Data item expressions from a library [message #482233] |
Tue, 25 August 2009 15:05  |
We're trying to use a library to define a Data element which we use across
multiple reports. The element's expression is a non-trivial formula.
Functionally, this is working, however this approach is killing
performance (in 2.3.2.1 at least). We're seeing report generation time go
from 12s to 5 minutes, and the rptdocument go from 18MB to 146MB, although
the outputs seem to match.
I know there are some caching enhancements in 2.5, but we're stuck w/ 2.3
for now, so I'd love to hear ideas for a work-around, if any exist other
than copy/pasting our expression into local Data elements on each report.
I can also reproduce this w/o a library. Essentially the acceptable
performance occurs when the Data element references a binding on the
table, and the poor performance occurs when the Data element has its own
bindings (which is how it would come from a library).
James
FUDForum. Page generated in 0.31554 seconds
