Home » Eclipse Projects » Eclipse Platform » Workbench save and restore dilama
Workbench save and restore dilama [message #482827] Fri, 28 August 2009 05:08 Go to next message
i have an rcp application in which there is a perspective,
In createInitialLayout i have added
partlisteners,windowlistener,workbenchlistenere for varies resons,
when i run the application with setSaveAndRestore true,
on restore the createInitialLayout method is not called...
am i adding the listeners in the wrong place...
or is there a workaround for the same....
Also what if i dont want to save and restore my perpective,views(the
application contains many perspectives which need save and restore)
To achieve the above on preshutdown i tryed to close my views which were
opened,but here the problem is it only returns the active perspective
parts...
(i.e if the user in some other perspective on shutdown the views returned
will be of the specific perpective not my perspective)
pls help
Re: Workbench save and restore dilama [message #482990 is a reply to message #482827] Fri, 28 August 2009 18:15 Go to previous messageGo to next message
"vijay " <vijay.rajonline@gmail.com> wrote in message
news:3e1edb236197a8b08d4dd7b0f7ba2a40$1@www.eclipse.org...
When you set save and restore to true, you are telling the workbench to
restore its previous state and *not* reset your perspective the the intial
layout. createInitialLayout is called when there is no saved state (or when
you choose the "Reset Perspective" action).
You should consider adding listeners during one of the WorkbenchAdvisor or
WorkbenchWindowAdvisor callbacks.
Good question - I do not know how to selectively save some perspectives and
not others.
> parts...
Re: Workbench save and restore dilama [message #483087 is a reply to message #482990] Mon, 31 August 2009 00:53 Go to previous messageGo to next message
I think in createInitialLayout java doc should contain this info,
ya this is obvious but still it should be....
I do not have access to these classes,since my application startup code is
in a framework which is used as a target platform hence unmodifiable....
what would be the best place to add these listeners so that i do not
accidentally load my plugins on startup and also can moniter perspective
change window states etc...
i know all this is a design issue, but still can you pls suggest a proper
place for adding all the listeners....
> not others.
>> parts...
Re: Workbench save and restore dilama [message #483458 is a reply to message #483087] Tue, 01 September 2009 12:35 Go to previous messageGo to next message
You can put startup code in your BundleActivator. You could look into the
"org.eclipse.ui.startup" extension point.
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/reference/extension-points/org_eclipse_ui_ startup.html
Will
news:56c588e55982b8bf020eccd3c73ec0f0$1@www.eclipse.org...
>> intial layout. createInitialLayout is called when there is no saved
>> state (or when you choose the "Reset Perspective" action).
>> or WorkbenchWindowAdvisor callbacks.
> Thanks
>> and not others.
>>> parts...
>>> returned will be of the specific perpective not my perspective)
Re: Workbench save and restore dilama [message #483566 is a reply to message #483458] Wed, 02 September 2009 02:28 Go to previous messageGo to next message
I did exactly that only,but using uijod because startup is a non ui
thread..
after doing all that,now there is a new problem....
my application has language change option,on language change and restart
the views are restored but with titles with old language...
on focus of the view only, the titles get updated...
is this a bug or it should be like this?????
> Will
>> Thanks
>>> and not others.
>>>> parts...
Re: Workbench save and restore dilama [message #483738 is a reply to message #483566] Wed, 02 September 2009 14:44 Go to previous message
vijay wrote on Wed, 02 September 2009 02:28
A bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=202172
PW
Previous Topic:Programmatically associate views to categories
Next Topic:Can I use a command parameter in its handler's enabledWhen?
Current Time: Sat Nov 08 05:06:44 EST 2025
Powered by FUDForum. Page generated in 0.04463 seconds
