| Legal and Distribution Query [message #48209] | Fri, 10 August 2007 03:58  |  |
| Eclipse User  |  |  |  |  | I have a soon to be released commercial plug-in which I'd like to distribute pre-installed on my own Eclipse platform distribution.
 First, I am uncertain on legal issues that may be involved in
 distributing my own Eclipse bundle. I have looked at section 5.0 of
 http://www.eclipse.org/legal/guidetolegaldoc.php, but without a law
 degree, it is hard to understand exactly what it means. Any pointers to
 an explanation of this document in plain English is appreciated.
 Second, since the target users for my plug-in will most likely not be
 developing any Java, RCP, or Plug-ins applications, I'd like my
 distribution to contain only the absolute necessary plug-ins for the
 platform (NO JDT, PDE, etc). To accomplish this, I've taken the Eclipse
 distribution and removed almost all plug-ins (from the Product
 Configuration GUI), and then restarted the workbench with the -clean
 option. This seems to work well, but it is very time consuming. Is there
 a better way to do this? Why doesn't the foundation provide a bare
 minimum distribution?
 Thanks in advance for your response.
 Amir
| Re: Legal and Distribution Query [message #48241 is a reply to message #48209] | Fri, 10 August 2007 04:51   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jacek.pospychala.pl.ibm.com
 Amir,
 I am not any representative of the Foundation. but anyway
 in my opinion section 5.0, to which you refer says primarily you should
 make it clear to all your customers, that you are provider of the
 application. It's because they may be confused, since in a lot of places
 it's stated that Eclipse Foundation is provider, but if you
 redistribute, then you are provider and foundation is the origin of some
 parts.
 You can't simply modify files provided by Eclipse, to include your
 license, instead you'd rather write a one clear single license that
 informs your customer, that some parts of your product come from Eclipse.
 You can also take a look at how others indicate that their applications
 are based on Eclipse, eg. you might want to download a trial of IBM
 Rational Application Developer and Adobe Flex Builder (not sure if there
 is a trial). Afaik they have two different approaches, while IBM clearly
 states RAD is on Eclipse, Adobe is not specially verbose about this.
 Second, I guess, there is no one bare minimum distribution. For example,
 one wants just few essencial headless plugins, other wants essence for
 UI applications, and so on. Personally always when launching my plugins
 I go to "Run", create new launch definition, unselect all plugins and
 then select only mine and "Add Required plugins". Later you can create a
 Product configuration and easily export your application.
 > to an explanation of this document in plain English is appreciated.
 > Eclipse distribution and removed almost all plug-ins (from the Product
 > there a better way to do this? Why doesn't the foundation provide a
 > bare minimum distribution?
 > Amir
FUDForum. Page generated in 0.04676 seconds
