Home » Modeling » Epsilon » EMF ChangeRecorder in eol
EMF ChangeRecorder in eol [message #482736] Thu, 27 August 2009 13:36 Go to next message
is there a way I can access the EMF ChangeRecorder from my eol program?
I'd like to monitor model changes done by the eol program.
Thanks a lot in advance and regards,
Anne
Re: EMF ChangeRecorder in eol [message #482746 is a reply to message #482736] Thu, 27 August 2009 14:22 Go to previous messageGo to next message
Hi Anne,
Are you running EOL via a launch configuration or through Java code?
Dimitris
Anne wrote:
> Anne
Re: EMF ChangeRecorder in eol [message #482768 is a reply to message #482746] Thu, 27 August 2009 16:37 Go to previous messageGo to next message
Hi Dimitri,
via a launch configuration.
Anne
Dimitris Kolovos wrote:
> Hi Anne,
> Cheers,
> Dimitris
> Anne wrote:
>> Hi,
>> program? I'd like to monitor model changes done by the eol program.
>> Anne
Re: EMF ChangeRecorder in eol [message #482772 is a reply to message #482768] Thu, 27 August 2009 17:43 Go to previous messageGo to next message
Hi Anne,
In this case, you'll need to write a Java class (tool) and let Epsilon
know about it (as per
http://www.eclipse.org/gmt/epsilon/doc/EpsilonTools.pdf - which we
should really update at some point). Then you can instantiate it using
the Native type and call its methods through EOL - one of them would
have a signature like monitor(EmfModel model) and would internally use
model.getModelImpl() to get a reference to the underlying resource which
it could then track using an EMF ChangeRecorder.
Dimitris
Anne wrote:
> Hi Dimitri,
> Anne
>> Hi Anne,
>> Cheers,
>> Dimitris
>> Anne wrote:
>>> Hi,
>>> Anne
Re: EMF ChangeRecorder in eol [message #536773 is a reply to message #482772] Sun, 30 May 2010 16:22 Go to previous messageGo to next message
So what's the answer if one is calling EOL through Java? And would accessing the recorder through EOL be better, easier, faster, etc. than doing so with straight Java?
I'm only looking for a short answer -- no immediate need yet, just trying to get a handle on all these technologies.
Stephen
Dimitrios Kolovos wrote:
Hi Anne,
Dimitris
Anne wrote:
> Hi Dimitri,
> Anne
>> Hi Anne,
>> Cheers,
>> Dimitris
>> Anne wrote:
>>> Hi,
>>> Anne
Re: EMF ChangeRecorder in eol [message #536775 is a reply to message #536773] Sun, 30 May 2010 17:10 Go to previous message
Hi Stephen,
If you're running EOL from Java as part of an Eclipse plugin, the
process is the same (need to define extension etc.). If it's a
standalone Java application, the tool just needs to be in the classpath.
There shouldn't be a difference regarding speed or ease of use whether
you access the recorder through EOL or Java.
Dimitris
> Cheers,
> Stephen
>> Hi Anne,
>> which it could then track using an EMF ChangeRecorder.
>> Cheers,
>> Dimitris
>> Anne wrote:
>> > Hi Dimitri,
>> > > Anne
>> >> Hi Anne,
>> >> Cheers,
>> >> Dimitris
>> >> Anne wrote:
>> >>> Hi,
>> >>> is there a way I can access the EMF ChangeRecorder from my eol >>>
>> >>> Anne
Re: EMF ChangeRecorder in eol [message #579776 is a reply to message #482736] Thu, 27 August 2009 14:22 Go to previous message
Hi Anne,
Dimitris
Anne wrote:
> Anne
Re: EMF ChangeRecorder in eol [message #579787 is a reply to message #482746] Thu, 27 August 2009 16:37 Go to previous message
Hi Dimitri,
Anne
> Hi Anne,
> Cheers,
> Dimitris
> Anne wrote:
>> Hi,
>> Anne
Re: EMF ChangeRecorder in eol [message #579800 is a reply to message #482768] Thu, 27 August 2009 17:43 Go to previous message
Hi Anne,
Dimitris
Anne wrote:
> Hi Dimitri,
> Anne
>> Hi Anne,
>> Cheers,
>> Dimitris
>> Anne wrote:
>>> Hi,
>>> Anne
Re: EMF ChangeRecorder in eol [message #589546 is a reply to message #482772] Sun, 30 May 2010 16:22 Go to previous message
Stephen
> Hi Anne,
> Cheers,
> Dimitris
> Anne wrote:
> > Hi Dimitri,
> > Anne
> >> Hi Anne,
> >> Cheers,
> >> Dimitris
> >> Anne wrote:
> >>> Hi,
> >>> Anne
Re: EMF ChangeRecorder in eol [message #589554 is a reply to message #589546] Sun, 30 May 2010 17:10 Go to previous message
Hi Stephen,
Dimitris
> Cheers,
> Stephen
>> Hi Anne,
>> Cheers,
>> Dimitris
>> Anne wrote:
>> > Hi Dimitri,
>> > > Anne
>> >> Hi Anne,
>> >> Cheers,
>> >> Dimitris
>> >> Anne wrote:
>> >>> Hi,
>> >>> Anne
Previous Topic:EMF Compare-ECL integration
Next Topic:Special assignment operator bug?
Current Time: Wed Jul 23 05:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.05727 seconds
