Home » Eclipse Projects » Eclipse Platform » Handler and JUnit test
Handler and JUnit test [message #481747] Mon, 24 August 2009 04:13 Go to next message
First Thanks for reading this post.
I created an Handler class which deletes model elements from my tree
navigator. It semms to work well. Now I'm trying to write an integration
test for my Handler class. Therefore I used JUnit. I have basic knowledge
in JUnit but i never tested a Handler before. Wenn I start my test, i will
get a lot of NullPointExceptions.
For example that method in the class EMFTransactionPlugin causes an
Exception because getPlugin() returns null. public static String
getPluginId() {
return getPlugin().getBundle().getSymbolicName();
It is easy to understand because the whole UI interaction is missing in my
test.
I created an test Handler which gets me the UI event but how can i
intergrate it in my Junit test?
Now my question.
How can I create an integration test for handlers unsing Junit? Can
somebody please help me, maybe there is a tutorial?
Thank you very much!
RCH
Re: Handler and JUnit test [message #481831 is a reply to message #481747] Mon, 24 August 2009 09:40 Go to previous message
When dealing with plugins, you can create a Junit test (the manifest for your test plugin must depend on org.eclipse.junit). Then you can run your test as a Junit Plug-in Test so that OSGi runs and starts up the appropriate bundles.
PW
Previous Topic:Core Expressions Debugging
Next Topic:Text encoding not picked up from container
Current Time: Mon Jul 21 00:34:53 EDT 2025
Powered by FUDForum. Page generated in 0.06975 seconds
