Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Sleak plugin
Sleak plugin [message #482605] Thu, 27 August 2009 05:29 Go to next message
Originally posted by: hanish.kukreja.gmail.com
Hi All,
I am trying to use Sleak plugin for analysing SWT resource leak. I
followed the steps mentioned here : http://www.eclipse.org/swt/tools.php.
Sleak window appears but when I am running my application as eclipse
workbench and I try to use sleak clicking on snap it always gives me the
error :
Warning : Device is not tracking resource allocation
These are the steps mentioned to use sleak in the above article.
# Extract the .options file from the
eclipse/plugins/org.eclipse.ui_<version>.jar archive to the eclipse/
folder.
# Add the following lines to the .options file:
org.eclipse.ui/debug=true
org.eclipse.ui/trace/graphics=true
I set both these optoions in .options file and kept the .options file in
eclipse/ folder as mentioned. But when I debug where the display is
created for Display.getDeviceData().debug and
Display.getDeviceData().trace. Both of them are false thought I set them
as true in .options file.
I might be doing somethin worng. May be not puting .options file at
appropriate location.
I also read on news group. This is one of the thread which was discussing
same issue.
http://dev.eclipse.org/newslists/news.eclipse.platform.swt/m sg43284.html
but solution was not mentioned there
Any one Can help me??
Re: Sleak plugin [message #482636 is a reply to message #482605] Thu, 27 August 2009 07:44 Go to previous messageGo to next message
Hello Hanish,
You can read the article at
http://eclipsesource.com/blogs/2009/04/17/finding-swt-leaks- with-sleak/
To enable the tracing option, go to the launch configuration.
Go to the tracing tab.
Check (enable) the plugin 'org.eclipse.ui'. On the right pane check
(enable) 'debug' and 'trace/graphics'.
Re: Sleak plugin [message #482657 is a reply to message #482605] Thu, 27 August 2009 09:15 Go to previous messageGo to next message
Hi Hanish,
do you start your application with the -debug command line argument?
remo
Re: Sleak plugin [message #1043384 is a reply to message #482657] Wed, 17 April 2013 12:27 Go to previous message
A note for others finding this topic: The -debug option can be specified in eclipse.ini (add it on a line before -vmargs).
Previous Topic:Filling Tree with hundreds of items without freezing
Next Topic:looking for solution
Current Time: Wed Jul 23 17:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.03320 seconds
