Problem using SystemRemoteFolderDialog [message #482122] |
Tue, 25 August 2009 08:44  |
I have RSE 3.1 runtime installed and have some code which uses the
SystemRemoteFolderDialog class to get the pathname of a directory on the
remote system. If the user clicks a directory name, then getOutputObject
returns an instance of SftpRemoteFile and everything is fine. If the user
selects either the 'My Home' or 'Root' labels, then getRemoteObject
returns an instance of SystemFilterReference and I can't get a remote path
from that since it's the wrong class.
How should I handle this? Should my code issue an error message indicating
that 'My Home' or 'Root' are not valid selections and that the user should
retry with a selection of a directory instead of one of these two objects?
Is there something else my code should be doing? Is this a RSE problem?
Dave
Re: Problem using SystemRemoteFolderDialog [message #482531 is a reply to message #482484] |
Wed, 26 August 2009 18:39  |
I tried what you suggested and it works for both the 'My Home' and 'Root'
cases.
David McKnight wrote:
> Hi Dave,
> Here's something you may want to try:
> // could have selected a filter reference
> Object value = selectFolderAction.getValue();
> if (value instanceof ISystemFilterReference){
> ISystemFilterReference fref = (ISystemFilterReference)value;
> ISubSystem ss = fref.getSubSystem();
> // target for filter should give the most relevant folder
> Object target = ss.getTargetForFilter(fref);
> if (target instanceof IRemoteFile){
> remoteFile = (IRemoteFile)target;
> Dave
Re: Problem using SystemRemoteFolderDialog [message #582290 is a reply to message #482122] |
Wed, 26 August 2009 14:22  |
Hi Dave,
Dave
"David Wootton" <dwootton@us.ibm.com> wrote in message
news:54e7b9a3beb626ff7b00a3ad164665ee$1@www.eclipse.org...
>selects either the 'My Home' or 'Root' labels, then getRemoteObject returns
>an instance of SystemFilterReference and I can't get a remote path from
> Thanks
> Dave
Re: Problem using SystemRemoteFolderDialog [message #582316 is a reply to message #482484] |
cases.
> Hi Dave,
> Dave
FUDForum. Page generated in 0.03939 seconds
