Home » Archived » Riena » Unable to resize application(Unable to resize Riena examples on Linux)
Unable to resize application [message #481637] Sat, 22 August 2009 01:05 Go to next message
Hello - I have downloaded and setup the Riena environment and I ran into two problems. Problem 1 was that the Riena 1.1.0 does not include 3 plugins (javax.servlet, org.eclipse.equinox.log, and org.eclipse.equinox.security). I fixed this quickly and proceeded to launch both the mail and hello world application. Both applications do not resize once they launch - hitting maximize does not work either. This is of course very odd and I was wondering if anyone else has seen this with Riena. I am running on Linux.
Re: Unable to resize application [message #481801 is a reply to message #481637] Mon, 24 August 2009 07:40 Go to previous messageGo to next message
Hi Chase,
I just tested it under Windows and it worked. Obviously a bug that only occurs under Linux.
Please enter a bugreport and feel free to add a patch to fix it.
kind regards
christian campo
Re: Unable to resize application [message #487195 is a reply to message #481637] Tue, 22 September 2009 08:26 Go to previous messageGo to next message
Am 22.08.2009 07:05, schrieb Chase Wolfinger:
Hello.
I can confirm that resizing doesn't work on Linux.
Are there a lot of people using Riena on Linux?
Regards, Peter
Re: Unable to resize application [message #489411 is a reply to message #481801] Fri, 02 October 2009 17:04 Go to previous messageGo to next message
> Hi Chase,
> occurs under Linux.
> kind regards
> christian campo
FYI: This is a bug in SWT under linux/GTK:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291253
Re: Unable to resize application [message #490837 is a reply to message #487195] Sun, 11 October 2009 14:49 Go to previous message
> Hello.
> Regards, Peter
Honestly I dont have information on what platforms Riena is used. How many people do you know other than you that use
Riena on Linux....
christian campo
Re: Unable to resize application [message #583888 is a reply to message #481801] Fri, 02 October 2009 17:04 Go to previous message
> Hi Chase,
> occurs under Linux.
> kind regards
> christian campo
Re: Unable to resize application [message #583947 is a reply to message #487195] Sun, 11 October 2009 14:49 Go to previous message
> Hello.
> Regards, Peter
Riena on Linux....
christian campo
Previous Topic:Can the imagepath check for PNG then GIF or tell me if an image exists?
Next Topic:Riena 1.2.0.M2 milestone
Current Time: Sat Jul 26 12:54:05 EDT 2025
Powered by FUDForum. Page generated in 0.09084 seconds
