Home » Modeling » UML2 Tools » Getting started with Topcased(need help settting up)
Getting started with Topcased [message #482275] Tue, 25 August 2009 20:30 Go to next message
Hi everyone,
I recently downloaded Topcased RCP 3.0.1 for Linux. When I try to run it (by running the "eclipse" executable in the topcased directory) I get an error saying Eclipse isn't installed. I Just downloaded Eclipse 3.5 prior to topcased as well. Both Eclipse and topcased are in my /home directory. Can someone help me with this problem?
Re: Getting started with Topcased [message #482280 is a reply to message #482275] Tue, 25 August 2009 23:55 Go to previous messageGo to next message
I have 64 bit Linux and 64 bit Eclipse 3.5. I think Topcased is made for 32 bit as that is what shows when I type "file eclipse" on the executable within the topcased directory. I am going to see if I can run 32bit eclipse to fix this. If not, I will just put it on my windows machine.
Re: Getting started with Topcased [message #482282 is a reply to message #482280] Wed, 26 August 2009 00:03 Go to previous messageGo to next message
When I try to run 32 bit eclipse it says "cannot find companion launcher jar." Same error message when I try to run Topcased.
Re: Getting started with Topcased [message #482544 is a reply to message #482275] Wed, 26 August 2009 20:24 Go to previous messageGo to next message
Well I have come to the conclusion that Topcased is for 32bit platforms only. If so, that defeats the purpose of java, to take away the hardware dependencies.
Re: Getting started with Topcased [message #483459 is a reply to message #482544] Tue, 01 September 2009 12:30 Go to previous message
John,
No, Topcased is not only available on 32bit platforms.
That is true the two RCP versions that are packaged are built against
win32 and linux-gtk platforms only (we assume they are the most common
platforms for which we could propose a RCP version), but it is
"supposed" to work on much more platforms.
In your case, you should first download the appropriate version
( http://download.eclipse.org/eclipse/downloads/drops/R-3.5-20 0906111540/index.php
- linux-gtk-x86_64) and use update site mechanism to install Topcased
and its dependencies.
See the release note for additional informations, and if you have any
further problem, please use the Tocpased users mailing list :
http://lists.gforge.enseeiht.fr/mailman/listinfo/topcased-us ers
Jacques
> dependencies.
Re: Getting started with Topcased [message #624830 is a reply to message #482544] Tue, 01 September 2009 12:30 Go to previous message
John,
Jacques
> dependencies.
Previous Topic:extending UML2Tools
Next Topic:uml2tools newbie - Trouble with basic functionality
Current Time: Wed Jul 23 05:43:51 EDT 2025
Powered by FUDForum. Page generated in 0.04391 seconds
