Home » Archived » BIRT » Argument passing to ScriptedDataSetEventHandler
Argument passing to ScriptedDataSetEventHandler [message #481780] Mon, 24 August 2009 05:51 Go to next message
I have a method that gathers data for the report, and then runs the
report, which uses a scripted data source. The scripted data sets then
retrieve the data that is to be put into the report over a singelton
class that provides the report data.
Currently this method has to be synchronized, because when it is called
a second time while the first call is still reading the report data, it
may happen that the report data that is read by the first caller is
overwritten by the second caller.
So my question is: Is there a way to pass some kind of argument to a
DataSetEventAdapter, such that it knows which report data to use and to
avoid race conditions?
Thanks!
Jacques Stadler
Re: Argument passing to ScriptedDataSetEventHandler [message #481878 is a reply to message #481780] Mon, 24 August 2009 11:42 Go to previous messageGo to next message
Jacques,
Are you using the Report Engine API to run the report? If so you can
get your data and put it in the application context object, which your
scripted dataset can then access.
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("output/resample/test.html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.getAppContext().put("mydataobject", mdo);
The scripted ds would then be able to access the mdo object like:
mydataobject.size(); //assuming mdo is a HashMap
Jason
Jacques wrote:
> Hello,
> Thanks!
> Jacques Stadler
Re: Argument passing to ScriptedDataSetEventHandler [message #481896 is a reply to message #481878] Mon, 24 August 2009 12:37 Go to previous messageGo to next message
Originally posted by: jst.ivyteam.ch
Well, sounds good, but does not work yet.
The thing is that I use a Java DataSet, not javascript.
Any idea how I can access the Application Context there?
Thanks!
Jacques
Jason Weathersby schrieb:
> Jacques,
> Jason
> Jacques wrote:
>> Hello,
>> called a second time while the first call is still reading the report
>> data, it may happen that the report data that is read by the first
>> caller is overwritten by the second caller.
>> to avoid race conditions?
>> Thanks!
>> Jacques Stadler
Re: Argument passing to ScriptedDataSetEventHandler [message #481929 is a reply to message #481896] Mon, 24 August 2009 14:13 Go to previous messageGo to next message
You should be able to get it like:
reportContext.getAppContext().get(Object)
The beforeOpen is passed the reportContext object.
Jason
> Thanks!
> Jacques
>> Jacques,
>> Jason
>> Jacques wrote:
>>> Hello,
>>> then retrieve the data that is to be put into the report over a
>>> singelton class that provides the report data.
>>> Thanks!
>>> Jacques Stadler
Re: Argument passing to ScriptedDataSetEventHandler [message #482037 is a reply to message #481929] Tue, 25 August 2009 04:04 Go to previous message
This works perfectly!
Thank you very much!
Jacques
> Jason
>> Thanks!
>> Jacques
>>> Jacques,
>>> your scripted dataset can then access.
>>> Jason
>>> Jacques wrote:
>>>> Hello,
>>>> report data, it may happen that the report data that is read by the
>>>> first caller is overwritten by the second caller.
>>>> Thanks!
>>>> Jacques Stadler
Previous Topic:pie chart from single row with multiple columns containing numbers
Next Topic:The cols width been fixed when export the report to a "xls" type
Current Time: Sun Jul 20 20:37:35 EDT 2025
Powered by FUDForum. Page generated in 0.04016 seconds
