KeyBindings don't work after product is exported [message #481767] |
Mon, 24 August 2009 05:07  |
Hi all,
I configured KeyBindings for commands in my application following this
tutorial [1].
The Bindings work well if I start the application in the ide. After
exporting the product they don't work there.
Here is what I did.
Created an own Keybinding-Scheme
Added the scheme-id to all bindings.
Added file "plugin_customization.ini" to the root (as mentioned in [1])
and marked it to be exported on the build.properties page.
As it was not working the first time, i found somewhere else (don't
remember where) that adding the property "preferenceCustomization" with
value "plugin_customization.ini" to the product extension point could
help. Tried that, too, didn't work.
What am I missing?
TIA
Tom
[1] http://www.vogella.de/articles/EclipseCommands/article.html# keybinding
Re: KeyBindings don't work after product is exported [message #483179 is a reply to message #483105] |
Mon, 31 August 2009 09:46  |
Thomas Haskes wrote on Mon, 31 August 2009 03:18 | Sorry, forgot to reply on this one because it works meanwhile. Switching
to another workspace made it work, but I couldnt figure out what the
problem was exactly.
The preference set in the customization is a "default". If anything had set the scheme preference at any time in that workspace, that setting would be saved and propagated forward. Maybe that's what happened (it was using an old bogus value).
PW
FUDForum. Page generated in 0.06135 seconds
