How to cancel Build [message #482059] |
Tue, 25 August 2009 05:53  |
In my EarlyStartup plugin, I have a PRE_BUILD listener which does things,
but if these things failed, how to cancel the BUILD ?
Throw a runtine exception ?
This is the code to listen PRE_BUILD events.
ResourcesPlugin.getWorkspace().addResourceChangeListener(new
PreBuildProcess(), IResourceChangeEvent.PRE_BUILD);
Re: How to cancel Build [message #484877 is a reply to message #482814] |
Wed, 09 September 2009 11:16  |
Can't you use the file modification hook? The file modification hook goes
into your checker which prevents the saving of the file which in turn will
not trigger the build.
Wim
File modification validators
It's also possible that team repository providers will need to prevent or
intervene in the editing or saving of a file. The team plug-in accomplishes
this by using the extension point
org.eclipse.core.resources.fileModificationValidator to register a validator
that is called whenever a resource is to be modified.
<extension point="org.eclipse.core.resources.fileModificationValidator "
id="FileValidator">
<fileModificationValidator
class=" org.eclipse.team.internal.core.FileModificationValidatorMana ger "/>
</extension>
The supplied class must implement IFileModificationValidator, which is
called by the platform whenever a resource is saved or opened. The team
plug-in installs a file modification manager that can determine which team
provider is managing a resource and invoke its specific validator.
Best Regards,
Wim Jongman
http://www.remainsoftware.com
http://www.industrial-tsi.com
"encom79 " <encom79@hotmail.com> wrote in message
news:e1bc34802b26784facb3cf894cdfb434$1@www.eclipse.org...
> The aim is to trigger the "run" and "debug" button press :/
> There is no PRE_RUN or PRE_DEBUG, PRE_BUILD is the best and simplest way I
> have found to run my process before the "run/debug".
> In this PRE_BUILD process I launch some executable (GUI) in a thread then
> the regular BUILD start by launching Adobe Flex/Air program.
> If my executable in the PRE_BUILD failed I should not let Adobe Flex/Air
> program to run :/
> That's why I need to find a way to kill Adobe Flex/Air program.
FUDForum. Page generated in 0.03226 seconds
