Home » Modeling » GMF (Graphical Modeling Framework) » No code been generated while click Generate Model Code
No code been generated while click Generate Model Code [message #48219] Thu, 14 September 2006 16:25 Go to next message
Hello everyone,
I follow the GMF tutorial but using my own model (test.mdl) instead. Problem
occurs while I right click the test.genmodel and do generate model code,
nothing happens (also no error message). It should be generate code within 3
packages (test, test.impl, test.util) right? After then, I continue to
generate edit and got an error. The error shows in below. Does anybody know
what happen? Thanks a lot.
Generate Ed&it Code
Generating edit project
Generating Java class test.test.provider.FlowDeleteCommandItemProvider
failed with an unhandled exception
InvocationTargetException
NullPointerException
Generating Java class test.test.provider.FlowCreateCommandItemProvider
Generating Java class test.test.provider.FlowReCreateCommandItemProvider
Generating Java class test.test.provider.ShapeCreateCommandItemProvider
Generating Java class test.test.provider.ShapeDeleteCommandItemProvider
Generating Java class test.test.provider.DiagramEditPartItemProvider
Meilin
Re: No code been generated while click Generate Model Code [message #48772 is a reply to message #48219] Fri, 15 September 2006 06:37 Go to previous message
Originally posted by: 5d5.mail.ru
I fear that nobody will tell you what happens without knowing the stack
of NullPointerException...
exquisitus wrote:
> Hello everyone,
> Generate Ed&it Code
> Meilin
Previous Topic:classes not being generated
Next Topic:GMF Issue
Current Time: Fri Jul 18 20:23:18 EDT 2025
Powered by FUDForum. Page generated in 0.06067 seconds
