[EuGENia | EOL] Adding new label problem [message #482899] |
Fri, 28 August 2009 09:44  |
I'm trying to add a new label to the compartment of XXX node. But it is
not working out.
var label = new GmfGraph!Label("temp");
CompartmentFigure.children.add(label);
If I do this then it allows me to all blank label where I want but, when
I try to add name and text to label it is not working.
var label = new GmfGraph!Label;
label.name = "RuleNacsCompartmentFigureLabel";
label.text = "NACs Compartment";
Please help me with this.
Many thanks,
Mihir
{solved} [EuGENia | EOL] Adding new label problem [message #482941 is a reply to message #482907] |
Fri, 28 August 2009 11:35  |
Hi Dimitris,
Thanks for your help.
Actually I was just experimenting with the constructor if it works and
so I forgot to remove it while pasting that bit of code here in the post. :)
After changing "" to '', it works fine.. :)
Thanks a million,
Mihir
Dimitris Kolovos wrote:
> Hi Mihir,
> EOL doesn't support constructors with parameters for model elements such
> as GmfGraph!Label("temp").
> Also, in EOL strings are placed within '' (support for "" will be added
> in the next version) so you should try:
> label.name = 'RuleNacsCompartmentFigureLabel';
> label.text = 'NACs Compartment';
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> is not working out.
>> when I try to add name and text to label it is not working.
>> Many thanks,
>> Mihir
Re: [EuGENia | EOL] Adding new label problem [message #579841 is a reply to message #482899] |
Fri, 28 August 2009 09:47  |
Hi Mihir,
Dimitris
Mihir wrote:
> Hello,
> not working out.
> Many thanks,
> Mihir
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
{solved} [EuGENia | EOL] Adding new label problem [message #579858 is a reply to message #482907] |
Hi Dimitris,
Thanks a million,
Mihir
> Hi Mihir,
> Cheers,
> Dimitris
> Mihir wrote:
>> Hello,
>> is not working out.
>> Many thanks,
>> Mihir
FUDForum. Page generated in 0.05585 seconds
