Home » Eclipse Projects » Rich Client Platform (RCP) » Cannot get Menu Items in eclipse 3.4
Cannot get Menu Items in eclipse 3.4 [message #481234] |
Thu, 20 August 2009 04:11  |
I have moved from Target platform eclipse 3.3.2 to 3.4 recently.
I have developed an RCP application which has some toolbar icons.
These icons have an initial disabled state. However after running the
application using eclipse 3.4, the initial state of these icons is
toggled to "enabled".
On debugging the code I found that the method getItemCount() of
org.eclipse.swt.Menu class returns an empty list while retrieving the
menu items.
In my code, based on this return value, I am setting the enabled
/disabled state of the icons.But since we get an empty list, no further
operation is possible.
I have not done any code changes in my application. This behavior is
observed after switching the target platform.
I have searched on net if this is a side effect of some changes in
eclipse 3.4 but did not get any solution.
If anybody has come across this problem, please let me know about the
solution.
Sneha
Re: Cannot get Menu Items in eclipse 3.4 [message #481764 is a reply to message #481234] |
Mon, 24 August 2009 05:07   |
its hard to pinpoint your problem remotely. I suggest that you try the
small examples from the following tutorial and then check the difference
to your code:
http://www.vogella.de/articles/EclipseCommands/article.html
Best regards, Lars
sneha wrote:
> menu items.
> solution.
> Sneha
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Cannot get Menu Items in eclipse 3.4 [message #482103 is a reply to message #481234] |
Tue, 25 August 2009 07:52   |
To enable/ disable action I had used code from following link:
(http://www.eclipsezone.com/eclipse/forums/t90781.rhtml) with some
modification.
Display.getDefault().syncExec(new Runnable() {
public void run() {
IWorkbench workbench = PlatformUI.getWorkbench();
Menu menubar = workbench.getActiveWorkbenchWindow().
getShell().getMenuBar();
if(menubar == null ){
return;
MenuItem[] mItems = menubar.getItems();
if(mItems == null){
return;
for(int j = 0 ;j < menuItems.length; j++) {
if(mItems .getText().equals("Tools")){
Menu menu = mItems .getMenu();
for( int i = 0; i < menu.getItemCount(); ++i) {
**** In the above marked line, menu.getItemCount returns 0 but i can
**** see actions entry (menu item) in main menu and toolbar
**** after this code I am trying to get the menu Item action and
** set its state to enabled.
**** But since the code is returning 0 from above line, I am not able to
****toggle the state of the action Item
SubContributionItem cItem = null;
Object menuItemData = item.getData();
if(menuItemData == null){
continue;
if(menuItemData instanceof SubContributionItem){
cItem = (SubContributionItem)menuItemData;
IContributionItem conItems = cItem.getInnerItem();
if(conItems instanceof ActionContributionItem){
ActionContributionItem items = (ActionContributionItem) conItems;
String id = cItem.getId();
if((id != null) && (toolsID.contains(id))){
items.getAction().setEnabled(state);
/disabled state of the icons.But since we get an empty list from
menu.getItemCount(), no further operation is possible.
This code is working perfectly fine in eclipse 3.3.2. Same code gives
problem in Eclipse 3.4.
Any pointers would be of great help.
Sneha
Paul Webster wrote:
> What code do you have? Is it that you have a DROP_DOWN action?
> PW
sneha wrote:
> menu items.
> solution.
> Sneha
Re: Cannot get Menu Items in eclipse 3.4 [message #482104 is a reply to message #481764] |
Tue, 25 August 2009 07:55   |
Thanks for the link. But I am facing this problem after switching from
Eclipse target platform 3.3.2 to 3.4.
please refer to details of my problem in the other mail thread.
Any suggestions would be of great help.
Sneha
Lars Vogel wrote:
> to your code:
> Best regards, Lars
> sneha wrote:
>> Hi,
>> menu items.
>> solution.
>> Thanks,
>> Sneha
Re: Cannot get Menu Items in eclipse 3.4 [message #482562 is a reply to message #482103] |
Thu, 27 August 2009 00:55   |
I still don't have any solution to this problem. I have not yet found
whether the below mentioned problem is a known issue in Eclipse 3.4 or
whether there is a workaround to my problem.
solution.
Any pointers would be of great help!!
Sneha
sneha wrote:
> modification.
> public void run() {
> return;
> if(mItems == null){
> return;
> continue;
> Sneha
> > PW
> sneha wrote:
>> Hi,
>> menu items.
>> solution.
>> Thanks,
>> Sneha
Re: Cannot get Menu Items in eclipse 3.4 [message #482563 is a reply to message #482414] |
Thu, 27 August 2009 00:58  |
Will try out both the solutions.
Thanks a lot!!
-Sneha
Paul Webster wrote:
> your code makes assumptions about the main menu (internal implementation
> details) that I'm surprised worked in 3.3 and definitely won't work in 3.4.
> There isn't a fix. In 3.4, those menu items are created on the fly and
> are disposed more aggressively.
> The correct way to update an actionSet action enabled state is to do it
> from the IWorkbenchWindowActionDelegate. On selection change or
> execution, the IActionDelegate has the opportunity to update its
> corresponding IAction.
> Commands and Handlers have a more flexible lifecycle that allows
> updating some attributes at different points in time.
> PW
Current Time: Sat Aug 30 21:07:06 EDT 2025
Powered by FUDForum. Page generated in 0.05407 seconds
