Home » Eclipse Projects » DSDP - Target Management » Cannot Transfer Files
Cannot Transfer Files [message #481150] |
Wed, 19 August 2009 15:05  |
I use RSE to manage files on my remote system. Recently I have been
unable to transfer files from my workstation to any of my systems using
RSE. When I transfer a file I see the progress indicator refreshing the
folder but the file never gets transfered and no errors are thrown or
logged. I have tried uninstalling and reinstalling TM and have even
tried a fresh install of eclipse 3.5 with TM3.1 and it still fails to
transfer. This was working before. I have tried on several different
servers but with no luck. Please help.
Mike
Re: Cannot Transfer Files [message #483175 is a reply to message #482781] |
Mon, 31 August 2009 09:21   |
Hi Michael,
It's possible that the problem is the file path is too long for Windows
(there are path restrictions). Could you try this using a workspace with a
shorter path? For example, instead of using this:
C:\Documents and Settings\Mike\XXX\Workspaces\XXXXXXXXX\
could you try somethign like this:
C:\Workspace\
Dave
"Michael Yara" <michaely@i9technologies.com> wrote in message
news:h7739t$7fv$1@build.eclipse.org...
>I just tried on a fresh install of Eclipse 3.5 with TM 3.1 pulled from the
>update site, new workspace and still shows the same behavior.
> Michael Yara wrote:
>> This is a windows system and I transfer using copy/paste and/or drag and
>> drop. I cannot transfer files from my local system to a remote system or
>> from remote to remote. If i go from local to remote the previously
>> described behavior occurs. If i do a remote to remote i get this error.
>> Message reported from file system: java.io.FileNotFoundException:
>> C:\Documents and
>> Settings\Mike\XXX\Workspaces\XXXXXXXXX\RemoteSystemsTempFile s\PHONE.XXXXXXXXXX.COM\root\old\encode_template.xml
>> (The system cannot find the path specified)
>> Xs masking sensitive data.
>> David McKnight wrote:
>>> Hi Mike,
>>> Which client are you on (i.e. windows, linux, etc.)? Could you describe
>>> how you do the transfers? Is this via copy/paste from the "Local"
>>> system to a remote system?
>>> Thanks,
>>> Dave
>>> news:h6hiek$t6u$1@build.eclipse.org...
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #484892 is a reply to message #483175] |
Wed, 09 September 2009 11:50   |
David,
Unfortunately your suggestion did not work. I thought for sure this was
the issue since I am seeing it occur even on a fresh install with a
brand new workspace.
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Re: Cannot Transfer Files [message #582374 is a reply to message #482781] |
Hi Michael,
C:\Workspace\
Dave
>> C:\Documents and
>>> Hi Mike,
>>> Thanks,
>>> Dave
>>>> Hello,
>>>> Thanks,
>>>> Mike
Re: Cannot Transfer Files [message #582469 is a reply to message #483175] |
David,
Mike
> Hi Michael,
> C:\Workspace\
> Dave
>>> C:\Documents and
>>>> Hi Mike,
>>>> Thanks,
>>>> Dave
>>>>> Hello,
>>>>> Thanks,
>>>>> Mike
Current Time: Sun Jul 27 14:10:34 EDT 2025
Powered by FUDForum. Page generated in 0.07403 seconds
