Home » Modeling » EMF » EcrossReferenceAdapter ClassCastException
EcrossReferenceAdapter ClassCastException [message #482752] Thu, 27 August 2009 15:22 Go to next message
I am hitting a ClassCastException (CCE) at line 613 of
ECrossReferenceAdapter.java. I searched the eclipse newsgroups and found
one entry related but did not understand how it was resolved. I am using
EMF version 2.4.2, with GMF 1.1.3. The CCE is occuring due to an unset
notification from my domain model, where the unset is for a reference with
an upper bound of many (*). The call to unset is generated, and not
modified. It results in calling EObjectEList.unset(), which in turn calls
owner.eNotify(createNotification(Notification.UNSET, oldIsSet, false));
The ECrossReferenceAdapter class is trying to cast the notification's old
value to an EObject, which is failing because it is an instance of Boolean.
Any help would be greatly appreciated.
Thanks in advance,
Travis London
Re: EcrossReferenceAdapter ClassCastException [message #482762 is a reply to message #482752] Thu, 27 August 2009 16:21 Go to previous messageGo to next message
Travis,
It sounds like a bug (and oversight). I recall a similar bug coming up
in the ChangeRecorder; you can look at how it handles this case..
Please open a bugzilla. I'll try to get a patch into it as soon as
possible. I'm not sure what to suggest for such an old version, other
than applying the patch yourself to the older source...
Travis London wrote:
> Hello,
> found one entry related but did not understand how it was resolved. I
> am using EMF version 2.4.2, with GMF 1.1.3. The CCE is occuring due
> to an unset notification from my domain model, where the unset is for
> a reference with an upper bound of many (*). The call to unset is
> generated, and not modified. It results in calling
> old value to an EObject, which is failing because it is an instance of
> Boolean.
> Thanks in advance,
> Travis London
Re: EcrossReferenceAdapter ClassCastException [message #482770 is a reply to message #482762] Thu, 27 August 2009 17:15 Go to previous messageGo to next message
Thank you very much for the input. I will watch the issue for a patch.
Re: EcrossReferenceAdapter ClassCastException [message #482783 is a reply to message #482762] Thu, 27 August 2009 19:21 Go to previous messageGo to next message
That patch worked for me. Is this fix in a newer version? Or is it
something you will have to add?
Also it turns out the GMF CrossReferenceAdapter class has the same
problem. I will bring it up on their news group.
Thanks, again.
Re: EcrossReferenceAdapter ClassCastException [message #482839 is a reply to message #482783] Fri, 28 August 2009 06:15 Go to previous message
Travis,
I'll need to apply this patch for 2.6.
You'd better open a separate bugzilla for GMF.
> Thanks, again.
Previous Topic:Populating EMF Resource using default serialization and Non-containment from Database - Want to avoi
Next Topic:Send a xml as inputStream
Current Time: Fri Jul 18 20:36:19 EDT 2025
Powered by FUDForum. Page generated in 0.06987 seconds
