Home » Eclipse Projects » Eclipse Platform » Text formatting with label provider
Text formatting with label provider [message #481618] Fri, 21 August 2009 17:41 Go to next message
As you can see from the jdts display of Libraries, there is some way to
change the text style of text in the navigator (e.g. the JREs name is
dark gray).
Since that text is simply returned as a string by a LabelProvider I was
wondering how. Is there some kind of magic formatting for that kind of
stuff or does one have to register a special "FormattingDecorator" for this?
regards
Christoph
Re: Text formatting with label provider [message #481741 is a reply to message #481618] Mon, 24 August 2009 03:47 Go to previous messageGo to next message
Christoph Höger wrote:
> to change the text style of text in the navigator (e.g. the JREs name
> is dark gray).
> was wondering how. Is there some kind of magic formatting for that
> kind of stuff or does one have to register a special
What exactly do you want to do?
Dani
> regards
> Christoph
Re: Text formatting with label provider [message #481952 is a reply to message #481741] Mon, 24 August 2009 16:03 Go to previous messageGo to next message
I have custom Navigator elements (in that case entries for referenced
libraries) for my Modelica projects. I want those elements to be
rendered with custom colors.
You can see a similar feature in JDT: The system library is called "JRE
System Library" (in black) followed by the JRE version in dark gray.
Single library entries have a name and their path in light gray.
That is what I would like to archive for my elements.
Re: Text formatting with label provider [message #481958 is a reply to message #481952] Mon, 24 August 2009 16:45 Go to previous messageGo to next message
I think what you are looking for are the styled label providers added in
3.4. Take a look at these snippets:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet049StyledCellLabelProvider.java?view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet050DelegatingStyledCellLabelProvider.java?v iew=markup
I believe if you use a lightweight decorator to add a prefix or suffix
to an element, it will style it in a different color as well. Though the
color it chooses for the decoration is a platform-wide preference.
Re: Text formatting with label provider [message #482174 is a reply to message #481952] Tue, 25 August 2009 11:01 Go to previous messageGo to next message
> "JRE System Library" (in black) followed by the JRE version in dark
> gray. Single library entries have a name and their path in light gray.
Let your label provider implement
org.eclipse.jface.viewers.DelegatingStyledCellLabelProvider. IStyledLabelProvider.
Dani
Re: Text formatting with label provider [message #482773 is a reply to message #482174] Thu, 27 August 2009 17:43 Go to previous message
Thanks alot Daniel and Jacob!
That was what I was searching for.
Previous Topic:debug JSTL variables
Next Topic:Using P2 to deploy plugins with fragments
Current Time: Sun Jul 27 09:34:55 EDT 2025
Powered by FUDForum. Page generated in 0.05196 seconds
