelBuildScriptGenerator#bundleToCP doesn't export required
dependencies:
BundleDescription[] prereqs = bundle.getResolvedRequires();
returns nothing, but
bundle.getRequiredBundles()
contains
[Require-Bundle: org.apache.ant; bundle-version="0.0.0", Require-Bundle:
org.eclipse.core.resources; bundle-version="0.0.0", Require-Bundle: org.eclipse.core.runtime;
bundle-version="0.0.0", Require-Bundle: org.eclipse.core.runtime.compatibility;
bundle-version="0.0.0", Require-Bundle: org.eclipse.text; bundle-version="0.0.0",
Require-Bundle: org.aspectj.weaver; bundle-version="92.2.29"]
Shouldn't those bundles be included when calculating ajde.classpath?
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #482871 is a reply to message #482870] Fri, 28 August 2009 08:09 Go to previous messageGo to next message
> required
> dependencies:
> contains [Require-Bundle: org.apache.ant; bundle-version="0.0.0",
> Require-Bundle: org.eclipse.core.resources; bundle-version="0.0.0",
> Require-Bundle: org.eclipse.core.runtime; bundle-version="0.0.0",
> bundle-version="0.0.0", Require-Bundle: org.aspectj.weaver;
Hmm.. ajde bundle is not resolved.
Should ajde bundle be resolved before org.eclipse.ajdt.core.exports.AJModelBuildScriptGenerator.bu ndleToCP(BundleDescription)
is called?
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #482942 is a reply to message #482871] Fri, 28 August 2009 11:22 Go to previous messageGo to next message
Hello Ivica,
>> required
>> dependencies:
> undleDescription)
> is called?
The problem occurs only when I use custom target platform.
It seems that ajde is not resolved when ajde.classpath is generated, and
it's causing the problem.
I don't think bundles have to be resolved in order to be added to ajde.classpath,
so I have replaced:
// now add prerequisite bundles
for (int i = 0; i < prereqs.length; i++) {
String[] pcp = bundleToCP(prereqs[i]);
pathList.addAll(Arrays.asList(pcp));
with:
BundleSpecification[] prereqs = bundle.getRequiredBundles();
BundleDescription prereqBundle = getModel(prereqs[i].getName(), null);
if (prereqBundle != null ) {
String[] pcp = bundleToCP(prereqBundle);
I'm not sure if this has more implications.
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #482949 is a reply to message #482942] Fri, 28 August 2009 12:22 Go to previous messageGo to next message
Hi Ivica,
org.aspectj.ajde must be in the target platform in order for the build to
work. So, add that bundle to the target platform and it should work.
> ajde.classpath,
> so I have replaced:
> with:
Re: Aspectj export fails because IMessageHandler cannot be found [message #482957 is a reply to message #482949] Fri, 28 August 2009 12:49 Go to previous messageGo to next message
Hello Andrew,
> to work. So, add that bundle to the target platform and it should
> work.
Thanks Andrew. I will do that.
Btw. Isn't that a little bit unexpected: we don't have to include PDE in
the target platform in order to compile a product.
Don't you think this should be documented?
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #482960 is a reply to message #482949] Fri, 28 August 2009 13:18 Go to previous messageGo to next message
Hello Andrew,
> Hi Ivica,
> work.
Hi Andrew,
I have tried to add ajde to the target platform and it doesn't work.
I have added ajde to the target platform and generated build.xml looks like
this:
<pathelement path=" ../uredsko_platform_341/ajde/org.aspectj.ajde_1.6.5.20090618 034232/ajde.jar "/>
</path>
</taskdef>
<src path="src/" />
</iajc>
iajc fails with error:
net.croz.aspect\build.xml:139: taskdef A class needed by class org.aspectj.tools.ant.taskdefs.AjcTask
Total time: 281 milliseconds
If we just get ajde dependencies without trying to resolve them ajde.classpath
will be created as expected.
Why ${ajde.classpath} bundles have to be resolved from the target platform?
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #482993 is a reply to message #482957] Fri, 28 August 2009 19:37 Go to previous messageGo to next message
This is something I have been bothered about, but have not had time to
address. I raised a bug for this and will try to get to it in the future.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288020
Of course, patches are always welcome. :)
On 28/08/09 9:49 AM, in article
d8d722417af78cbf6275d2dc608@news.eclipse.org, "Ivica Loncar"
<iloncar.mlIQTEST@gmail.com> wrote:
> Hello Andrew,
>> work.
Re: Aspectj export fails because IMessageHandler cannot be found [message #482994 is a reply to message #482960] Fri, 28 August 2009 19:40 Go to previous messageGo to next message
I believe that the weaver and aspectj runtime are required by ajde and so
must be in the target platform as well.
On 28/08/09 10:18 AM, in article
d8d722417b058cbf62b78ca7f10@news.eclipse.org, "Ivica Loncar"
> Hello Andrew,
>> Hi Ivica,
>> work.
> Hi Andrew,
> this:
> <pathelement
> jar"/>
> </path>
> </taskdef>
> <src path="src/" />
> </iajc>
Re: Aspectj export fails because IMessageHandler cannot be found [message #483036 is a reply to message #482994] Sat, 29 August 2009 13:35 Go to previous message
Hello Andrew,
> so must be in the target platform as well.
I do have weaver and runtime in the target platform.
Unfortunately build still fails since AJDE is not resolved.
There are additional dependencies that need to be deployed into target platform:
org.apache.ant_1.7.1.v20090120-1145
org.eclipse.core.runtime.compatibility_3.2.0.v20090413.jar
org.eclipse.text_3.4.0.v20080605-1800.jar
Cost me some time.. no I have to figure out how to do headless build...
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #600535 is a reply to message #482870] Fri, 28 August 2009 08:09 Go to previous message
> required
> dependencies:
is called?
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #600550 is a reply to message #482871] Fri, 28 August 2009 11:22 Go to previous message
Hello Ivica,
>> required
>> dependencies:
> undleDescription)
> is called?
so I have replaced:
with:
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #600565 is a reply to message #482942] Fri, 28 August 2009 12:22 Go to previous message
Hi Ivica,
> ajde.classpath,
> so I have replaced:
> with:
Re: Aspectj export fails because IMessageHandler cannot be found [message #600570 is a reply to message #482949] Fri, 28 August 2009 12:49 Go to previous message
Hello Andrew,
> work.
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #600581 is a reply to message #482949] Fri, 28 August 2009 13:18 Go to previous message
Hello Andrew,
> Hi Ivica,
> work.
Hi Andrew,
this:
</path>
</taskdef>
<src path="src/" />
</iajc>
Ivica Loncar
Re: Aspectj export fails because IMessageHandler cannot be found [message #600589 is a reply to message #482957] Fri, 28 August 2009 19:37 Go to previous message
> Hello Andrew,
>> work.
Re: Aspectj export fails because IMessageHandler cannot be found [message #600599 is a reply to message #482960] Fri, 28 August 2009 19:40 Go to previous message
> Hello Andrew,
>> Hi Ivica,
>> work.
> Hi Andrew,
> this:
> <pathelement
> jar"/>
> </path>
> </taskdef>
> <src path="src/" />
> </iajc>
Re: Aspectj export fails because IMessageHandler cannot be found [message #600611 is a reply to message #482994] Sat, 29 August 2009 13:35 Go to previous message
Hello Andrew,
Ivica Loncar
Previous Topic:Aspectj export fails because IMessageHandler cannot be found
Next Topic:[BUG?] java.lang.VerifyError with @AspectJ annotation (but with print, works!?)
Current Time: Wed Jul 23 15:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.26315 seconds
